Old 10-22-2019, 10:09 AM   #1
jslack
Drives: 2017 Red subaru BRZ Limited
right size injectors for Jackson Supercharger and E85
Hello group. I'm sure the answer might be buried here somewhere, but hope y'all might be able to answer it quickly.
I want to upgrade to the Jackson Supercharger next year and run my E85 still. So I wanted to know what size injectors would be suitable for this application along with the fuel pump. I already got a C65 DW fuel pump and hope that will be sufficient. Any other suggestions for fuel upgrades would also be great. Thanks.
jslack is offline   Reply With Quote
Old 10-22-2019, 10:56 AM   #2
Grady
Grady's Avatar
700cc injectors.
Old 10-22-2019, 11:37 AM   #3
kev0
Drives: '14
Yup. 700cc injectors will be perfect for around 280whp.
kev0 is offline   Reply With Quote
Old 10-22-2019, 01:24 PM   #4
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
DW 700cc is what I have for my Harrop with E85 at 12psi.
Old 10-22-2019, 06:04 PM   #5
J1Avs
Drives: 2018 BRZ tS
I use DW 700CC Injectors — I’ve heard negative feedback on the DW 65C Fuel Pump though, most everyone recommends the 300C. I run the stock Fuel Pump on my JRSC w/ E85 without issue, but that was at my tuner’s preference.
J1Avs is offline   Reply With Quote
Old 10-23-2019, 10:57 AM   #6
Irace86.2.0
I run the DW300c too. Good insurance even if it may not be necessary.
Old 10-24-2019, 03:57 AM   #7
CSG Mike
CSG Mike's Avatar
700CC is fine.
Dump that 65C and get a 300C.
PM to order.
Old 10-24-2019, 12:13 PM   #8
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
700CC is fine.
PM to order.
curious on your thoughts on the 65c pump vs. the 300c. I've had this pump for almost 4 years. is the 300c a replacement to the 65c? only asking since i had no idea there was another option.
pgranberg11 is offline   Reply With Quote
Old 10-24-2019, 12:57 PM   #9
CSG Mike
CSG Mike's Avatar
Slightly different form factors, and the 300C has more capacity. The 65C has a tendency to overheat.
pgranberg11 (10-24-2019)
Old 10-24-2019, 01:15 PM   #10
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
which method did you use, 4 orings? or spacer with 1 oring? thanks!
Old 10-24-2019, 01:19 PM   #11
CSG Mike
CSG Mike's Avatar
4 o-rings.
Jackson Racing Supercharger kit c38 Minidude147 Engine, Exhaust, Bolt-Ons 6 06-14-2019 11:19 AM
WTB: Jackson Racing Supercharger Chris3007 Want-To-Buy Requests 2 08-06-2018 11:11 AM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Wtb: Jackson racing supercharger Yosty Want-To-Buy Requests 3 07-29-2015 09:31 AM
Jackson Racing SC - exhaust piping size ndsleep612 Forced Induction 9 08-11-2014 07:39 PM
