Old 10-30-2019, 12:55 PM   #113
pslater
Drives: 2017 Golf R
Originally Posted by timurrrr View Post
OZ
Ultraleggera 17x8.0 +40 FIT
first off - thank you so much for compiling this list! it's hugely appreciated.
secondly - are we sure on the +40 offset listed above for the OZ Ultraleggera in 17x8? AFAIK, they only come in +35 and +48 offsets....?
thanks!
peter
pslater is offline   Reply With Quote
The Following User Says Thank You to pslater For This Useful Post:
timurrrr (11-06-2019)
Old 10-30-2019, 01:16 PM   #114
bradyhuutch
bradyhuutch's Avatar
Drives: 2019 WRB BRZ PP
Originally Posted by Dzmitry View Post
Forgot to update as I've had these on for a little over a couple weeks now. But just a final confirmation that these wheels fit very nicely.
Konig Hypergram @ 18x8.5 +38 offset
Tires: General G-MAX AS-05 @ 235/40R18
Total weight of wheel and tire combo came out at about 39.6 lbs.
Clearance is just a little more than the stock PP wheels on the front of the caliper, and much more all around as these are 18's vs 17's.
What are you running suspension-wise? Would this wheel/tire combo rub on either stock suspension or a 1" drop on springs?
bradyhuutch is offline   Reply With Quote
Old 10-30-2019, 01:49 PM   #115
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
You're very welcome!
That's why I've also compiled the list of sources
Originally Posted by mixxxx View Post
OZ Ultraleggera 17x8+40
Plenty of clearance
mixxxx, can you please answer Peter's question?
Old 10-31-2019, 07:53 AM   #116
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
I have no suspension mods yet, the photos show a fully stock setup. I have no rub at all and expect none in the extreme situations, as I did plenty of research before jumping the gun. I plan on going to a 1" drop with Racecomp Yellows in the near future, and also expect no rub. In the case that it may be pushing it close, I plan on getting camber bolts up front anyway to improve clearance, handling, and match up closer to the natural rear camber from a drop.
Dzmitry is offline   Reply With Quote
Old 10-31-2019, 12:07 PM   #117
bradyhuutch
So clearance of the springs themselves is good? It's funny that you say you're planning on getting RCE Yellows.. I'm getting those as well! I also have a WRB PP, will be getting the STi aero bits, and Hypergrams in this size(don't know if bronze or gray yet). I hate to copy your car but I swear mine was an original idea! I just happened to find your car to confirm it looks great, lol. Good thing you're on the East Coast and I'm on the West Coast Thanks for the input on clearance!
Also I'm not sure how close you are to getting the springs, but FT86SF has a package on their website that includes the springs, front SPC camber bolts, and SPC rear lower control arms for $550. It's only about $10 less than buying all the parts separately, but it'll be a much better deal when we get a holiday discount code! The link is below if you want to check it out
https://www.ft86speedfactory.com/ft-...l#.XbsFhZpKiUk
The Following User Says Thank You to bradyhuutch For This Useful Post:
Dzmitry (11-07-2019)
Old 11-03-2019, 03:01 PM   #118
mixxxx
mixxxx's Avatar
thanks!
peter
thanks for confirming. it is indeed the +48, apologies on the typo
mixxxx is offline   Reply With Quote
Old 11-03-2019, 10:39 PM   #119
pslater
Drives: 2017 Golf R
thanks, that helps.
mixxxx (11-06-2019)
Old 11-06-2019, 02:30 AM   #120
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Please correct the offset in this post.
In the meantime, I've updated the top post in this thread — thanks pslater for spotting a mistake!
The Following User Says Thank You to timurrrr For This Useful Post:
mixxxx (11-06-2019)
Old 11-06-2019, 12:33 PM   #121
pslater
Drives: 2017 Golf R
i have a head for numbers, so i tend to spot things like that. it's a blessing and a curse, LOL.
mixxxx (11-06-2019)
Old 11-07-2019, 07:59 AM   #122
Dzmitry
Dzmitry's Avatar
Wow sweet, that's great to know, thanks a lot! I was originally going to just go with the front camber bolts and settle for the natural rear camber unless it was going to be way off. I'll keep an eye on this! And yes, clearance from the spring is great, not dangerously close where you have to question it, it's perfect. Lol, go for it! As even though I also wanted to do my own unique idea, and I feel like I did, there are plenty of peeps with Hypergrams from what I've noticed. It's a fantastic setup that's lightweight for cheap and good quality. Love the bronze look too, and they never look dirty hahaha!
Old 11-16-2019, 03:00 PM   #123
Goingnowherefast
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Can anyone confirm if 18x10 RPF1 ET38 fit over the OEM brembo's
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
Goingnowherefast is offline   Reply With Quote
Old 12-02-2019, 09:56 PM   #124
RippedManiac
Jedi
Drives: Pikachu BRZ
Heres what I got on those Titans
17x8 +48
RippedManiac is offline   Reply With Quote
Old 12-02-2019, 10:11 PM   #125
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
17x8 +48
Nice, wasn't expecting these to have so much clearance!
Looks like there's at least one finger between the caliper and the balancing weights on the inside of the wheel barrel?
That would be
Rota Titan 17x8 +48,
5x100, no spacers, right?
Old 12-03-2019, 07:02 PM   #126
RippedManiac
Jedi
Drives: Pikachu BRZ
That would be
My mistake,
Rota G-Force 17x8 +48
5x100, no spacers.
About 3 credit cards stacked of clearance between the balancing weight tbh.
Pretty tight when I noticed, but i dont see any signs of rubbing.
brz, performance package, wheels
Finding wheels to clear brembos jojosbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 11-13-2018 08:46 AM
Performance package Brembos Ernest72 Want-To-Buy Requests 2 07-14-2018 08:06 AM
Performance Package Brembos Freezing to Wheels? texastwurkt3am Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-23-2018 08:31 AM
What pads fit the Performance Package Brembos? mistople Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 01-03-2018 05:15 PM
