| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: GR86 Trueno Edition
Is it normal that the coolant gets low in time?
Hi,
I have a 2019 limited and 14000 miles. Last month I just checked some of the liquids and realized that the coolant level was at min (cold). After driving from Boston to NY the level gets close to max (is normal when the car is heated) Today I checked before turning on (cold) and the level was way below the min. I did drive just 5 miles and it was just close to min. It’s scares me but never had this in my previous cars. I always check the ground for any leaks (coolant oil etc) and never saw a leak. This car has been used only for my weekly Boston - NY trips and has the 14K miles. Never pushed the car and regularly drive 60-70 MPH. I wonder if the decrease of the coolant is normal. I had my 6K and 12K Checks at the Subaru dealer and they also did not mention anything regarding this. I can get the oem Subaru coolant and put a little in. Just wanted to ask if there is anything to worry about. If topping it, should I add it on a heated (and after how long driving) car? Thanks Sent from my iPhone using Tapatalk |
#2 |
Drives: 2016 Halo FRS
Would a large temperature differential between the two data points (where you observed cold coolant levels) be great enough to account for the thermal expansion?
| The Following User Says Thank You to jordan7831 For This Useful Post: | Busybee (10-29-2019) |
#3 |
Drives: 2017 toyota 86
I keep mine Just at / slightly under the full line when cold. Over time you do slowly lose some although it should not be much unless you have a leak, also if you had it checked on a hot summer day, and are now checking it and its 40 degrees colder that could also drop it a few inches down the reservoir line.
Just top it off and check it a few times before your next couple drives to see if its dropping at all. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | Busybee (10-29-2019) |
#4 |
It should never be at the full line when cold. It is an expansion tank for when it gets hot and if full when cold there is no place for it to expand to.
The coolant is a mix of water and antifreeze. The water will slowly evaporate over time and needs to be replaced periodically. If you can not see or smell it then you have no issue. Just replace the water (distilled) and carry on.
#5 | |
Thanks. That’s what I did in the previous cars. Putting distilled water from time to time. I already got the oem Subaru coolant. Do you think If I add the coolant it will be ok? Or should I just replace the evaporated water. Sent from my iPhone using Tapatalk |
#6 | |
"The coolant level is satisfactory if it is between the “F” and “L” lines on the reservoir when the engine is cold. If the level is on or below the “L” line, add coolant up to the “F” line. (→P. 465)" So it is satisfactory to be in between the F and L lines, but when filling it up it says to fill to the F line. The reservoir has plenty of expansion space beyond the F line, if you are expanding the fluid beyond that capacity then you have other issues to worry about, like air in the system, leaks in the system, or overheating. Although as previously stated colder weather can make it read "artificially" low, i would fill right at or just under F line at about 70 degrees, or fill about 1/3" lower per 10 degree drop but never below the L. Or just warm coolant up to 70s and top it up to just at or under F. |
| The Following 5 Users Say Thank You to 86TOYO2k17 For This Useful Post: | johnowow (02-23-2023), Spuds (10-30-2019), Stomachbuzz (11-30-2019), Tcoat (10-29-2019), Tokay444 (10-29-2019) |
#7 |
Just replace the water. Keep the coolant for when it needs to be changed.
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (10-30-2019) |
#8 | |
#9 |
Senior gif poster
Drives: 2013 Asphalt FRS
Both the dealer and I have by mistake overfilled my coolant a few times and everything seemed to be okay, never leaked or anything. I also have never in my 6 years of ownership added distilled water. I just top it off with 50/50 toyota stuff, around 100k I do expect to do a flush. I originally planned on getting the super awesome jackson dual radiator/oil cooler, but due to other financial strains I can no longer afford that radiator
![]() On a side note, does anyone know if the J02 recall involves replacing the coolant? I don't think it does but seems worth asking. |
#10 | |
However coolant has additives to both increase boiling point, decrease freezing point, and prevent corrosion. Its also pretty cheap and infrequently replaced. Lots of places to save money. Personally a coolant isn’t a place I choose. |
#11 |
Appreciate all the information in a such short time. Thanks
#12 |
Senior gif poster
Right, which is why I have been using the Toyota 50/50 stuff. Been using the same jug for a long time, bought it years ago and still use it to this day. Not very expensive considering how infrequently I have to top it off and how long its lasted.
#13 | |
The Dictater
Drives: '13 Red Scion FRS
| The Following User Says Thank You to Spuds For This Useful Post: | DandoX (10-30-2019) |
#14 | |
The Dictater
| The Following User Says Thank You to Spuds For This Useful Post: | humfrz (10-30-2019) |
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 09:21 PM |
| Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install | The Sentinel | Engine, Exhaust, Transmission | 92 | 03-09-2015 06:20 PM |
| first time running Slick tires... Pedal dance or normal 5sec trac off? | dejxx | Tracking / Autocross / HPDE / Drifting | 6 | 11-16-2014 05:07 PM |
| Normal Engine Coolant Temps? | Dezoris | Engine, Exhaust, Transmission | 1 | 04-05-2013 04:17 PM |
