Old 11-08-2019, 02:03 PM   #29
scuzzy
Drives: 22 BRZ limited MT
If it's a daily driver just get better tires.
scuzzy is offline   Reply With Quote
Old 11-08-2019, 02:45 PM   #30
Tristor
Tristor's Avatar
Originally Posted by FinallyGot View Post
I'm thinking of getting a staggered setup. Thoughts on this spec?
Wondering if fitment would be flush. I'm aware of the wheelitfit website but I'm a bit confused looking at it. Some people say there is rubbing running 9.5" then others say they have no issues.
Front: 18x8.5 +45 Tire: 235
Rear: 18x9.5 +45 Tire: 245
As mentioned before I'm on stock suspension. Stock brake kit, maybe upgrading.
Don't run staggered setups on this platform. It's doable, but require significant adjustment to compensate. The platform is not designed for staggered and it negatively affects driving dynamics without compensating in geometry.
Also, for stock suspension I'd recommend 9" wide or narrower wheels, going wider than 9" will be problematic. To run wider than 9" you need to run aftermarket suspension arms to adjust camber to prevent rubbing and usually aftermarket endlinks as well.
17x9 +41 or +42 is about perfect on stock suspension to get a flush look and meat. 18x8.5 +44 is also about perfect on stock suspension.
The rear technically needs a little more offset which can be corrected with slip-on spacers, but it's not necessary.
Tristor is offline   Reply With Quote
The Following User Says Thank You to Tristor For This Useful Post:
Will BRZ (11-10-2019)
Old 11-08-2019, 03:10 PM   #31
FinallyGot
Drives: Brz
I'll probably get 18x8.5 front and back. However About spacers, Is it safe to run them? Whats the torque required? Lmao I'm just scared to be cruising on the highway then look in my rear view mirror and see my wheel flying off.
FinallyGot is offline   Reply With Quote
Old 11-08-2019, 03:32 PM   #32
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Just buy some extended studs to be safe.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 11-08-2019, 04:26 PM   #33
TommyW
TommyW's Avatar
Drives: '13 Whiteout
For ride quality stick with 17" wheels. Good tires of whatever width you like and some good lowering springs and the car will look great handle well and you aren't spending a bunch of money on coilovers that you don't need for the street anyway. 18's look a bit better but then you have the form and function thing going on, a bit harsher ride for a slight improvement in looks
TommyW is offline   Reply With Quote
Old 11-08-2019, 04:51 PM   #34
Tristor
Tristor's Avatar
You don't have to have spacers, they're just for flushing the wheels out in the rear for looks. As long as you have good thread engagement it's the same torque as normal... 89 lb/ft. I've been running billet spacers on track and on the street the whole time I've owned my car. If you buy quality spacers and torque your wheels properly you've got nothing to worry about.
If you want more than a 3mm slip on spacer though, you need to get extended studs and open-ended lug nuts. ARP extended studs and CSG Spec lugs are where it's at.
Old 11-17-2019, 02:35 PM   #35
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Now, If I had things to do over...
I would get first:
1" drop springs
SPC LCA
Whiteline bumpsteer kit
camber bolts
spacers for stock wheels.
Later I would upgrade the shocks to koni or bilsteins. Then buy a set of wheels. 18x9 +30 to +45 is a good size IMO.
Now that you’re on coilovers, you wouldn’t have gone for coils right away along with the LCA and all that?
Will BRZ is offline   Reply With Quote
Old 11-17-2019, 03:18 PM   #36
86TOYO2k17
Drives: 2017 toyota 86
Not sure if every wheel has the same thickness at the lug holes. But i got 8 1/4 turns on my lugs with a 4mm spacer.
Old 11-17-2019, 08:57 PM   #37
Will BRZ
Drives: 2015 BRZ
Originally Posted by darksnyder View Post
Find below 18" TRD SF rims on Pilot Super Sport 225/40/18 on stock suspension. Changing to MPSS has totally changed the way the car grips now!
225/40/18 is perfect on stock suspension. Fills up the wheel well nicely and isn’t that far off of stock diameter. I’d probably just get spacers in the rear and a lip kit or something. Though there’s something about a meaty tire on a 17 with a one finger gap between the tire and fender that I love
The Following User Says Thank You to Will BRZ For This Useful Post:
FinallyGot (11-19-2019)
Old 11-18-2019, 01:26 PM   #38
Leonardo
Country Boy 4 Life
Leonardo's Avatar
No way. I would not get coils again. I would upgrade to koni or bilsteins. I would also keep my rubber bushings and not go pillow-ball everywhere.
245's fit on a 9" wide wheels.
9" wide wheels fit without coils.
Anyway... It's all just a learning experience for me...
I LIKE TIRES!
Will BRZ (11-20-2019)
Old 11-19-2019, 12:19 AM   #39
FinallyGot
Drives: Brz
Love this Idea, Any recommendations for lowering springs?
Old 11-19-2019, 10:22 AM   #40
TommyW
TommyW's Avatar
it depends on how low you want. 3/4 is good and 1” seems a bit much. I’ve had good luck with H&R however there is RCE, Hotchkiss, etc.
Old 11-19-2019, 11:49 AM   #41
HaXx
Drives: jrsc_brz
the rce yellows
i dont even have them, but its just known that they are the gold standard
heres a thread about coils, and the yellows are talked about a bunch
http://www.ft86club.com/forums/showthread.php?t=137716
HaXx is offline   Reply With Quote
The Following User Says Thank You to HaXx For This Useful Post:
Racecomp Engineering (11-19-2019)
Pure red FRS, how it looks on yonaka coilovers and XXR wheels nhuyvan1106 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 11-11-2016 03:33 AM
FS: FR-S / BRZ Exhaust, Coilovers, Wheels GuerillaRacing Southeast 0 10-24-2013 04:33 PM
HKS coilovers and Rays wheels sold. Blur GT Australia Classifieds 7 08-16-2013 11:09 PM
KAB Whiteout FR-S, BC Coilovers and Klutch wheels KAB-FRS BRZ Photos, Videos, Wallpapers, Gallery Forum 3 10-19-2012 01:12 AM
Coilovers vs. Springs and aftermarket wheels. BigJyoungblood Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 10-01-2012 12:47 AM
