#2115 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
7 years of ownership today.
#2116 |
Drives: Black BRZ
#2117 | |
The car is currently at Atlanta Speed Company to have the leaks addressed. It's just kept me from driving the car a lot since the timing cover leak is very slowly dripping on one of the manifold runners and I noticed the wrap smoking a little bit once the engine is fully warmed up. Not willing to risk anything, and I don't have the time nor the resources (shop equipment) anymore to address it myself. Last edited by ATL BRZ; 10-29-2019 at 02:30 PM. |
#2118 |
Long awaited update.
Been a crazy year with starting a family and now taking care of my newborn son who entered this world at the end of August. The car has been up at Atlanta Speed Company since July occupying their interior storage while we waited for a good time for them to tear into it. Over the last couple weeks, the professionals at ASC took my engine out and fully disassembled it. ![]() ![]() This is what they found. As evidenced below, Mazworx did not assemble and seal my engine correctly. NSFL Warning. ![]() Sealant noodles all up in the oil pickup screen. ![]() ![]() Sealant where it does not belong in the oil passages in both heads. Not pictured: At least one of the Supertech valve seals was not seated correctly and likely causing the smoking on cold starts that I was experiencing. ![]() No sealant where it belongs on the corners of the headgaskets as directed by the service manual. Was sweating oil there too just wasn't enough to drip. ![]() Intake cam sprocket detent plate which fell off upon inspection. This was originally causing slow response codes on the driver's intake bank on my first few drives. I thought it may have been the 40 weight engine oil I had in the sump, so I changed it out for some 20 weight, which made the codes go away once I got the oil good and hot on a summer afternoon. Thought that was the end of it and whatever small blockage was causing the AVCS on that bank to be unresponsive was cleared up. I understand the sprockets rely on a specific oil pressure which is controlled by the OCVs in front of them. I also know that the detent plates on early builds are known to become dislodged from where they are initially pressed in and allow too much oil pressure through them and cause the same family of cam response codes to be triggered. When Mazworx was assembling the engine, I reached out and asked if they could pull the sprockets off an inspect them to ensure the plates were securely in place. They said it was not possible with the cams still in the carriers and they normally just leave them in place when rebuilding these engines. I watched the tech at ASC remove the sprockets from my cams while still in the carriers in about 10 seconds by simply removing the 3 bolts securing them to the ends of the cams. ![]() The sleeves, bores, pistons and rods all appeared to be ok and I had no indication otherwise during the break-in miles I put on the engine. Mazworx did all of the machine work on my original case halves and timing cover to install the sleeves and Reimax high capacity oil pump. That all looked good to us. I emailed Mark Mazurowski, the owner at Mazworx, on 10/11, the day I went to ASC to see all of this for myself and document it. I reached out and explained what we found and shared the photos- asking what could be done about it. He has not responded as of today, over two weeks later. After talking things over with ASC, we agreed that the rotating assembly and short block were likely just fine since the miles on the engine were minimal and all at low RPMs with no boost, so there was minimal risk of bearing damage due to starvation. I'm just glad I took it to them when I did. ASC finished up the reassembly this week with a new full engine gasket and seal kit, new intake cam sprocket, professional surface prep and sealant application that fully adheres to the factory service manual's specification. They also put in all new Supertech valve seals to make sure they were all seated correctly and would not leak as they did previously. ![]() ![]() ![]() While I am very disappointed in the job that Mazworx did with the assembly of my engine and their apparent lack of responsibility for doing it so poorly, I am trying to stay positive and be grateful for the awesome work that Atlanta Speed Company did to get Melanie back in action! FINALLY! ![]() ![]() ![]() ![]() ![]() They definitely treated her right and made sure she was squeaky clean again, and most importantly free of oil leaks and excessive sealant. Driving her home for the first time in a long time was a real pleasure. Still needs some tune tweaks, an oil change or two, and new front rotors before hitting the track again, but I'll get to those items as soon as I can. For now I'm just celebrating having it back in my hands with more confidence than ever. |
#2119 |
Drives: Bone stock
Wow man. Glad you have her back up and running. Your car inspires me. I guess I'll stay away from mazworx for an engine and just find a reputable engine builder locally or iag block.
Sent from my SM-N960U using Tapatalk |
#2120 |
A few nice shots with a good camera from southrnfresh_joe
Still waiting on a new pair of splitter rods after bending them by accident while loading the car on a trailer ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#2121 |
Drives: 2017 BRZ (Sold), 2023 GR86
Bummer to hear about the continued engine problems. Looks like it's in the right hands though.
#2122 |
Had an awesome time last week at The Retrofit Source installing a new pair of Morimoto full LED headlights and a pair of ModPod Mini LED arrays to use as DRLs and turn signals!
![]() ![]() ![]() ![]() ![]() They just edited together a nice little video showcasing the lights! [ame]https://www.youtube.com/watch?v=yUl6HOWl6po[/ame] Haven't been able to do much night driving yet, but so far they have been an awesome upgrade! |
#2123 |
Drives: 2023 BRZ
Good stuff! I've had those headlights sitting in my basement for a couple weeks. I'll have them installed a couple weeks from now. How is the light output compared to OEM HIDs with bulbs that are several years old?
Did you have to do anything to adapt the electronics, or were they plug and play?
Director of Rocky Mountain 86CUP
#2124 | |
#2125 |
I did some night driving over the weekend and thought I'd share my thoughts with you! My first impressions at night were really good! The beam spread is much wider than OEM HIDs, and the output on dark roads was excellent, still superior to stock. I also like how quiet they are when parked. The OEM HIDs made a buzzing noise that wasn't bothersome, but noticeable compared to the silent operation of the LED projectors in the Morimotos.
#2126 |
Drives: '13 LAVA - lightly modded
I think one criticism I've heard of the morimoto lights is that the LED daytime running strip is considerably dimmer and less visible in the day time than the factory boomerangs.
Any word on this? Also, I thought HID had superior output than LED: https://www.ft86club.com/forums/show...&postcount=172 I like the 5yr warranty offered by the Retrofit Source. Definitely be the store I would get them from.
You are going to be condemned to live out the consequences of your taste - TM
#2127 | |
You can see in my install pics that the Morimoto DRL strip is just as bright if not brighter than OEM. HID may have more raw output but the projectors have a lot to do with the amount of light that gets out and the spread of it. The Morimoto Projectors have a more consistent spread than oem and I find their overall performance to be better. |
#2128 |
Recently commissioned some vector art from a friend of mine, and it turned out awesome!
![]() ![]() ![]() ![]() Now I can't decide which one to print and frame! |
| Tags |
| jdl turbo, mazworx, racecomp engineering, track build, verus engineering |
| Wnt3d's 86 - Turbo E85 Daily/Track Build | wnt3d | Member's Car Journals | 77 | 07-17-2017 03:35 PM |
| No Limit Motorsport Full Blown BRZ Build | No Limit Motorsport | Member's Car Journals | 16 | 07-08-2014 12:46 PM |
