Old 10-22-2019, 02:27 AM   #1863
Takumidesh
Takumidesh's Avatar
Drives: 2013 FR-S, 2015 TC
https://datazap.me/u/takumidesh/1022...x=55.85&hg=1-9
Hello all. I am trying to learn more about the internal workings of tuning and what all the numbers mean.
this is a pull from a 'launch' all the way through 3rd gear. I am just wondering if there is anything that should be jumping out at me.
basically, if someone is bored and wants to take a look at this log and help me understand it a bit better, I would very much appreciate it.
2013 FR-S Basically Disassembled in the garage.
2015 TC BONE STOCK BABY
KANSAI DORIFTO
Takumidesh is offline   Reply With Quote
Old 10-22-2019, 06:57 AM   #1864
steve99
Drives: FT86
Everything looks ok
Iam 1
Very small amount of knock in lower rpm area
Only thing wrong is its running way to rich for e85 its running low 11 afr should be low to mid 12
Most likely due to perrin intake
Takumidesh (10-23-2019)
Old 10-22-2019, 03:29 PM   #1865
Takumidesh
Takumidesh's Avatar
Everything looks ok
Iam 1
Thanks! I've heard that you shouldn't mess with maf scaling when running the e85 tune due to the way fuel trims are calculated. Do you think I would be better off going back to the factory intake? I know the Perrin intake doesn't do much, but I like the look and how it cleans up the engine bay (delete the sound tube and all that).
Edit: to add, do you think the knock may be from the launch control?
Sent from my Moto Z3 Play using Tapatalk
KANSAI DORIFTO
Old 10-22-2019, 06:47 PM   #1866
steve99
Drives: FT86
I can rescale you maf for a small charge message me if interested.
Knock wont be from launch , it only minor couls jist take out a little timing in that area
As long as ethanol content is stavle you can scale maf on e85
Old 10-22-2019, 07:49 PM   #1867
Xinnie
Xinnie's Avatar
Drives: 2015 FR-S, 1997 328iS
https://datazap.me/u/xinnie/car-bogs...&data=30-33-34
This is a log where I'm inputting light throttle to 3.5k.
Is this normal? My car has really low long term fuel trims. Can it indicate an exhaust leak?
https://datazap.me/u/xinnie/cruise-l...zoom=4804-7149
This is a cruise log. Constant low long term fuel trim.
Xinnie is offline   Reply With Quote
Old 10-23-2019, 02:38 AM   #1868
steve99
Drives: FT86
High positive ltft usually indicates leak
Old 10-23-2019, 03:49 AM   #1869
Xinnie
Xinnie's Avatar
What about high negative?
Old 10-23-2019, 04:45 AM   #1870
tomm.brz
Drives: brz 2017 hksv2
High negative could be a vacuum leak near the throttle or anywhere near intake manifold
tomm.brz is online now   Reply With Quote
Old 10-27-2019, 01:29 AM   #1871
Carlos.z
Drives: Limited brz
im having a bit of an issue with the car, its a 2013 at brz tunned by james at hri for exhaust and uel header. car is super sluggish until around 3.5k rpm, throttle feels numb i step on the cars and takes for ever to gain any speed.
car ran ok for a while so i thought it was bad gas since i left it sitting for 2 mo while on vacation plus it spent 2 weeks at the dealer for the recall soon after returning, but ive gone thru a few tanks now and even re-flashed the latest tune provided but nothing as changed.
sent a log to hri and said it lookd fine and that nothing changes by its own,
this is just log from the drive home tonight. if anyone sees something odd and could shed some light it'll be amazing,
https://datazap.me/u/21carlos/log-15...?log=0&data=22
Carlos.z is offline   Reply With Quote
Old 10-27-2019, 03:07 AM   #1872
Boomerang
86
Boomerang's Avatar
Your IAM is sitting on 0? Should be 1
Wrong def?
Old 10-27-2019, 04:34 AM   #1873
Xinnie
Xinnie's Avatar
https://datazap.me/u/xinnie/check-lo...a=3-4-30-33-34
3rd gear pull 1500rpm to 5000rpm
jackson racing supercharger
does this look normal? I feel like its not getting enough boost and stft and ltft looks weird.
Old 10-27-2019, 06:15 AM   #1874
tomm.brz
You re floosing your engine with fuel and the air supposed to enter, doesn t arrive
Check for intake leaks, you re probably blowing away your intake charge
Old 10-28-2019, 09:19 PM   #1875
Carlos.z
Drives: Limited brz
Wrong def?
Thanks for your reply since I've been reading about AIM and watching it closely on the ecutek app. It hardly ever went ove 0.70 I filled up at shell and now it sit below .20
Do I have sht tune or really shitty gas around the city?
Old 10-29-2019, 06:51 AM   #1876
Boomerang
86
Boomerang's Avatar
If your IAM is really that low you have major knock and the engine is pulling timing.
You may have a bad or incorrect(E85?) tune or you have bad gas or running too low octane fuel for the tune.
Either way 0.2 IAM aint good, 1 is great and 0.7 is stock
Your logs look different, were they taken at different times as IAM is different?
On one log your LTFT is positive on cruising indicating adding more fuel/lean so maybe an intake leak near your throttle body? Check the hoses and clamps around there..
You could take it back to the tuner or send the log with the low IAM
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
