Old 09-12-2019, 01:47 PM   #701
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Originally Posted by Sgtfluffy16 View Post
Sgtfluffy16
I definitely don't have that plate. I can't say tho. I got mine used.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline
Old 09-19-2019, 01:48 AM   #702
jflogerzi
jflogerzi's Avatar
Anyone running the Front Sport Kit with Stock Rears. Thoughts on Pad combo's. I got the BP20's which I hope was not mistake based on what I am reading in this thread. Rears I am looking for a good pair... maybe W3's or Hawk Plus or EBC Yellows
2013 Series 10 FRS #553
jflogerzi is offline
The Following User Says Thank You to jflogerzi For This Useful Post:
PearlAozora (09-19-2019)
Old 09-19-2019, 06:55 AM   #703
PearlAozora
PearlAozora's Avatar
Drives: 2015 Subaru BRZ Aozora Edition
Try a hawk performance + pad in the rear. They work amazingly with my stage 2 front.
As for the bp20 pad, I could ask for a little more bite, but they’re cheap options that last a good while on an extremely demanding brake track (my home track). I’ve never had brake fade issues and they lasted way longer than stock caliber pads that cost 3-4 times as much
PearlAozora is offline
The Following User Says Thank You to PearlAozora For This Useful Post:
jflogerzi (09-19-2019)
Old 09-19-2019, 10:10 AM   #704
DarkSunrise
DarkSunrise's Avatar
BP20's up front are not bad on the track, especially given how cheap they are. Not a huge amount of bite and a little squishy, but no issues with fade (on a stage 2 kit, at least). Seems relatively easy on the rotors. Be prepared for plenty of squeal and dust on the street.
For the rear pad, I'm using XP10's. No problems there. I've always liked that pad on this car though.
2022 BRZ Build
2013 FR-S Build
DarkSunrise is offline
Old 09-19-2019, 10:10 AM   #705
jflogerzi
jflogerzi's Avatar
I am gonna give ebc yellows a try as I got a deal
Old 09-20-2019, 10:06 AM   #706
maregt
Drives: Subaru BRZ
I've used DS2500, EBC Yellow and again DS2500 on DBA plain rotor. The EBC were inferior performance wise but absolutely quiet
Inviato dal mio LG-M320 utilizzando Tapatalk
maregt is offline
The Following User Says Thank You to maregt For This Useful Post:
jflogerzi (09-20-2019)
Old 10-16-2019, 05:35 AM   #707
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Coupon code PLEASE 🙂
Carlitoz3 is offline
Old 10-26-2019, 12:37 AM   #708
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
You think all EBCs would be quiet? Low speed squeal is my biggest woe with the BP10’s or 20’s or whatever I bought with these. I’m considering getting the rotors spun then getting EBC Red for street driving.
I have the Stage 2 up front and the sports in the rear. I don’t even know if EBC has sizes for those or where to buy them.
Irace86.2.0 is offline
Old 10-26-2019, 12:49 AM   #709
DarkSunrise
Have you tried Polymatrix Q? It's a Wilwood pad designed for minimal noise/dust. I think I'm going to give them a try.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
Irace86.2.0 (10-26-2019)
Old 10-26-2019, 08:08 AM   #710
PearlAozora
Has anyone noticed more wear on the front drivers side pads compared to passenger side?
Through 2 sets of pads me, and another 86 driver have both noticed it with our stage 2 kits running BP20. Not sure if it’s a track, pad, or calliper issue.
Old 10-26-2019, 12:53 PM   #711
Irace86.2.0
I haven’t tried anything else. From what I’ve read, everything squeals that is semi-metallic, which is why I was either going to switch to organic “normal” pads or go ceramic like the EBC Red Stuff, but these seem to be ceramic too, so I’ll look into them.
I did have a lot of noise coming from my brakes. I ended up buying brand new rotors and a set of Gloc gs1
And all brake noises have gone away. Either there's something embedded in your pad that's causing the noise or there's something on your rotors. I actually do track days with my car and I remove the rotor and the brake pad and put on a completely different set of rotors and brake pads when I am on the track. Now obviously my race brake pads are unGodly noisy and I'm fine with that. But those brake pads are only on for the track.
They were squealing at low speeds under light-medium braking from day one. This seems to be universal, and it makes coming to a stop in traffic unbearable. Light braking or firm/heavy braking seems to be fine, especially at high speeds.
You know, I like this idea. I’m aware that people will swap pads for track days, but that always seemed odd to me because the surfaces wouldn’t align or seat well, right? But in your case, they are a matching set.
I’ll look into doing that.
Old 10-27-2019, 11:56 AM   #712
DarkSunrise
I just ordered the Polymatrix Q pads. I'll post a review here to let you know if these solved my low-speed squeal issue. Will also be putting Stoptech SP or OEM pads on the rear as well, so hoping this combination will be completely quiet for street use.
2022 BRZ Build
2013 FR-S Build
Irace86.2.0 (10-27-2019)
Old 10-27-2019, 01:00 PM   #713
Irace86.2.0
It is kind of frustrating to read reviews online. Some people say the BP10’s I have squeal, while others have the 10’s or even the 20’s and say their squeal is gone compared to their old pads. I don’t know if these are short term reviews or long term.
Where did you buy your pads? I don’t know where to buy or what size to get these for my setup, but I’ll look forward to your review.
I also didn’t find rotor upgrades on RR Racing’s website. I thought the steel rotors could be upgraded to two piece rotors, but the one piece rotors listed seem to be cheaper than the replacement discs for the two piece, which seems odd.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
PearlAozora (10-27-2019)
Old 10-27-2019, 01:02 PM   #714
PearlAozora
Two piece rotors are significantly lighter. You’ll pay more for that minimal unsprung weight.
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 04:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 11:31 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
