Old 09-20-2019, 05:07 PM   #1
kyle116
Drives: 2015 Scion FR-S
My experience with an AliExpress Backup Camera (License Plate Light style)
I wasnt able to find many people posting about this specific style of backup camera so I thought I give some info. Its the License Plate Light Backup Camera from AliExpress or other Chinese company product. I bought it to avoid drilling any holes into the car even if its the just the trunk garnish piece.
This what the camera looks like (not my car, from aliexpress):
Link for the camera I purchased:
https://www.aliexpress.com/item/32831516871.html
For the price of the camera($20), I am very pleased with the quality. One downside of this camera, there small LEDs on them and due to the stock head unit requiring the camera to always be on, the lights on the camera stay on even when driving. Haven't thought of the best solution yet other than covering with black electrical tape.
I paid for the install as I could not quite figure out the wiring of this compared to other OEM tutorials. I am happy to try and answer any questions you have though.
Heres a short video I made displaying the camera quality, how it looks, how the camera lights look when car is on, and camera in reverse being used during daytime, night time, and in a parking garage:
kyle116 is offline   Reply With Quote
Old 10-04-2019, 11:55 PM   #2
greencounty
greencounty's Avatar
The camera doesn't always need to be on. The installer told you that because they didn't want to run a relay from the headunit to turn the camera on when the stock radio tells it to turn on.
The radio sends a 6v signal that will only turn on when the camera needs to be on. If you power the camera from that signal (or use a relay to send 12v when that 6v signal is on) then it will only be on when the car first starts and when you're in reverse.
Garage:
2013 BRZ Limited 6MT - Galaxy Blue
1994 Ford Probe GT 5MT - Red(some would argue pink)
1969 Mustang Fastback 4MT - Royal Maroon
greencounty is offline   Reply With Quote
Old 10-05-2019, 05:25 PM   #3
ir1064
Drives: 6MT, C7P
i've have exact same set up as yours, and i tap the 12V from reverse triggering wire and it has enough voltage to power the camera when i put my gear on reverse, running couple years now, knock on wood!!!
ir1064 is offline   Reply With Quote
Old 10-11-2019, 05:08 PM   #4
greencounty
Connecting it to the reverse signal shouldn't work. I'm guessing that you connected to the 6v signal that the headunit provides for turn-on.
The Fujitsu Ten headunit does a check when you first turn the car on to detect if a camera is connected. The camera must be turned on to pass this check. The camera won't be on when you first turn the car on if you tap into the reverse signal at the tail light (unless you always start the car when shifted into reverse).
Garage:
Old 10-18-2019, 11:32 PM   #5
kyle116
Ahh I see, well thanks for that info. I'll look into installing a relay
Old 10-23-2019, 05:55 AM   #6
KeshaFlansburg
Drives: BMW
It's a low cost one. I always prefer to get a rearview camera with complete system kit. I never bought any auto product from AliExpress but if you want a suggestion then I would Alpine HCE-C1100 if you want to cover dynamic range.
KeshaFlansburg is offline   Reply With Quote
aliexpress, backup camera, reverse camera
Backup Camera input/recommendations for 2014 Monogram without factory Backup Camera RedLeaderD4S Electronics | Audio | NAV | Infotainment 3 08-04-2017 09:32 PM
My experience installing a backup camera ARTBRZ Electronics | Audio | NAV | Infotainment 0 03-19-2015 09:37 AM
Back up camera integrated with license plate light brianlo622 Electronics | Audio | NAV | Infotainment 10 05-26-2014 10:04 PM
FR-S and BRZ PTUNING License Plate Relocation kit/Go-Pro Camera Mount/Tow hook kit Patrick@Ptuning Cosmetic Modification (Interior/Exterior/Lighting) 4 10-01-2013 12:43 PM
Beatsonic license plate mounted backup camera? normancw Electronics | Audio | NAV | Infotainment 3 01-28-2013 06:08 PM
