Old 11-10-2019, 01:02 AM   #113
jflogerzi
jflogerzi's Avatar
I stick with 5w-30 as I am boosted. Sent my first sample to Blackstone. Also run JC racing dual radiator cooler.
2013 Series 10 FRS #553
Old 11-10-2019, 05:47 AM   #114
Apelsin
Drives: Jeep
So, what is so bad about high oil temperatures? Did anyone actually blew their engine tracking on 0w20 without an oil cooler?
Apelsin is offline   Reply With Quote
Old 11-10-2019, 10:44 AM   #115
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
At higher temperatures, oil becomes less viscous and it is unable to lubricant the rotating assembling sufficiently. While this might not lead to "blowing an engine", the more worrying fear it that it will lead to long-term issues down the road.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 11-10-2019, 02:17 PM   #116
Tristor
Tristor's Avatar
1. Temperature and pressure are related. Higher temperatures = lower pressure, not enough oil pressure able very bad things (TM) happen.
2. Yes, many examples exist of people learning about very bad things (TM) the hard way. At this point it’s just stupid to track this car without an engine oil cooler.
Tristor is offline   Reply With Quote
The Following 2 Users Say Thank You to Tristor For This Useful Post:
new2subaru (11-10-2019), Ultramaroon (11-10-2019)
Old 11-20-2019, 06:02 PM   #117
mrhayes1
Drives: 2013 Scion FRS white
Its pretty well widely understood that 0w20 oils, and now even 0w16!!, are solely for fuel economy. If emissions/fuel economy was not on the table, we would still be putting 5w30, 10w40 in all our cars. The only real advantage to 0w20 is you could say it better protects the engine during cold starts as opposed to 5w30, etc.
mrhayes1 is offline   Reply With Quote
Old 11-20-2019, 06:41 PM   #118
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
If cold starts are a worry, just run 0W30
Old 11-21-2019, 02:29 PM   #119
ZDan
ZDan's Avatar
Drives: '23 BRZ
Lower viscosity at higher temps is not an issue if you go to a heavier oil. Viscosity of 5w30 at 270F is about the same as viscosity of 0w20 at 230F-235F.
As for oil pressure, just look at the plots on the first post in this thread. The oil pressure for 5w30 oil is the same with or without an oil cooler.
So, viscosity isn't an issue if you use thicker oil, and pressure isn't an issue either as the pressure drop due to the oil cooler is equal to the pressure that would have been gained due to cooler oil.
Plenty of engines have failed *with* oil coolers. There's a *great* thread which suggests that the stock oil pickup tube is the culprit for sustained high-rpm usage.
https://www.ft86club.com/forums/showthread.php?t=134863
I'm pretty satisfied that I'm OK tracking without a cooler for my car and my usage.
It should be noted that adding an oil cooler is not a risk-free proposition. Leaks are not uncommon...
As in other threads, for those considering getting one I'd suggest first having oil analysis done before and after tracking, and see if oil degradation and particulates indicate any problems before investing in an oil cooler.
Old 11-21-2019, 04:09 PM   #120
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I go one better and run synthetic 0W-40 along with the FXT cooler.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 11-21-2019, 04:11 PM   #121
venturaII
venturaII's Avatar
Is that the one where OP went with the Killer B pickup tube...?
Old 11-21-2019, 04:53 PM   #122
ZDan
ZDan's Avatar
Drives: '23 BRZ
They modified Killer B with a larger tube. Here's the thread, I'll link it in my post above as well:
venturaII (11-22-2019)
Old 11-28-2019, 12:17 PM   #123
Apelsin
Drives: Jeep
How do you measure oil temperatures? Is there an app/obd2 scanner combination that can do it? Mine can't
Old 11-28-2019, 12:26 PM   #124
jflogerzi
jflogerzi's Avatar
Search for the torque app in Android and how to create the custom pid to measure. Just need a Bluetooth obo2 reader
Old 11-28-2019, 12:42 PM   #125
Apelsin
Drives: Jeep
Anything that works with Apple?
Old 11-28-2019, 01:03 PM   #126
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Has anyone established what oil pressure is adaquite for NA? I know typically the boosted guys like to see 10psi per 1k RPM.
Quickie: 0w20 vs 5w20 / 5w30 empower-auto Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 43 12-17-2016 01:54 PM
Oil 5w30 cooldandani Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 05-27-2015 09:50 AM
UOA 5w30 Rocket.BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 07-07-2014 11:29 PM
Where to buy Eneos 5w30? mswhong AUSTRALIA 0 03-26-2013 06:25 AM
DOT Crash Test (non) Data for FR-S/BRZ Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 15 03-24-2012 04:21 AM
