Old 10-31-2019, 03:56 AM   #15
Flunoir
Drives: stanced
Originally Posted by EAGLE5 View Post
Check the fuses. I think there's even one on the positive battery cable.
So because my obd2 wasn’t working I wanted to first check the fuse for it and turns out, it’s all good! Which fuses should I check next? If the fuse for my obd2 is fine, then why isn’t it working? Tomorrow morning a repair shop is going to give me a diagnostic over the phone supposedly but I’ll see what happens. This is my first car and this is my first time dealing with an issue like this. My parking lights don’t work and when I press on the brake pedal the tail lights don’t work either. Yet, when I lock or unlock my car the tail lights and parking lights flash like normal! I am trying to get this resolved ASAP because I need my car and my windows are rolled halfway down and won’t go up after this incident posing a big risk to my car because it is parked in the driveway. I have been covering my cat though so I haven’t worried too much but still, I need my car back.
Flunoir is offline   Reply With Quote
Old 10-31-2019, 06:23 AM   #16
milanojess
milanojess's Avatar
Drives: 2013 FRS
2013 Scion FR-S Died While Driving
Check OBDII power ( forgot which pins, search how to check OBDII power)
Then look for fuse to ECU
Check for all ground points in engine bay. Clean them with contact cleaners or deOxit
2013 FRS - JRSC CARB
"Use all of the track" they say
milanojess is offline   Reply With Quote
Old 10-31-2019, 07:28 AM   #17
Flunoir
Drives: stanced
Thank you for your response! I’m looking into having my car looked at professionally since I don’t want to mess anything up on my own and have a bigger problem to face!
Old 10-31-2019, 09:37 AM   #18
Go right back to basics. Check to ensure that the cables clamped to the battery are clean and tight. The battery could show as good but if full power isn't getting out of it then you would have all those symptoms.
Oh, and is the car stock or modified?
JesseG (10-31-2019)
Old 10-31-2019, 09:56 AM   #19
jflogerzi
jflogerzi's Avatar
Smells like a ground wire or battery connector is loose or needs to be clean
2013 Series 10 FRS #553
Old 10-31-2019, 10:28 AM   #20
p1l0t
p1l0t's Avatar
I think the car has to be at least in the ON position for OBD-II to work. Not running but at least ON not Accessory. Not sure if you have key or keyless.
Old 10-31-2019, 11:17 AM   #21
When you had your car's battery tested, was it in the car or did you take it out and take it to a shop? Did they do a "load test" on the battery?
Tcoat (10-31-2019)
Old 10-31-2019, 11:46 AM   #22
Flunoir
Drives: stanced
Omg it’s you! When I’m on the forums I see you everywhere so for you to be on this thread makes me happy! Haha, anyways, the cables are clean and tight and the car is completely stock other than a muffler delete.
Old 10-31-2019, 11:47 AM   #23
Flunoir
Drives: stanced
Ground wire????
Old 10-31-2019, 11:47 AM   #24
Flunoir
Drives: stanced
I tried that! And it still didn’t work!
Old 10-31-2019, 11:51 AM   #25
Flunoir
Drives: stanced
What’s up man? I took the battery out had them test it. My car is parked at my house and I don’t want to have it towed back and forth places. I’m not sure what you mean by a “load” test, but they did check the voltage and said that the battery was normal. Here’s the thing, I seen a video online where a guy with an FR-S couldn’t start his car and it wouldn’t make any noises at startup and all he did was replace the battery and it worked! I still think the battery might be the culprit in some way.
Old 10-31-2019, 11:55 AM   #26
No work done recently? Next step check the big ground cable that is bolted on the bell housing on the passenger side of the car. Can't seem to find a picture right now.
The battery should be load tested. It may have enough voltage to look fine but not enough amperage to run everything or turn it over.
Old 10-31-2019, 11:59 AM   #27
Flunoir
Drives: stanced
I did have a custom reverse light installed but that was a couple of weeks ago and I also had a friend of mine try to tune my car but he said it didn’t work but I don’t know what he did to my ecu or if he messed anything up on accident.
Old 10-31-2019, 12:11 PM   #28
Ohhhhhh. Well not to scare you but that opens up a whole new range of possibilities. When messing with ECUs anything can happen. Best get it in to somebody that can actually see what is going on.
2013 FRS Engine Died Jamesallen45 Issues | Warranty | Recalls / TSB 24 05-31-2018 04:30 PM
Beatrush Catless Equal Length Exhaust Manifold Subaru BRZ 2013-2015 / Scion FR-S 2013 RallySport Direct Engine, Exhaust, Bolt-Ons 21 06-03-2015 02:21 PM
Takeda Intake System; Stage 2 Wrinkle Black; PRO 5R; Scion FR-S 2013 H4-2.0L TM-2013 AMPLIFIED MOTORSPORT Engine, Exhaust, Bolt-Ons 16 10-03-2012 08:03 PM
2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast Zgrinch Scion FR-S / Toyota 86 GT86 General Forum 124 02-21-2012 02:43 AM
