Drives: Looking to buy
Valve Spring Recall Affecting Fuel Economy?
Ever since I got my recall work done, I feel like my average mpg went down. Besides the recall, I had them change out the spark plugs and TOB, nothing else. Has anyone else feel their fuel economy taken a slight hit of a few MPG less?
Is this something that needs to be broken in for the mpg to go back up to where it was? Sent from my GM1915 using Tapatalk |
#2 |
The Gunshine State
Drives: '14 BRZ Limited
Are you going by the car computer only or doing your own calculations?
How long has it been since the recall?
![]() Current DD: M235i |
#3 |
If you have done nothing else to the engine and are using stock tune it will take a little while for the computer to re learn.
#4 | |
#5 |
#6 | |
The Gunshine State
I think it's too soon to tell, you've only gone 1 tank since the recall. Keep driving and monitoring.
| The Following 2 Users Say Thank You to 8RZ For This Useful Post: | DarkPira7e (11-06-2019), Exrald (11-09-2019) |
#7 |
Checked my records for the two months before and two months after.
2 months before was 3,836 miles @32.60MPG 2 months after was 3,192 miles @32.64MPG That included changing out the plugs at 136,000 miles for the first time.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#8 |
The weather has got colder since you had the recall done. You will take a small hit in MPG just from that. There should be no impact on MPG from the work they did.
#9 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
When I replaced my battery last spring, the in dash average display went down drastically.
It's finally got back to the pretty solid 33.4 I had before only last month. You're most likely getting the same mileage. The computer takes quite a while to creep back up with that 0 still in the data set.
"I gotta rock." -- Charley Brown |
#10 | |
#12 |
Rust bucket enthusiast
My gas mileage dropped significantly because I started driving the car as if it were new to me - hammering every corner I could find as I had just been re-united with an old friend. Are you certain also that you're not driving differently than before?
| The Following User Says Thank You to DarkPira7e For This Useful Post: | 8RZ (11-06-2019) |
#13 | |
#14 |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
| Not doing the Valve Spring Recall? | arnie0000 | Issues | Warranty | Recalls / TSB | 30 | 08-06-2019 05:24 PM |
| Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-08-2019 11:38 PM |
| BRZ Valve Spring Recall | mrhemi | Issues | Warranty | Recalls / TSB | 6 | 03-01-2019 03:35 PM |
| Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 07:41 PM |
