Old 11-01-2019, 11:17 AM   #29
RotARy15
Drives: 1993 Mazda RX-7 R1, 2025 BRZ tS
I just remembered that I was interested in quick caliper spreaders. It appears the Lisle ones are junk and everything else I can find is stupid expensive. I don't get it. They are just reverse pliers....
RotARy15 is offline   Reply With Quote
Old 11-01-2019, 11:36 AM   #30
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by i8ur911 View Post
Any decent pad for the track is going to make noise.
One of the pros of the PP cars is the quickness of changing pads with the Brembo's. I can do all 4 calipers in less than an hour....and that's taking my time.
With that being said, it's in your best interest to swap pads. Not only is the noise annoying, but you don't want to wear out expensive pads by street driving them. You also don't want to ruin rotors with using "cold" track pads on the track.
That's my $0.02.
Sent from my Pixel 3 using Tapatalk
There is loud, and then there is freight train coming to an emergency stop. @mistople's car was really loud. My XP10's were almost as bad, not quite. I am on CSG C1's now. They make a bit of noise at low speeds but are pretty quiet.
Old 11-01-2019, 12:13 PM   #31
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Yep. My car goes full freight train with the W5s when even remotely under regular track temps.
mistople is offline   Reply With Quote
Old 11-01-2019, 01:31 PM   #32
TunaNoCrust
TunaNoCrust's Avatar
Drives: 86, 981S, RX8, 2500HD, GenesisV8
I have used the Lisle ones for two years, and well over a dozen brake pad changes without a single issue...even on my 2500HD.
TunaNoCrust is offline   Reply With Quote
Old 11-01-2019, 01:37 PM   #33
ZDan
ZDan's Avatar
Drives: '23 BRZ
I'll have to try these PFC11's at some point then.
Every other track pad I've run makes noise and I've never been a fan of the "street/track" pads. There's always a compromise with those as they can't be great at both disciplines.
There is *always* a compromise with *any* pad, period.
As for "street/track", for *me*, Carbotech XP8 and XP10 and PFC 11 have all worked great for me as street/track pads for entire track seasons. I would like more initial bite than any of these have but not willing to go noisier or dustier or less effective when cold.
Pads that didn't work for me as "street/track":
WinMax W5 too loud, Project Mu CR not enough cold bite, and going *way* back, Hawk HP+ way too much corrosive hard-to-clean black dust and way too much noise on the street.
Old 11-01-2019, 01:45 PM   #34
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The C1's feel like they have better initial bite then XP10's. I don't think the friction coefficent is much higher but I think they are less compressible which also leads to more consistent pedal feel. They are also much quieter and don't seem to dust any worse. They are much more expensive though.
Old 11-01-2019, 03:51 PM   #35
TunaNoCrust
How did you like the 9012s on my car? I find them twice as noisy as the HP+. My Pagid Yellows on the Porsche were very quiet.
Are you mostly driving the Porsche on the street?
Old 11-01-2019, 04:38 PM   #36
ZDan
ZDan's Avatar
Drives: '23 BRZ
I don't remember them so they musta been fine! Do you run them on the street a lot or swap them out?
I'm back and forth between CAyman and BRZ on the street. Cayman is nicer (i.e., less wind and road noise and feels noticeably more solid), mucho bettero engie noises , but BRZ feels lighter which I like and also has better steering IMO. Cayman steering is too slow and also too heavy, and the steering wheel is too big. Also mine feels very nonlinear at ~45 degrees steering wheel angle particularly on right-handers. Honestly I'd like the Porsche twice as much if it had the BRZ's steering.
Old 11-01-2019, 05:36 PM   #37
Grady
Grady's Avatar
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
I doubt it!
It is close but I have you by 5 months.
Old 11-04-2019, 01:12 PM   #38
TunaNoCrust
Haha well thats good then!
I run them on the street, I have no issues. Even my Genesis has HP+.
My Porsche's steering although heavy was never non-linear, that sounds pretty awful. I did like it better at high speeds than the 86s, but that could have just been the car itself?
Could it be a steering geometry issue? I wonder if there is an upgrade to make it 981 steering?
Old 11-15-2019, 10:26 AM   #39
pcs
Just get the oil cooler. Do you really want to be running multiple sessions in a day at 270*F?
I never understood the 'oil cooler isn't needed' crowd. engine makes less power, oil gets thinner and breaks down faster, and you have to constantly monitor it. Even if it isn't absolutely needed, it seems silly to not get one given how critical oil is. By the time you realize you need it, it might be too late.
pcs is offline   Reply With Quote
Old 11-15-2019, 10:32 AM   #40
pcs
*shrug* looks like this is your regular topic here, @ZDan lol. guess we'll have to be on different sides of the coin.
Old 11-15-2019, 12:59 PM   #41
ZDan
ZDan's Avatar
Drives: '23 BRZ
Does it though? Does ECU pull timing with oil temp or something? If not I can't think of any reason it should lose power. If it does it's not enough to be obvious or noticeable. But if so I'll definitely be addressing that...
Hotter = thinner, so run 30wt during track season. 30wt viscosity at 270F is similar to 20wt at ~235F
Casual track usage, the oil doesn't break down particularly quickly. This has been demonstrated with oil analysis. You don't have to "constantly monitor it". Of course you should check oil level regularly anyway.
Old 11-15-2019, 01:57 PM   #42
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
A few people, I am not one of them, don't believe the pressure loss from running a cooler is worth it and chose to offset it by running 5-30 instead. It really depends on your region and how long your sessions are.
If your oil is breaking down from temperature you need to run different oil. Through UOA's and ASTM testing good modern synthetics like Motul 300V and Redline take a TON of tempt to break down. 300V has been tested at 300F for 40 hours with little to no break down or degradation.
WTB: Performance Pack Wheels Chuckable Want-To-Buy Requests 0 07-27-2019 12:18 PM
WTB: Performance Pack Wheels Chuckable Want-To-Buy Requests 0 07-27-2019 12:16 PM
Performance pack brakes Jdmuscle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 03-11-2019 05:05 PM
to performance pack or not Victorscp Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 10-19-2018 03:53 AM
GT-86 optional performance-pack Ziptuning Scion FR-S / Toyota 86 GT86 General Forum 24 08-29-2012 03:00 AM
