Old 07-19-2012, 08:59 PM   #1
deedz
Drives: Rocket Bunny FR-S
Manual grinding sound
Hey guys,
Im new to manual cars and I recently just learned to drive. Im not great at it and i still occasionally stall but something that has bothered me
Was that when i slow down for a stop
Light i put it in neutral, then as i am still moving at say 15 mph with the clutch still in after putting neutral, i move it to
First with the clutch still down to get read for a green light at a stop, when doing this i hear a grinding
Sound right before it fully enters 1st gear and i feel it in the stick everytime maybe even other gears.
Anyone know if this is normal?
deedz is offline   Reply With Quote
Old 07-19-2012, 09:05 PM   #2
denverizzles
are you pushing the clutch pedal all the way down? are you jiggling the shifter while your in neutral?
denverizzles is offline   Reply With Quote
Old 07-19-2012, 09:07 PM   #3
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
Stop putting the car in first gear at 15 MPH. You're going to destroy your synchros. Only engage first when stopped or barely moving.
Subie is offline   Reply With Quote
Old 07-19-2012, 09:16 PM   #4
deedz
My friend said i may not be pressing ALL the way down
Im not downshifting to first though, im in neutral while the clutch is sill down breaking for a stop light and right before while the clutch is still in, i move it To first to prepare to go from a stop when the light turns green
Old 07-19-2012, 09:18 PM   #5
Subie
Señor Member
Subie's Avatar
That sounds exactly like downshifting into first to me. When the clutch is depressed the input shaft and engine are disconnected, but the output shaft is still connected to the wheels. Whenever you move the gearstick into first you're changing gears, whether or not the clutch is engaged.
Old 07-19-2012, 09:31 PM   #6
MiguelAE86
Drives: NB Miata
so wait, by that logic: whenever you shift with the input shaft and output shaft engaged to their perspective ends, you're still grinding the gears
MiguelAE86 is offline   Reply With Quote
Old 07-19-2012, 09:31 PM   #7
Subie
Señor Member
Subie's Avatar
Yes, if the input shaft speed doesn't match the output shaft speed.
Old 07-19-2012, 09:33 PM   #8
Suffa
Drives: Black GTS
Yeah i agree, dont get into 1st unless your not moving.
Suffa is offline   Reply With Quote
Old 07-19-2012, 09:37 PM   #9
denverizzles
1st gear should ONLY be used at a complete stop. DO NOT ever down shift in to first...fastest way to screw shit up
Old 07-19-2012, 09:51 PM   #10
MiguelAE86
Drives: NB Miata
Ah, heel-and-toe required?
Old 07-19-2012, 09:55 PM   #11
Subie
Señor Member
Subie's Avatar
No; you'd have to rev-match perfectly while in neutral to downshift (i.e. push the gearstick out of gear without using the clutch, rev-match, push the gearstick into the next gear), and time upshifts perfectly so that the input shaft speed would slow down to the right speed to match the output shaft as you engage the the next gear. It requires a lot of precision. I've personally never tried clutchless shifting.
Old 07-19-2012, 10:01 PM   #12
deedz
so how would I go about doing this in my situation in the best way without messing my car up?
Old 07-19-2012, 10:04 PM   #13
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
When you stop downshifting to first while still moving...
I'll be back!!
F3dzo is offline   Reply With Quote
Old 07-19-2012, 10:06 PM   #14
Neekowahhhh
Enthusiast
Neekowahhhh's Avatar
Drives: Crystal Black BRZ Limited
Use your brakes when you get under 15.. Those are way cheaper to replace..
Instagram: Neekowahhhh
Mishimoto Air Induction Hose;K&N High Flow Air Filter;Berk Tech Catless Front Pipe;Invidia N1 Catback Exhaust TT;Matte Bronze XXR 527 17x8.25 ET 25
Neekowahhhh is offline   Reply With Quote
notchy/gritty transmission. every gear grinding prest1ge Engine, Exhaust, Transmission 41 12-09-2012 06:45 PM
Sound tube mod? smbrm Engine, Exhaust, Transmission 25 06-20-2012 07:24 PM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 11:33 AM
Southeast sound OFF! OldSkoolToys Southeast 133 05-25-2012 12:31 AM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 01:33 AM
