Old 10-18-2019, 12:01 AM   #1
jflogerzi
jflogerzi's Avatar
CSG Tein Flex A vs RCE superstreet 1's
Looking to replace my stock dampers and RCE yellow combo for something a little more geared for track and auto X while still retaining OEM or better ride quality. They are nearly the same price. Paring it with 245/40/17 SX2's and RR street BBK on the front. Just looking for thoughts from owners.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
Qadthane (10-26-2019)
Old 11-07-2019, 02:18 PM   #2
indlinx
Drives: 2018 BRZ Sportech RS
sames
i was wondering about this as well. looking for a mainly street coilover that has better ride than the PP sachs. the new 949 xidas also fits the bill but out of my budget. so its down to these 2.
indlinx is offline   Reply With Quote
The Following User Says Thank You to indlinx For This Useful Post:
jflogerzi (11-07-2019)
Old 11-07-2019, 04:47 PM   #3
86league
Drives: '13 BRZ Limited
No experience with the Flex A's - but I did swap from RCE yellows/Stock dampers to the SS1 coilovers and am pretty happy with the SS1 performance. The Flex A's have the same spring rate, the damping is probably somewhat different.
Let me split my observations into 2 parts. Impact harshness and then response to "lower" frequency undulations.
I'd say the SS1s are better than stock in impact harshness over sharp bumps when the shocks are dialed back to a street setting.
With about 2x the stock spring rate however (fronts at least), you will notice the difference in ride. In a lot of ways it's good : handling in general, less body roll, etc -- but it does have some drawbacks for particular road surface/speed combinations. If memory serves the spring stiffness effect was a little more noticeable from Yellows to SS1's than from stock to yellows, but you get the better damping at the same time that helps things out.
"ride quality" seems to mean something different to everyone. The performance benefits are there and in general the ride is not worse than stock - just somewhat different - at least to me.
Hopefully that helps.
86league is offline   Reply With Quote
The Following 6 Users Say Thank You to 86league For This Useful Post:
Griever423 (07-14-2020), jflogerzi (11-07-2019), Racecomp Engineering (11-07-2019), RL_BRZ (12-26-2020), why? (07-28-2020), wparsons (09-09-2020)
Old 11-08-2019, 01:53 PM   #4
indlinx
another interesting option thats in the same price bracket is HKS GT IV 20spec and spec-A.
20spec is 5K/5K
spec-A is 6K/6K but has more front stroke
both were designed to be more comfortable street daily coils.
coilover shopping is a real headache
The Following 3 Users Say Thank You to indlinx For This Useful Post:
Griever423 (07-14-2020), jflogerzi (11-08-2019), RL_BRZ (12-26-2020)
Old 07-13-2020, 07:42 PM   #5
Colin86
Drives: 86
@jflogerzi -OP what did you buy one of these and are you happy with your decision?
Any other feedback on csg fla vs ss1? Am interested in a street coilover that can function for HPDE's and these two options are currently at the top of my list.
Thanks in advance!
Colin86 is offline   Reply With Quote
Old 07-14-2020, 06:09 PM   #6
We're working on adding (as an option) rear lowering mounts to our kits btw. Tons of travel as is but front lowering camber plates and rear lowering mounts for even more compression travel at lower ride heights is extra nice.
No ETA yet, working on logistical details.
We've been really happy with our SS1 kits! Just an awesome all around performer that's a lot of fun. A true road & track suspension at a great price. I've been on stock shocks for rallycross reasons this year and I miss my SS1s a lot. My girlfriend does too, which was unexpected (she is very much not a car person). The SS1s were better on the crap streets of Baltimore that I live on. They have more compression travel than stock at recommended ride heights and of course the valving is better. As mentioned above, the softer springs of OEM have advantages in some instances, but overall ride is IMO better than stock.
- Andrew
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
kevaughan (10-04-2022), tehShirt (07-16-2020), why? (07-28-2020), wparsons (09-09-2020)
Old 07-16-2020, 01:47 AM   #7
jflogerzi
jflogerzi's Avatar
Thanks in advance!
sadly still have not added suspension changes yet... These 2 sets are on my radar.
Old 07-16-2020, 11:16 AM   #8
Milhouse86
Noob
Milhouse86's Avatar
Drives: 13' FRS, 13' F150, 17' A4, 69' 442
I ended up going RCE. They have a really great reputation and seem willing to give advice assistance to dial in your set up.
My experience is still very limited as I blew up my motor at a track weekend the day after my new suspension came in
So mine is still new in box sadly
Sent from my Pixel 4 XL using Tapatalk
-2013 FRS/Black (Motor Blown/Under Construction)
http://www.ft86club.com/forums/showthread.php?t=135599
-1979 Trans AM/Black (Sold) -1969 Olds 442/Orange with white racing stripes - 2017 Audi A4/Black
Milhouse86 is offline   Reply With Quote
Old 07-17-2020, 10:44 PM   #9
Decep
Drives: 2013 FR-S Series 10
My SS1s have been good for the ~10k miles i've put on them. Run them about an inch lower and keep them at the softer street setting RCE suggests in the instructions. Everyday lil bumps are probably better than stock, big dips/impacts at freeway speeds are definitely worse than stock. Don't expect miracles for ride quality when you double your spring rate
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following 2 Users Say Thank You to Decep For This Useful Post:
Racecomp Engineering (07-18-2020), wparsons (09-09-2020)
Old 07-18-2020, 02:55 AM   #10
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Sounds like your discomfort was from hitting the bump stops.
If that's the case, you were likely either too low*, or actually needed a higher spring rate.
I believe SS1s don't have separate damper body length adjustability, so incorrectly set bump travel can't be the reason.
Another possibility is that your rebound settings were too high for the street.
* — from the perspective of "given the spring rates, the suspension didn't have enough travel to absorb enough energy too hit bump stops".
Old 07-18-2020, 08:54 AM   #11
Yeah approx double the spring rate of stock isn't going to be perfectly smooth ride quality 100% of the time! But I've swapped between stock and SS1 a lot over the past year and I miss the SS1s a lot when they're not on the car for just basic around town driving in Baltimore city. It's different...better in some ways and for me overall better.
Tuning just for the really big bumps would make some compromises elsewhere! (especially with a mid-level coilover system).
- Andrew
Old 07-18-2020, 03:35 PM   #12
Decep
It's not discomfort really, its just a fact that on the highways near me, they put these big dips in the road at certain points and if you're going 70 or 80 mph your butt is going to launch out of the seat for a second. I've hit bump stops before and this aint it.
RCE SS-1 Coilovers
Corsa Catback
The Following 4 Users Say Thank You to Decep For This Useful Post:
CSG Mike (07-21-2020), Griever423 (07-21-2020), Racecomp Engineering (07-18-2020), wparsons (09-09-2020)
Old 07-28-2020, 02:18 AM   #13
jflogerzi
jflogerzi's Avatar
I think I am going to give the CSG Tien's a chance. Website says in stock in October so just in time for when I get a nice bonus as work.
CSG Mike (07-30-2020)
Old 09-08-2020, 11:48 PM   #14
jflogerzi
jflogerzi's Avatar
Bumping this thread. As we get close to October I am still on the fence... Between these 2. Would love some first hand accounts. Vendor support is both good and price is the same. Guessi g you can't go wrong with either...
Tein flex a or flex z coilovers? Phuviano Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-17-2019 04:37 PM
Tein Flex A vs Flex Z VOSS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 04-18-2019 05:38 PM
Tein Flex A DeaconRoc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 138 04-12-2018 05:23 AM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 09:33 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
