Old 10-22-2019, 10:54 AM   #21337
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Originally Posted by jflogerzi View Post
New tires, oil change and washed the inside of the rims. Went from 225 to 245's
Hypergrams!
MCTeeJ is offline   Reply With Quote
The Following User Says Thank You to MCTeeJ For This Useful Post:
jflogerzi (10-22-2019)
Old 10-22-2019, 02:16 PM   #21338
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Our Series-10 look great with dark rims. Nice offset!
MJones_RB is offline   Reply With Quote
Old 10-22-2019, 02:21 PM   #21339
jflogerzi
jflogerzi's Avatar
Yup agree. 40 in the back and 37 up front( added 3mm spacer to give extra clearance for BBK.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
MJones_RB (10-25-2019)
Old 10-26-2019, 09:56 PM   #21340
arxm
Drives: 2013 FR-S, 2023 BRZ
do you have a tune?
Mufflers and cats don't create scavenging. I'm assuming you have a tune for full exhaust, so without further details I'd say your exhaust diameter is too large or something else is wrong. Or your seat Dyno is no longer calibrated properly
sorry it took so long to get back to you guys, I didnt go ahead with a tune because I was planning on saving up for when I boost as I would need to re tune then anyway, however ill probably be putting my muffler back on till spring since nobody in my neighborhood wants to hear me cold start and let the car warm up Ive been looking into ecutek vs oft and heard when boosting that the ecutek is a better option but for na to switch between tunes easily the oft is better am I correct with that understanding?
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 10-26-2019, 11:51 PM   #21341
Ashikabi
Ashikabi's Avatar
Oh... Well that explains it. Your car doesn't know what to do with the improved flow. If you need to switch tunes then OFT will be superior. ECUtek can switch tunes easily too but you need to possess all the maps to switch between, which could be costly. The OFT can also be resold for a large portion of what you pay new so you won't lose much money switching away from it. I've always heard ECUtek is better for boost too.
The Following 2 Users Say Thank You to Ashikabi For This Useful Post:
arxm (10-27-2019), Ultramaroon (10-27-2019)
Old 10-27-2019, 02:45 PM   #21342
arxm
I see, I guess ill just wait in that case, dont want the hassle of switching or compromising
Old 10-27-2019, 03:15 PM   #21343
Ashikabi
Ashikabi's Avatar
That's how I did it. Then LS swapped before I could boost so I lost my ECUtek license. If I'd had OFT then I wouldn't have lost all my investment. It's a less than perfect situation either way
The Following User Says Thank You to Ashikabi For This Useful Post:
arxm (10-28-2019)
Old 11-04-2019, 07:59 PM   #21344
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Tossed the winter wheels on and installed rokbloks mudflaps. I'm ready for the white stuff.
Edit
The Following User Says Thank You to RToyo86 For This Useful Post:
Myriad (11-05-2019)
Old 11-04-2019, 08:03 PM   #21345
MJones_RB
MJones_RB's Avatar
Installed my fancy Receseng Cam Plate. When I pried the stock one off, the sealant didn't look as bad as some of the other posts I've seen. Is this a case of "if it ain't broke...?"
The Following User Says Thank You to MJones_RB For This Useful Post:
JesseG (11-05-2019)
Old 11-04-2019, 11:31 PM   #21346
Terran
Terran's Avatar
Drives: Raven FR-S 6MT
Got Volk ZE40's 18x9.5 +43 in Diamond Dark Gunmetal wrapped in 255/35/18 Pilot Sport 4S
Terran is offline   Reply With Quote
The Following 6 Users Say Thank You to Terran For This Useful Post:
eMCee (11-17-2019), humfrz (11-05-2019), JesseG (11-05-2019), Leonardo (11-05-2019), MCTeeJ (11-06-2019), RToyo86 (11-05-2019)
Old 11-05-2019, 12:14 AM   #21347
Ya reckon -
MJones_RB (11-05-2019)
Old 11-05-2019, 12:15 AM   #21348
Good looking wheels -
Terran (11-05-2019)
Old 11-05-2019, 01:35 PM   #21349
Jordanwolf
Rice King
Jordanwolf's Avatar
Originally Posted by beltax90 View Post
mm?
Millimeters?
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 11-05-2019, 01:41 PM   #21350
Originally Posted by Jordanwolf View Post
Millimeters?
Plain or peanut?
