Old 10-15-2019, 12:29 AM   #1
HKSBRZ14
Drives: 14' BRZ supercharged
Window only goes 1/2 way down
I have a 2014 BRZ and my passenger window works but stops about half way down. I have tried the “reset” several different ways with no luck. Does anyone have similar experience with their window not going down all the way. Need help!!
HKSBRZ14 is offline   Reply With Quote
Old 10-15-2019, 03:21 AM   #2
I haven't had this problem but if your fuses are good, the switch is working properly and the reset procedure doesn't straighten it out, I reckon you will have to pull the door apart and see what jamming it up.
humfrz is online now   Reply With Quote
soundman98 (10-16-2019)
Old 10-16-2019, 11:42 PM   #3
soundman98
ProCrastinationConsultant
soundman98's Avatar
you didn't just replace the speakers did you?!? i recall there being very limited clearance for different speakers.
Old 10-17-2019, 12:16 AM   #4
HKSBRZ14
Nope, stock speakers... Also the car isn’t driven much. It’s parked in the garage, one day it just stopped rolling down all the way. The auto up and down function still works and it closes all the way at the top.
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 03:14 PM
Drivers window grabbing window seal and pushing it up. stockysnail Issues | Warranty | Recalls / TSB 22 12-22-2015 02:08 PM
Window Visor and Frozen Window TSB tinma Cosmetic Modification (Interior/Exterior/Lighting) 9 05-19-2015 02:51 AM
Window Scratched by Window Motor / Lifter? tomkozski Issues | Warranty | Recalls / TSB 22 05-31-2014 08:25 AM
squeaky window due to window rubbing against rubber at the top tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-10-2013 06:34 AM
