Old 11-15-2019, 03:07 AM   #62973
Hells bells, we had variable compression engines commercially produced back in the 30s.
Iffen ya don't believe that, just try starting one of these suckers without knowing about it -
humfrz is offline
soundman98 (11-16-2019)
Old 11-15-2019, 05:49 AM   #62974
p1l0t
p1l0t's Avatar
Nice tractor
p1l0t is offline
humfrz (11-15-2019)
Old 11-15-2019, 07:34 AM   #62975
Boomerang
86
Boomerang's Avatar
Nice tractor
Boomerang is offline
The Following 3 Users Say Thank You to Boomerang For This Useful Post:
humfrz (11-15-2019), p1l0t (11-15-2019), Ultramaroon (11-15-2019)
Old 11-15-2019, 07:46 AM   #62976
I had at least a couple of cars that had variable compression. They weren't supposed to be variable but they were.
Tcoat is offline
Dadhawk (11-15-2019), NoHaveMSG (11-15-2019), soundman98 (11-16-2019), Ultramaroon (11-15-2019)
Old 11-15-2019, 08:16 AM   #62977
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Mine varied depending on what cylinder you picked.
Sapphireho is offline
soundman98 (11-16-2019), Tcoat (11-15-2019)
Old 11-15-2019, 08:27 AM   #62978
Tcoat is offline
Sapphireho (11-15-2019)
Old 11-15-2019, 09:49 AM   #62979
Lantanafrs2
Drives: 2013 frs red
Higher pressure results in less losses to entropy during combustion. In theory you want the highest compression you can get at all times. But the limiting factor is the tendency of gasoline/air to detonate when you compress it too quickly. By decreasing the maximum pressure, you decrease the rate of compression. Thus allowing higher rpm, advancing timing, and more fuel/air (higher boost) at higher temperatures.
Being able to tune the compression ratio gives you the best of both worlds in the same engine.
Absolutely but Nissan's solution seems somewhat elaborate to me. I agree with the poster who called it "marketing "
Lantanafrs2 is offline
Old 11-15-2019, 10:04 AM   #62980
JD001
JD001's Avatar
Drives: Subaru BRZ
No messing with that steering set-up.. couldn't be more direct. I wonder if anyone has tried a similar mod on their Twin.
JD001 is offline
The Following User Says Thank You to JD001 For This Useful Post:
humfrz (11-15-2019)
Old 11-15-2019, 10:26 AM   #62981
Dat camber though! Need more low and Rocket Bunny.
Tcoat is offline
bcj (11-15-2019), humfrz (11-15-2019), JD001 (11-15-2019)
Old 11-15-2019, 10:33 AM   #62982
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Aw shit, finally able to pull the required documents and open a business checking account. Time to spend some money!
Nevermore is offline
Old 11-15-2019, 11:49 AM   #62983
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Can you describe a simpler solution to achieve variable compression?
Spuds is offline
Old 11-15-2019, 12:27 PM   #62984
JD001
JD001's Avatar
Drives: Subaru BRZ
Hole in the block could be one such 'simpler solution' to achieve variable compression..
JD001 is offline
The Following 3 Users Say Thank You to JD001 For This Useful Post:
NoHaveMSG (11-15-2019), soundman98 (11-16-2019), Tcoat (11-15-2019)
Old 11-15-2019, 12:33 PM   #62985
Could even make it controllable.
Tcoat is offline
Dadhawk (11-15-2019), JD001 (11-15-2019), Lantanafrs2 (11-15-2019), p1l0t (11-15-2019), soundman98 (11-16-2019)
Old 11-15-2019, 12:49 PM   #62986
Lantanafrs2
I wouldn't look for it in the first place. Not that big of an issue. All those reciprocating pieces. How about a good head unit? Or exhaust systems that dont rot out in 2 years?
