Old 10-31-2019, 07:47 PM   #1
chazmuska
chazmuska's Avatar
Drives: 2014 Scion FR-S
Before you think you have bad rocker valves....check this out!
So I purchased a used Borla UEL header from a private party. I should have taken better precautions so that's why I'm posting this to save someone else the ordeal! Basically, I put the header on and thought it sounded fantastic, that is UNTIL I started noticing some loud valve ticking sound coming from my engine every time I accelerated off the line (just normal driving). I was like, wtf, my engine is already going bad with under 50K? I heard about the rocker valve recall and thought I was experience the same issue. So after taking a look under my car I thought it was just a bad gasket initially, changed those out but it still was making that awful ticking sound! Well, as it turned out, the header cracked where the pipe meets the flange! ...and it also looks liked the previous owner tried to file it down further because you can see the grove marks in the pic (as well as the crack).
Do you guys think a welder can fix this or is this header just scrap metal now? Anyone else experience similar issues? I have the stock header on now and the "valve ticking" problem I thought I had is gone...thank god! But now I have to decide what do do with this Borla header!?
chazmuska is offline   Reply With Quote
Old 10-31-2019, 08:02 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
After some media blasting that can be welded no problem. Take it into a welding shop and chalk it up as a learning experience.
Old 10-31-2019, 09:16 PM   #3
chazmuska
chazmuska's Avatar
Originally Posted by solidsnake11 View Post
Ask them to use a tig, to weld it. If they don't have one go somewhere else.
Thanks man, I'll definitely take that as some good advice!
Old 11-01-2019, 12:27 AM   #4
Lantanafrs2
Drives: 2013 frs red
Header leaks can have a metallic sound however if your car was a year older you might actually be losing your motor at under 50k lol
Lantanafrs2 is offline   Reply With Quote
Old 11-01-2019, 02:09 AM   #5
What's a rocker valve?
The Following 5 Users Say Thank You to Ultramaroon For This Useful Post:
fika84 (11-01-2019), JD001 (11-01-2019), mswbrz (11-01-2019), NoHaveMSG (11-01-2019), Tcoat (11-01-2019), YamahaR86 (11-01-2019)
Old 11-01-2019, 03:46 PM   #6
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
You a bish and a hoe and love mocking people . (ᵔᴥᵔ)
mswbrz is offline   Reply With Quote
The Following 3 Users Say Thank You to mswbrz For This Useful Post:
NoHaveMSG (11-01-2019), Tcoat (11-01-2019), Ultramaroon (11-01-2019)
Old 11-01-2019, 03:56 PM   #7
That does not answer the question!
Old 11-01-2019, 04:40 PM   #8
Its code for rocker arm.
Old 11-01-2019, 04:59 PM   #9
Tristor
Tristor's Avatar
FYI, since it's clear people don't know this as well as I thought they did. Borla sucks. They used to be good, but they stopped manufacturing stuff in the US. Pretty much everything they make now is garbage. Stop buying their stuff. This is far from the only Borla UEL header to have cracks or bad welds.
Tristor is offline   Reply With Quote
Old 11-01-2019, 06:15 PM   #10
Grady
Grady's Avatar
As stated above, weld it. Headers crack it is no big deal. Also it not a bad idea to check the flange for flatness when off and fix it. this can be done with a flat file or sand paper on a flat surface.
Old 11-01-2019, 06:35 PM   #11
HaXx
Drives: jrsc_brz
yeah, not the first time ive heard of borla heads cracking. thanks for the heads up OP, valuable, easy fix to a nerve racking valve tick mystery.
HaXx is offline   Reply With Quote
Old 11-01-2019, 09:22 PM   #12
ls1ac
ls1ac's Avatar
It looks like someone who did not know what they were doing thought they would do a little porting. They saw the weld bead around the flange and thought they would clean up the transition. Cut it too thin and it broke away. Every time that cylinder fired it would move and return making the noise.
Easy fix.
Old 11-01-2019, 11:11 PM   #13
chazmuska
chazmuska's Avatar
Easy fix.
Thats exactly what I think happened, or perhaps they had already cracked it and tried to jbweld it or something and then file it down thinking they were doing a port job. Just an FYI, I did drive it hard sometimes and it took about 2 years until it started making the valve ticking sound (yes its a Rocker Arm not rocker valve...I don't know what I was thinking at the time lol )
The Following User Says Thank You to chazmuska For This Useful Post:
bcj (11-02-2019)
How clean are the valves? radroach Engine, Exhaust, Transmission 12 10-01-2020 02:40 PM
Brz Oil Control Valves Ichima Engine, Exhaust, Transmission 4 05-31-2019 10:48 AM
exhaust valves? aznatama Engine, Exhaust, Transmission 16 09-14-2014 10:39 PM
Clamps and Check Valves for FI sw20kosh Forced Induction 1 12-17-2013 07:32 PM
