#21379 |
Switched back to e85 tune and did a few hard launches. Forgot what a difference e85 makes!
2022 BRZ Build 2013 FR-S Build |
#21380 |
Drives: Scion FR-S Series 10 #2462
#21381 |
#21382 |
Rust bucket enthusiast
Replaced a coilpack and put the car on the dyno. It ended up where I wanted it, just needed to taper the boost in slower than it was. Stock catback!
![]() Last edited by DarkPira7e; 11-14-2019 at 06:11 PM. |
#21383 |
Drives: Asphalt FR-S
#21384 |
Wes
Installed Perrin engine mounts and Steering Lockdown kit
Instagram: @gt86ws
| The Following 3 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post: |
#21385 |
Sporadic Member
Drives: 2016 Halo FR-S M/T
So I installed secondhand Monogram headlamps tonight, though the unit I bought had the connectors already converted to 6-pin with LED + HID functionality (both lights come on when the stalk is turned to the headlights).
Now my car's electronics seem to be fighting each other for power. My car's lights are flickering all over the place and my door speakers dramatically lose volume. My windows are extremely slow. Since it was the middle of the night, I didn't want to start up my car. For the record, I have the following electronics installed so far: - Aftermarket Seicane Android Headunit - Blackvue DR-700S with a Power Magic Pro hooked up via an add-a-fuse - Hella horns directly connected to the battery (removed, replacing the harness with a better PNP solution) In addition to removing the horns, I also disconnected the DRL resistor since it was no longer necessary. Still having issues. Any ideas on where to start? I have a suspicion that there's too many electronics; more than the car can handle, since everything was working fine just moments ago before I installed the lights (except for the fact that I had intermittent speaker issues beforehand). Hopefully I didn't buy a pair of janky headlights here. I don't really believe that to be the case since I've had subtle electronic issues before. EDIT: Out of curiosity, I attempted to start the car. Nothing but clicks. I'm getting less than 9 volts according to my OBDII scanner. I truly wonder if my battery really needs replacement considering it started the car without issues just a moment ago when I needed to reposition it so I could work on it. Last edited by KR-S; 11-18-2019 at 07:20 AM. |
#21386 |
#21387 | |
#21388 | |
Sporadic Member
Forgot to mention I had the radio on the whole time during the install. Not sure if that was enough to drain the battery, but it probably did. |
#21389 |
Charging the battery should probably be your first step then
| The Following User Says Thank You to Ashikabi For This Useful Post: | Dadhawk (11-18-2019) |
#21390 |
Sporadic Member
#21392 | ||
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | DarkPira7e (11-18-2019), KR-S (11-19-2019) |
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
