Old 11-06-2019, 12:17 PM   #1
jc7993
Drives: Looking to buy
Valve Spring Recall Affecting Fuel Economy?
Ever since I got my recall work done, I feel like my average mpg went down. Besides the recall, I had them change out the spark plugs and TOB, nothing else. Has anyone else feel their fuel economy taken a slight hit of a few MPG less?
Is this something that needs to be broken in for the mpg to go back up to where it was?
jc7993 is offline   Reply With Quote
Old 11-06-2019, 12:34 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Are you going by the car computer only or doing your own calculations?
How long has it been since the recall?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 11-06-2019, 12:35 PM   #3
ls1ac
ls1ac's Avatar
If you have done nothing else to the engine and are using stock tune it will take a little while for the computer to re learn.
Old 11-06-2019, 12:36 PM   #4
jc7993
Going by the computer average mpg. I usually keep my eye on the fluctuating mpg while I'm driving and I noticed this change. It has been about 300miles since I got it back.
Old 11-06-2019, 12:37 PM   #5
jc7993
I have a ots tune before the recall. Do you know if they clear the tune as part of the recall?
Old 11-06-2019, 12:37 PM   #6
8RZ
The Gunshine State
8RZ's Avatar
I think it's too soon to tell, you've only gone 1 tank since the recall. Keep driving and monitoring.
Current DD: M235i
The Following 2 Users Say Thank You to 8RZ For This Useful Post:
DarkPira7e (11-06-2019), Exrald (11-09-2019)
Old 11-06-2019, 12:44 PM   #7
Checked my records for the two months before and two months after.
2 months before was 3,836 miles @32.60MPG
2 months after was 3,192 miles @32.64MPG
That included changing out the plugs at 136,000 miles for the first time.
Old 11-06-2019, 12:46 PM   #8
The weather has got colder since you had the recall done. You will take a small hit in MPG just from that. There should be no impact on MPG from the work they did.
Old 11-06-2019, 01:08 PM   #9
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
When I replaced my battery last spring, the in dash average display went down drastically.
It's finally got back to the pretty solid 33.4 I had before only last month.
You're most likely getting the same mileage.
The computer takes quite a while to creep back up with that 0 still in the data set.
Old 11-06-2019, 01:21 PM   #10
jc7993
I did noticed that I had to do the EULA agreement all over again on the head unit when I got it back. Maybe they disconnected the battery for a while doing the recall?
Old 11-06-2019, 01:31 PM   #11
8RZ
The Gunshine State
8RZ's Avatar
You can always reset your MPG data by holding the button down.
Current DD: M235i
Old 11-06-2019, 01:38 PM   #12
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
My gas mileage dropped significantly because I started driving the car as if it were new to me - hammering every corner I could find as I had just been re-united with an old friend. Are you certain also that you're not driving differently than before?
8RZ (11-06-2019)
Old 11-06-2019, 01:59 PM   #13
jc7993
Haha no I was told not to hammer it for the first thousand miles so I kept it under 4k rpm. It's been hard not to....
Old 11-06-2019, 02:00 PM   #14
jc7993
I think I will reset it and see how I fare. Haven't reset since I got it back from the recall.
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Not doing the Valve Spring Recall? arnie0000 Issues | Warranty | Recalls / TSB 30 08-06-2019 06:24 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 04:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
