| Engine Swaps Discussion of engine swaps. |
Drives: LS3 Dry Sump BRZ
LS3 BRZ cooling
So I finally took part in my first drift event, and couldnt be happier with the swap. The throttle response, is amazing, the power is amazing, car feels great. Will put up a vid in the monring to show you some footage.
The problem I am having is keeping the car cool enough for 2 laps. Drifting one lap and the coolant temp is already at 230f. Looking for ideas that you guys have done to resolve this issue. I am running the biggest possible radiator that would fit on the car. Not sure what else to do. 0 problems with oil temp as Im running a dry sump. |
#2 |
Drives: 2017 toyota 86
The main problems with heat drifting particularly implements are.
Generally lower speeds = less airflow Being sideways = less airflow Constant high revs = high temps. Best measures to counter these problems in addition to what you've done would be. Hood vents/louvres to help reduce engine bay temps. Upgraded fans as the limited airflow coming in the front when drifting wont suffice. Running 1 or 2 additional radiators in tandem behind each side fog light with dedicated fans for those. Blocking off areas to channel and focus all incoming airflow directly to radiator Using WMI to keep engine/combustion temps and IAT down could potentially help slow and delay coolant temps. Upgrade radiator hoses to thicker more insulated ones to prevent or delay heatsoak might help a little as well. |
#3 | |
I don’t have additional radiators on each side or in tandem. Do you know anyone who has done that previously? Would love to learn more. Also have upgraded hoses already .Can you please explain what you mean by WMI? This will be a real problem with this car. Very eager to find a solution. |
#4 |
As promised, here is my first test video, please excuse the quality as it was taken from my phone. The car following me is a modified Evo 6. |
#5 |
Drives: 86, 981S, RX8, 2500HD, GenesisV8
How many cores is your radiator? You need a SPAL or equivalent fan, not Derale.
I ran an LS with a rear radiator with NO airflow aside from the fan and never had a temperature problem. Mine was a 4 core radiator, SPAL fan, Hypertech 180 Thermostat, Stock Water Pump |
#6 | |
WMI = water methanol injection, will keep combustion and intake temps down quite a bit. Everything eventually heat soaks, so lowering any temp should help overall temps at least a little. The other option as was mentioned is relocating radiator to the trunk, then you can get a massive radiator, multiple fans have a complete custom setup that should really resolve all your issues. This may be the best solution since you have already implemented so many other things with no luck. |
#7 | |
#8 |
I don't remember the radiator, I bought it at a swap meet. It was a 4 core Griffin and I think a single 18" fan.
https://www.summitracing.com/parts/s...2049/overview/ What is your temperature before you go on track? If you are out there for 30-60 seconds, it should not hit 230, these motors tend not to run that hot in my experiences. I never have seen mine get over 215 and I have flogged mine savagely for 4-5 minutes hill killing. What is your A/F ratio at those rpms? Are you using underdrive crank pulley? What is your thermostat? I don't suggest rear mounted, it is a lot of work. Mine was done due to space restrictions. |
#9 | |
My mechanic also told me that he is not happy with the durale and he suspects this to be the problem. What is the difference between the durale and the spal you sent me? Here is a link to the one I currently have. https://www.summitracing.com/parts/der-16821 |
#10 |
Ok 180 is correct, I am concerned with how quick it is getting up to temp.
The Spal is just a superior fan in both quality and output. For your fan, are you using the 2 speed feature? How much of the radiator is covered by the fan? |
#11 |
The whole radiator is covered by the shroud. I dont think we are using the second speed. I need to see as the ECU doesnt have the option for the second speed. Not sure if we running the fast speed or the slow speed.
#12 | |
I Love custom Turbo kits
Drives: Limited BRZ
This was not enough for me. I needed to replace both of the slim fans provided (900 CFM Spals) with 1328 CFM spals (these are not super slim, as the motor sticks back a bit). With these fans I have not had any more cooling issues. My thermostat is also a LFE 160 degree. As a disclaimer, I did not take it to the drift track, but at low speeds and high FL heat, I had not overheating issues. Of course I know your use produces way more heat, but at least some ideas you can try to tackle heat. @Dustin put his radiator at an angle pulling heat away from the radiator but also not into the engine and his setup has also been great against the heat. It also allowed him to keep the stock fans which pull a lot of heat.
#13 |
We trying a few things. My fan is 2400 cfm and was set on the low speed at 1700 Cfm. So we increasing that to the high speed. We are also adding guides on each side to get more air while drifting.
I will revert back as soon as it's done, probably in the coming 2-3 days. |
| The Following 3 Users Say Thank You to Shahano For This Useful Post: |
| Seat cooling | Chimera | Electronics | Audio | NAV | Infotainment | 9 | 08-03-2023 12:29 PM |
| Oil Cooling - An In-Depth Look | VerusEric | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 115 | 02-20-2023 10:54 PM |
| All your cooling needs | Evasive Motorsports | Groupbuys | 46 | 07-10-2017 05:47 PM |
| brakes and cooling | DRACHENV6 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 08-11-2013 10:34 AM |
