Old 10-19-2019, 10:59 PM   #15
Lantanafrs2
Drives: 2013 frs red
Originally Posted by morswestford View Post
why not? well what do you think i should do then? i need my key fob reprogrammed. this is kind of important.
I would flash stock tune and have it transported. I've never heard of running a supercharger with a stock flash. Maybe someone else can chime in here?
Lantanafrs2 is offline   Reply With Quote
Old 10-19-2019, 11:41 PM   #16
morswestford
morswestford's Avatar
Drives: 2013 Subaru BRZ
what if i drove to dealership with my labtop. flashed it to stock there. have them re-program it. then i can flash it back to my tune. i think that may work.
i mean how bad could the car drive using the default with a supercharger anyways? it would still be drivable at least right?
morswestford is offline   Reply With Quote
Old 10-20-2019, 01:00 AM   #17
Lantanafrs2
I doubt it. Especially if you're running larger injectors. Your idea of flashing stock tune at dealership sounds pretty good imo
Old 10-20-2019, 01:07 AM   #18
soundman98
ProCrastinationConsultant
soundman98's Avatar
right until the car starts throwing misfire codes while they pull it into the service bay, and the tech attempts to go ahead and fix those codes...
just be honest with them about it, let them know what you're doing, and how the car will not be driveable while they program the key.
Old 10-20-2019, 02:10 AM   #19
morswestford
no, i dont have larger injectors. i have an automatic. supercharger, flex fuel kit.
custom exhaust system. thats it. i think it may even be drivable on lower RPMs. im not really sure. the tune came from Moto East. But that was three years ago. Should i email and find out? Are they in business still, does anyone know?
Old 10-20-2019, 02:13 AM   #20
morswestford
i know right, i need to make sure i communicate it clearly to them to not move the vehicle once the tune is back to default.
Old 10-20-2019, 02:24 AM   #21
Lantanafrs2
Contact xero limits. That's motoeasts new name. They'll be able to help you.
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
chaoskaze (10-28-2019)
Old 10-20-2019, 06:52 AM   #22
cjd
cjd's Avatar
Drives: 2017 BRZ
Unless you can get it at zero boost... It'll run lean. Probably. Check with your tuner maybe.
Old 10-20-2019, 05:22 PM   #23
morswestford
ok thanks i just did
Old 10-20-2019, 05:22 PM   #24
morswestford
i will, thank you
Old 10-25-2019, 01:18 PM   #25
ROFL it's Waffle
The guy w/o an FRS or BRZ
ROFL it's Waffle's Avatar
Drives: '23 GR86 Premium 6MT Halo White
Idk if that's a good idea with the supercharger
Driving it with a stock tune is what I'd be worried about more. Stock tune should be fine just to start up and let idle, just to get an OBDII reading.
ROFL it's Waffle is offline   Reply With Quote
Old 10-27-2019, 06:21 AM   #26
morswestford
I talked to Mike over at Moto-East (now Xero-Limit) because he was the one who did my tuning. He couldn't give me any explanation why the dealership can't communicate with the ECU. Nobody can.
But he said what I need to do is just replace my 3 bar MAP sensor with my stock sensor, then re-flash the tune to stock, and do this at the dealership so they can gingerly drive it to the service bay, do the work. then i can put back in my 3 bar map sensor, then re-flash it back to my tune.
Crazy right? Absolutely nuts I need to do all that just for them to fix my check engine light and also re-program my key-fob.
Old 10-27-2019, 03:43 PM   #27
ls1ac
ls1ac's Avatar
Back to really simple. Had a friend that my "good" reader would not work, but the cheep one would. It seems that the connecter in the car is not great. I used an extender cord with the good reader and all worked well.
Just a thought.
Old 10-27-2019, 04:56 PM   #28
Decep
Drives: 2013 FR-S Series 10
That does sound like quite a mess. I'd try an indie locksmith, i had one copy my current key to an aftermarket key (obviously doesnt help your AC issues)
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
brz, ecu
Tuners like "Mugen" or "Spoon" for Subaru? Seiryuu BRZ First-Gen (2012+) — General Topics 21 09-08-2018 03:33 PM
dealership thats willing to fix timing cover leak for "heavily modified" brz iarefluffy Southern California 14 12-28-2017 11:53 PM
Will the dealership "ECU Flash" be reset to factory after disconnecting battery? spatcha88 Engine, Exhaust, Transmission 5 04-02-2015 02:35 AM
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
Collection of "Subaru axing BRZ" & "Subaru making next-gen BRZ" rumor threads... mav1178 Other Vehicles & General Automotive Discussions 42 07-07-2014 03:52 PM
