Old 11-08-2019, 01:26 PM   #449
Hey was there official word of additional sound deadening on this model or is it just an informed guess? Does the trunk liner produce a noticeable difference? Thanks!
I can tell you it does zero for acoustics but is worth +5HP in terms of looks. It was one of the few mods I made to my car in 2013.
StraightOuttaCanadaEh (11-08-2019)
Old 11-08-2019, 04:32 PM   #450
etherdude
Drives: 2020 Hakone Edition, 2015 FR-S
Nice car. I'm noticing a very strange trend, what's going on with your handbrake?
Air Force salute...Aim high!
etherdude is offline   Reply With Quote
The Following User Says Thank You to etherdude For This Useful Post:
JD001 (11-09-2019)
Old 11-08-2019, 04:36 PM   #451
etherdude
The trunk liner does two things.
1) It helps protect the sheet metal from getting dents if you get too exuberant when slamming the trunk. Important for me when I travel with large low brass instruments in hard cases.
2) It DOES make a difference in road noise when travelling with rear seat down (which I do a lot - see #1 re: large brass instruments). Reduces some of the noise transmitted through the trunk lid (particularly when I had my TRD exhaust). When the seat is up, it doesn't do a whole lot.
Doug
Dadhawk (11-10-2019)
Old 11-08-2019, 04:50 PM   #452
etherdude
Informed guess...but I have my 2015 amd the 2020 I can drive back to back to compare. Plus I am a musician so my "ear" is pretty good. The 2020 definitely is a bit quieter.
I will say that the sound quality from the 2015 head unit is better, with more robust bass and more control over tonal options. The 2015 head unit fit all Scions but was "tuned" for the FR-S. The 2020 head unit is actually pretty cheap and simple, sounds a bit tinny, and has only very basic tone controls that don't seem to actually do much. But it does support Android Auto, which was important to me.
As a musician, I listen to LOTS of classical music and Jazz. In the greater Boston area, we have the best classical on 99.5 WCRB. I can get this with HD FM on the 2015 head unit from two different transmitters. I use my phone to get 91.1 KCSM Jazz from the SF bay area and to get WCRB when travelling.
The Following 2 Users Say Thank You to etherdude For This Useful Post:
Myriad (11-09-2019), StraightOuttaCanadaEh (11-08-2019)
Old 11-08-2019, 05:51 PM   #453
new2subaru
Weight Weenie
Drives: 15 FR-S
It could be you tires. The Michelin Pilot Sport 4S's are going to be quieter I would imagine. I found the stock tires to be loud.
The Following User Says Thank You to new2subaru For This Useful Post:
chaoskaze (11-08-2019)
Old 11-08-2019, 09:30 PM   #454
etherdude
Originally Posted by new2subaru View Post
It could be your tires. The Michelin Pilot Sport 4S's are going to be quieter I would imagine. I found the stock tires to be loud.
It could be, but I took the Pilot Sport 4S's right off of my 2015 FR-S on Oct. 30 and put them on the 2020 Hakone 86. So the comparison is pretty much apples and apples.
I do know that even my winter Blizzak WS80's are quieter than the Bridgestone Turanza EL400's (POS!) that were OEM on my New England 2015 FR-S. I replaced the Turanza's with Michelin PSS's and then 4S's. The 4S's are the quietest of the bunch. I don't know about the Primacy's that were OEM on the 2020 Hakone 86, since I never drove it with them on. I will put those tires on my OEM FR-S rims and will sell the FR-S with that tire wheel combination.
Doug
new2subaru (11-09-2019)
Old 11-09-2019, 12:25 AM   #455
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
It’s not just that, if you put the new 4.3 differential on cars before 2017 you will notice the newer car is indeed quieter.
The Following User Says Thank You to chaoskaze For This Useful Post:
Old 11-09-2019, 01:05 AM   #456
new2subaru
Weight Weenie
Drives: 15 FR-S
Can't quote you for some reason
That's interesting. Why does the 4.3 would make the car quieter?
Old 11-09-2019, 04:14 AM   #457
JD001
JD001's Avatar
Drives: Subaru BRZ
I like to throw another thought into the 'it's quieter' debate. I think that cars for the American market are down spec'd to meet the tougher cost brackets etc. Hence, cars are rather basic and with that you get greater NVH. The 'newer' American market cars could be nearer European specs..
Old 11-09-2019, 05:47 PM   #458
Myriad
Myriad's Avatar
Drives: 2017 86, 2012 Tundra, 1999 Integra
Regarding noise, don’t forget the underbody aerodynamic plates. They come on the higher end 2017+ models. They did not come on my 2017 base model and I don’t believe they were on the FRS models either. I added them and they made a bit of a difference at highway speeds.
Myriad
Myriad is offline   Reply With Quote
Old 11-09-2019, 09:57 PM   #459
new2subaru
Weight Weenie
Drives: 15 FR-S
Myriad
That's good to know. I have a set on order
Old 11-09-2019, 10:11 PM   #460
You'll love them. Be careful with the points where the panels mount over the fiber board. There should be spacers or special taller shoulder screws provided [but are not]. Blue Loctite helps.
Old 11-09-2019, 10:15 PM   #461
new2subaru
Weight Weenie
Drives: 15 FR-S
You'll love them. Be careful with the points where the panels mount over the fiber board. There should be spacers or special taller shoulder screws provided. Blue Loctite helps.
Thanks! I've had that off and have seen the spacers you're talking about. I'm anal when I take things apart and have a box of zip top baggies, schmatic and a labeler handy! Sometimes you don't get back to stuff as quick as you like...
Ultramaroon (11-10-2019)
Old 11-10-2019, 12:08 AM   #462
Edited my last. Sorry for vague post.
Advan Racing Special 18s TC3 and RGD2 - special for 2019 must check it out! Gruppe-s Wheels and Tires 7 07-26-2021 09:29 PM
2019 Special Edition BRZ, any ideas??? Stephen W. BRZ First-Gen (2012+) — General Topics 126 08-06-2018 05:39 PM
Cb special edition SurfAndSand Scion FR-S / Toyota 86 GT86 General Forum 20 02-14-2015 10:24 AM
2015 CDN BRZ Special Edition.. Skurj CANADA 36 06-20-2014 03:43 PM
Special edition BRZ coming to Canada soon! daiheadjai CANADA 11 03-11-2014 11:28 AM
