Old 07-10-2019, 07:33 PM   #43
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Originally Posted by showrun View Post
Nice meeting you yesterday at Pacific (even though you weren't driving your Twin ;-) ). I'm the guy with the orange FR-S.
Yeah, well, it's hard to drive the Twin when it has a blown engine
I'm having an engine built by Bluemoon and will have a tune (possibly different ECU) that will have some safeguards against running too low on gas with a supercharger. Also getting the baffle/flap thingy for the fuel tank. Still a good two months out before its backup and running, probably closer to three... sigh.
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
rixter145 (09-30-2019)
Old 11-13-2019, 12:25 PM   #44
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
It's been a long summer without my BRZ, but, this arrived so should be back in business soon
Thx Bluemoon!
The Following 6 Users Say Thank You to Sleepless For This Useful Post:
Code Monkey (11-13-2019), DarkSunrise (11-13-2019), mistople (11-13-2019), new2subaru (11-13-2019), NoHaveMSG (11-13-2019), TunaNoCrust (11-13-2019)
Old 11-13-2019, 07:55 PM   #45
amcp1
Drives: frs
Any details on the build? Keeping the JR setup?
amcp1 is offline   Reply With Quote
Old 11-14-2019, 12:49 PM   #46
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Yes, keeping the JRSC but upgrading to the high boost pulley.
The build is the "standard" Bluemoon setup.
FA20 / 4U-GSE short block:
- 2017+ New OEM block
- OE New Crank Shaft w/ WPC SU00300155
- Boring and Honing using torque plate for fitment of New Pisons x4
- Deck straight block
- Bluemoon Piston 86.5mm CH 28.8mm, Window Milling & Anti-Detonation Grooves by CP Piston (12:1 Compression Ratio)
- Bluemoon Connecting Rod kit - C-C 133.3mm, Pro-H by Carrillo
- Main Bearing Set - SU003-00156
- Connecting Rod Bearing Set Race Series Boring ACL, 4B8610JJ
- ARP Main Bolt Kit - Austenitic Stainless 260-5001
- WPC Metal Surface Treatment Bottom End Package (Crank Shaft, Main Bearing, Rod Bearing, Connecting Rods, Pistons, Piston Ring, Piston Wrist Pin, Cylinder Wall)
- Bluemoon baffled oil pan
Long block additions:
- Rebuilt Heads (converted to 2015 specs)
- Porting, polishing,
- ARP head studs
- Head gasket of your choice (this will determine final compression ratio)
- Valves, springs, and proprietary rocker arm retainer clips.
- WPC treatment all friction surfaces.
- Fluidampr - Hi Performance Damper
The Following 4 Users Say Thank You to Sleepless For This Useful Post:
Code Monkey (11-14-2019), Elliotw (03-06-2020), new2subaru (01-09-2020), NoHaveMSG (11-14-2019)
Old 01-09-2020, 05:52 PM   #47
PNWBRZTS
Drives: 2018 BRZ TS
- ARP head studs
Sleepless - how is progress on the car? Any regrets with the build by bluemoon? I may be headed in a similar direction with my car and would love to hear of any lessons learned: what has worked for you, and what hasn't. Also, I'm local - work in Redmond - and would love to see it when it is back together.
PNWBRZTS is offline   Reply With Quote
Old 01-09-2020, 08:30 PM   #48
amcp1
Drives: frs
Yes any thoughts on the build?
The Following User Says Thank You to amcp1 For This Useful Post:
Lonewolf (01-11-2020)
Old 01-11-2020, 04:28 PM   #49
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Bluemoon was very good and easy to work with.
The car is up and running fine, but is now in storage for the winter.
Code Monkey (01-11-2020)
Old 03-05-2020, 08:32 PM   #50
GrabTheWheel
Drives: 16' BRZ
Curious to see how this works out for you. Know many people who didn’t have good luck tracking built FA20’s, myself included. Just know that your baffled oil pan may not be enough.
GrabTheWheel is offline   Reply With Quote
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo tampaSi Brakes, Suspension, Chassis 4 05-27-2017 02:31 PM
MVP Track Time 2013 Great Lakes/Midwest Track Dates Feffman Great Lakes 5 09-07-2013 01:39 PM
GPS Track Time /Nine Lives Racing Track Day and Auto Show (Sun. 9/8) Chicago Great Lakes 0 08-13-2013 08:42 AM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-20-2012 11:31 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
