Old 10-16-2019, 04:23 AM   #43
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by timurrrr View Post
I believe you can use OEM lug nuts:
https://titan-7.com/pages/f-a-q
"All TITAN 7 Wheels work only with 60 Degree Cone seat lug nut / bolt (Unless otherwise noted)."
https://www.ft86club.com/forums/show...374#post501374
"Yeah, OEM Subaru = 60degree conical seat."
However, I'd also be very curious to hear recommendations of what aftermarket lug nuts to get.
The tire shop used has managed to scratch a few of my lug nuts while installing the wheels, so I'm thinking about replacing them, and I've figured getting new OEM lug nuts is kind of lame.
Having looked closer at my lug nuts, it seems like despite having the right seat shape, the OEM lug nuts should not be used with these wheels.
Here is a close-up of one of my lug nuts:
It appears that at some point closer to the wider part of the conical seat in the wheel the OEM lug nuts are a bit too wide, so they started chipping (or is it the finish that's chipping?). Also, probably the hex part of the lug nut doesn't extend much, and you can easily damage the finish of the wheel with the socket. I see similar issues around other lug nuts, although not quite as bad.
Seems like spline-style lugs is the way to go.
It's disappointing that the shop I went to didn't catch that, despite me specifically asking them if my lug nuts are ok for these wheels.
Also, I didn't get a good advice on that when I reached out to Titan 7 directly weeks prior to installation.
Old 10-16-2019, 07:31 PM   #44
Jdmuscle
Drives: Supra, Viper, Z06, GT350 and GX460
I see.. Titan suggested I use aftermarket lugs as well.
IG: @vipraz 94 Supra Turbo // 15 Viper GT // 16 Corvette Z06 // 18 Shelby GT350 // 19 BRZ LTD // 18 GX460 Premium // 13 Vrod Muscle
Jdmuscle is offline   Reply With Quote
Old 10-18-2019, 04:15 PM   #45
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Just installed Muteki 41885C Chrome 12mm x 1.25mm Closed End Spline Drive Lug Nuts - these look and sit much better!
On the photo with the stock lug nut you can see scratches from the socket -- I presume the lug nug was sitting so deep that the socket could only cover half of the length of the hex section. Yuck!
The Following 2 Users Say Thank You to timurrrr For This Useful Post:
Clipdat (08-13-2022), soundman98 (10-19-2019)
Old 10-23-2019, 01:54 PM   #46
Jdmuscle
Here is my car with T-S5 wheels...
The Following 2 Users Say Thank You to Jdmuscle For This Useful Post:
Clipdat (08-13-2022), jflogerzi (10-23-2019)
Old 10-23-2019, 06:13 PM   #47
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Another data point:
I've put my 17x9 T-S5s with new 245/40R17 GT Radial SX2 and OEM TPMS sensors on my bathroom scales and measured 43.8 lbs.
For comparison the OEM PP wheels with medium-worn Michelin Primacy HP (stock) tires and no TPMS on the same scaled and measured 39.6 lbs.
So looks like at the end of the day a combo of 17x9 with 245/40 is still heavier than OEM PP wheels + OEM tires.
Old 10-23-2019, 06:26 PM   #48
jflogerzi
jflogerzi's Avatar
Another data point:
. Way more grip and better looking wheels
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Old 10-24-2019, 10:11 PM   #49
doug1234
doug1234's Avatar
Drives: 2017 BRZ w/pp
CSG Spec TEIN Flex A
The car looks great. I'm interested in the setup. I have the 2017 BRZ w/pp and the CSG Flex A coilovers. I'm currently running -2.5 chamber in front and -2.0 rear with the recommended height? About 1.3 lower than stock. Do you think the wheel and tire setup will fit?
Sent from my Pixel 2 XL using Tapatalk
doug1234 is offline   Reply With Quote
Old 10-24-2019, 10:19 PM   #50
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Yeah I think so. The reason why I'm higher than recommended is because I want a little more daily driveability
FTR, I recently went to a Car Control Clinic and noticed that when my car spins out of a drift the front tire does rub against the fender a bit, even though I'm maxed out on front camber. You may want to keep that in mind wrt your lower ride height.
Note that I've dropped 3 turns of the front coilovers (6mm?) since the last time I took photos, so I was at ~31mm drop from factory at that CCC.
Old 10-26-2019, 01:44 PM   #51
doug1234
doug1234's Avatar
Thanks for the info. Still on the fence.
Old 11-13-2019, 05:01 AM   #52
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Absolutely love these wheels!
Now that they're track-proven, I've decided to share some more photos:
The Following 3 Users Say Thank You to timurrrr For This Useful Post:
Clipdat (08-13-2022), Goingnowherefast (11-13-2019), J1Avs (11-13-2019)
Old 11-13-2019, 02:10 PM   #53
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Another data point:
Sounds more like your particular combo is awful heavy. If your wheels come in at 15.8 lbs, then you have a 28 lb tire. There are a lot of tires that way MUCH less than this in that size. In fact, MOST tires of that size way much less than this, which comes to my surprise as to why these are so heavy? Maybe the performance in them stands out that much more? I would be surprised.
Dzmitry is offline   Reply With Quote
Old 11-13-2019, 03:18 PM   #54
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Now that you've mentioned -- yes, SX2s spec weight in that size is 26.2 lbs [1].
Still not clear where the extra 1.8 lbs come from; I don't think TPMS + center caps + balancing weights + dust and dirt would account for that.
Perhaps just an imprecision of my kitchen scales when used on an uneven pavement of my garage (I did try multiple locations though)...
Here's a quick table of weight SX2s vs Primacy HP in different sizes:
Code:
Size      | SX2      | PHP      | Difference
215/45R17 | 23.0 lbs | 20.8 lbs | 2.2 lbs
245/40R17 | 26.2 lbs | 22.5 lbs | 3.7 lbs
So yeah, apparently SX2s are so heavy that inertia-wise they outweigh the benefit of lightweight wheels. Still much faster laptimes though.
Perhaps when I'm ready for RE71Rs I can get well below 40 lbs for the wheel+tire combo :P
I couldn't easily find the weight of the OEM PP wheels without tires, but it used to be known to be ~22 lbs.
The Following User Says Thank You to timurrrr For This Useful Post:
Dzmitry (11-14-2019)
Old 11-13-2019, 03:28 PM   #55
Icecreamtruk
Drives: Track preped NA FRS
RE71R and yokos A052 are crazy light and have crazy grip. Be prepared to get a lot less durability out of them tho, probably 3 to 4 times less than the SX2.
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Old 11-13-2019, 03:58 PM   #56
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Yup, I'm aware of the increased wear Thanks!
New wheels - Rota Titan 17x9 justinco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 04-18-2017 01:30 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 02:50 PM
TWS T66-F Forged wheels on a Black FR-S Touge Factory Wheels and Tires 17 08-21-2014 12:53 PM
Forged Wheels for 86 Astra^EC AFRICA 5 09-24-2013 07:32 AM
AG.Function Forged Wheels Eric@GetYourWheels Wheels and Tires 22 08-01-2012 12:16 PM
