Old 10-13-2019, 11:43 AM   #5139
peaches
Drives: '14 BRZ Limited
Thanks for the info guys! While I was looking at how to spray the pulley without hitting the header I noticed the belt was aligned properly at the top but not at the bottom, it was 1 rib off on the fluid damper and the water pump. After aligning it properly the noise went away. Nice easy fix.
peaches is offline   Reply With Quote
The Following 2 Users Say Thank You to peaches For This Useful Post:
CSG Mike (10-13-2019), new2subaru (10-13-2019)
Old 10-13-2019, 12:24 PM   #5140
mrg666
pessimistic skeptic
mrg666's Avatar
My engine starts to do rough idling in extended stop and go traffic. I am thinking that this is because the effectiveness of intercooler starts to decrease when the car is not moving. And engine starts to take warmer air from the compressor. And, the recirculation valve is making this effect worse by recirculating the hot compressed air. Has anybody tested using blow-off valve instead of recirculating?
Old 10-13-2019, 03:00 PM   #5141
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
I'm putting my car back to stock for the recall and im having trouble reprograming my ecu back to stock. i cant seem to find my stock rom
Bones36 is offline   Reply With Quote
Old 10-13-2019, 03:49 PM   #5142
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
I don't think Jackson racing gives a stock rom becuse I was wondering how I would do that myself if i ever went back to stock for some reason , I'll have to follow the responses
mswbrz is offline   Reply With Quote
Old 10-13-2019, 06:08 PM   #5143
CSG Mike
CSG Mike's Avatar
Originally Posted by peaches View Post
Welcome to another edition of, What the fuck is that noise!!
I've had the JRSC on for 4 months, no issues so far. Started doing this 2 days ago right after start up, the noise goes away after the car warms up, but even after it cools down the rest of the day it doesn't do it. Kinda sounds like the cricket chirp but louder. However, unlike the cricket chirp is does it while it moves. Car drives fine, anybody knows what is causing it?
Sounds like a dirty or offset belt. Check your belt for alignment, and also use some conditioner!
*edit* looks like you found the problem!
Old 10-13-2019, 06:09 PM   #5144
CSG Mike
CSG Mike's Avatar
The MAF sensor measures temperature, and the CARB tune compensates for the hotter air when not moving!
Get me a log please.
As a quick check, use some MAF cleaner on your MAF.
mrg666 (10-14-2019), sroby (10-13-2019)
Old 10-13-2019, 06:10 PM   #5145
CSG Mike
CSG Mike's Avatar
A complete library of stock ROMs are included with the Ecutek kit you got. Use that to flash back to stock, and then when you go back to boost, flash your CARB tune back on!
Old 10-13-2019, 09:07 PM   #5146
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
figured out why i was getting an error code, battery needed charging
The Following User Says Thank You to Bones36 For This Useful Post:
sroby (10-13-2019)
Old 10-17-2019, 11:21 AM   #5147
ReDestructDead
Drives: White 2018 BRZ
Howdy everyone. I have a 2018 car with a C30 kit on it, JR dual rad/oil cooler and catch cans. I tried to do some searching and have been lurking for quite a while but I wasn't able to find anything specifically on this topic. How does the 2017+ revised engine perform under the stress of an E85 tune on the stock pulley C30? Has anyone blown a 2017 motor yet? I understand that the rods were not revised in this iteration of the design, but I'm still curious to hear what knowledge people have on the subject.
I'm likely going to be installing a flex fuel kit and a new pump/injectors as well and it seems that some people have had trouble with the DW pumps, so I plan on staying away from them. Is the Walbro pump coupled with 660cc FIC injectors a more suitable approach in terms of avoiding pump/injector reliability issues? Is a new pump 100% necessary with this size injector on ethanol blends?
ReDestructDead is offline   Reply With Quote
Old 10-17-2019, 12:48 PM   #5148
peaches
If the rods were not revised (stronger or weaker) then it's shouldn't be a problem, as long as you have a good tune from CSG or DT. I have a DW pump and haven't had any issues with it, in my experience a lot of the problems are caused by a bad install, being cheap, or cutting corners. If you're doing flex fuel and larger injectors, then yes the upgraded pump is required.
Old 10-17-2019, 01:09 PM   #5149
J1Avs
Drives: 2018 BRZ tS
I’m running a 2018 tS with JRSC C30 and and Ptuning Flex Fuel. DW 700CC injectors. Stock Fuel Pump.
Everyone recommended the fuel pump, and I even went to the extent of purchasing it. My tuner very much disagreed, and so I’m running the stock fuel pump with absolutely zero issue. They do not even recommend an upgraded fuel pump running their turbo kit with their flex fuel kit which can easily crest 400whp.
But that’s a tuner’s preference. If your tuner wants it, go for it, if they prefer to not use it, then I think you have your answer on that end.
Best bet, communicate with your tuner ahead of the purchase.
I’m sit back and wait for the flames now insisting that my car can’t possibly run right without a new fuel pump
J1Avs is offline   Reply With Quote
Old 10-17-2019, 01:15 PM   #5150
peaches
I wouldn't say you're lying or that it's not possible, but with the high demand from E-85 I wouldn't feel comfortable running a stock pump. I rather spend the money to run an upgraded one regardless of what the tuner says. If you're comfortable with that, more power to you.
The Following User Says Thank You to peaches For This Useful Post:
CSG Mike (10-17-2019)
Old 10-17-2019, 01:16 PM   #5151
mswbrz
mswbrz's Avatar
Where are the stock roms located on the ecutek bro ?
Old 10-17-2019, 01:51 PM   #5152
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
In the Ecutek Folder on your computer.
JDMChris is offline   Reply With Quote
The Following User Says Thank You to JDMChris For This Useful Post:
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
