| Member's Car Journals Car journals by our members. |
Drives: 2014 BRZ
Sleepless Track BRZ
Suspension:
Ohlin's R/T with 450 lb (8 k) springs (all corners) and Ohlin's camber plates SPL Front LCA, Rear LCA, bump steer rods, rear toe links, rear track/trailing bars Perrin 22mm front, 19mm rear swap bars Whiteline subframe and diff inserts AEM strut brace Engine & drivetrain: Bluemoon built engine Jackson Racing Supercharger Jackson Racing oil cooler Dual Radium catch cans ECUTek tuned by Drift Office STi motor and trans mounts Shifter bushing and return springs Final Drive: 3.73 DSS 600HP axles Brakes/Wheels/Tires: Enkei PF01 17x9 et45, PF01 17x8 et45 Tires tried: MPSS, NT01, Trofeo R, ADO8R, Z214 Stoptech 328mm BBK G-LOC R16 pads APR brake ducts Aero: APR GTC 200 wing Verus composite splitter and end plates, underbody panels, splitter, hood vents STi underbody panels TRD canards, mirror deflector, trunk deflector Interior: Recaro Profi XL seats Schroth Profi-6 HANS harnesses Cantrell Motorsports 4-point roll bar Raceseng shift knob CMS Lap Timer on iPod Touch data logger and video AIM Solo DL data logger and video
| The Following User Says Thank You to Sleepless For This Useful Post: | rixter145 (07-14-2020) |
Drives: '18 BRZ tS, '18 GTI SE, '11 RS
Photos?
Drives: frs
Yeah pics!
And why did you drop to a 3.73 FD? |
Drives: 2013 WRB BRZ 6MT
I can't say for certain this is why but I see hes boosted and I know people making a lot of power often prefer longer gearing so they don't have to shift as much. It gets old quick when you go through 3rd gear in only 1 second because the car makes so much power.
It's also often track dependant. Like my own local track has some long increasing radius turns that I have to slow down a lot on entry but end up running out of gear before exit so my options are to short shift before the corner and fall out of the power band or shift mid corner which tends to upset the chassis and can be dangerous. |
Drives: 2014 BRZ
First, the purchase. I was really torn between the metallic white and WR Blue. Blue won after many circles walked around the two parked together. Purchased from Eastside Subaru in Kirkland, WA just a bit over 4 years ago.
Drives: 2014 BRZ
With roughly 300 crank hp (265WHP) the stock gearing forces me to shift into higher gears too quickly and 6th gear is a really high overdrive so at Pacific Raceways I'd loose speed if I shifted into 6th so had to stay in 5th just below redline for way too long; well before T1.
Basically, shifting the gear changes allows me to stay in a lower gear which actually gives me more power over a lap at most any track. Higher final drives are fine for quick acceleration when top speed is not a factor (street driven and autocross). This is what the car looked like a couple months ago before I stripped the interior, changed to the Profi XL seats (had Sportsters for a couple of years; loved them but heavier and not as much support but were great when it was driven on the street).
| The Following User Says Thank You to Sleepless For This Useful Post: | Lonewolf (07-13-2018) |
Drives: 2014 BRZ
Some past pics (I'll post current interior and exterior in a few days; car is at Cantrell Motorsports in Bellevue getting a few tweaks).
This are from the Ridge Motorsports Park.
Drives: 2014 BRZ
APR wing installed.
| The Following User Says Thank You to Sleepless For This Useful Post: | Lococholo84 (07-13-2018) |
Car looks great! But I may be biased lol.
| The Following User Says Thank You to Elliotw For This Useful Post: | Lococholo84 (07-13-2018) |
#11 |
Drives: 2014 BRZ
Waxed for better aero
| The Following User Says Thank You to Sleepless For This Useful Post: | Elliotw (07-15-2018) |
#12 |
Drives: 2014 BRZ
Was at the Ridge Motorsports Park and this happened toward the end of a fine second session:
Left rear axle broke ![]() Given this car has been heavily tracked for 4 years, 2 with the JRSC I can't say I'm surprised. Ordered some DriveShaft Shop axles from CSG
#13 |
Drives: 2014 BRZ
Made it out to Pacific Raceways with the new DSS axles and new 17x9 Enkei PF01s with new Hankook Z214s (245/40). Car ran great and with the new tires and to no surprise got my best lap time at 1:36 in 85F ambient temps.
Can't wait for a 65F day!
| The Following User Says Thank You to Sleepless For This Useful Post: | NoHaveMSG (08-10-2018) |
#14 |
Drives: 2014 BRZ
Video chasing my friend in his Cayman S and my fastest clean lap.
| The Following User Says Thank You to Sleepless For This Useful Post: | jflogerzi (08-12-2018) |
| FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo | tampaSi | Brakes, Suspension, Chassis | 4 | 05-27-2017 03:31 PM |
| MVP Track Time 2013 Great Lakes/Midwest Track Dates | Feffman | Great Lakes | 5 | 09-07-2013 02:39 PM |
| GPS Track Time /Nine Lives Racing Track Day and Auto Show (Sun. 9/8) | Chicago | Great Lakes | 0 | 08-13-2013 09:42 AM |
| Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning | AZP Installs | NY / NJ / CT / PA | 11 | 08-21-2012 12:31 AM |
| Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning | AZP Installs | Tracking / Autocross / HPDE / Drifting | 0 | 08-14-2012 07:46 PM |
