Old 10-03-2019, 10:06 AM   #8695
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by break View Post
Has anyone got any example dyno charts of this kit running without aftermarket headers, and one with?
I don't have headers - but do have a cat back system. I'm trying to understand what's a typical power increase when adding headers to a supercharged car.
Sent from my Pixel 3a using Tapatalk
Don’t think many people cared to take to the time do that test, so might not be available.
But headers typically stack on top of SC, the gains a header makes NA should be similar gains with SC.
Old 10-04-2019, 08:35 AM   #8696
kev0
Drives: '14
WTH is the screw size for the oil dipstick? I’m pissed that the manual doesn’t state this..
kev0 is offline   Reply With Quote
Old 10-04-2019, 08:43 AM   #8697
ptschmidt77
Drives: 2014 BRZ Limited
Pretty sure it's 5mm.
ptschmidt77 is offline   Reply With Quote
The Following User Says Thank You to ptschmidt77 For This Useful Post:
kev0 (10-08-2019)
Old 10-11-2019, 01:30 PM   #8698
Regular
Drives: 2017 BRZ
Hey guys, I got my kit a couple months ago and I'm just wondering if you we can run the 69mm pulley w/o upgrading any internals, injectors or fuel pump?
As well, just wondering if anyone has any experience with a water meth injection kit? Specifically, where did you mist it into the system?
Regular guy... Not so regular car
Regular is offline   Reply With Quote
Old 10-11-2019, 01:50 PM   #8699
86TOYO2k17
Lots of people including myself are using 69mm pulley on stock block no problem. But obviously more power and boost = more risk. Its possible but not advise-able to run the 69mm on anything less then 93octane. Octane booster, E85, or WMI will resolve that.
WMI you can either NPT tap the sprintex intake pipe or just get a TB spacer with a NPT port already in it. I did the TB spacer myself.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Regular (10-11-2019)
Old 10-11-2019, 01:55 PM   #8700
Regular
Drives: 2017 BRZ
Thanks for the info! I'm currently from Canada and running Ultra 94 Oct from Petro. I'm assuming that should be sufficient.
In regards to the WMI, would you inject before the SC but after the TB?
Old 10-11-2019, 03:19 PM   #8701
86TOYO2k17
Yes, TB spacer is post TB pre blower. Or you can do pre TB by tapping the sprintex intake tube.
Most WMI nozzles have a check valve now days but, i also recommend a snow performance solenoid this will guarantee WM doesn’t leak while parked on a hill or idle/under vacuum only when you want it to spray. Also recommended to get a wmi failsafe and also wmi filter in between reservoir and pump.
Regular (10-12-2019)
Old 10-13-2019, 03:34 PM   #8702
jflogerzi
jflogerzi's Avatar
Can someone post a part number for the belt needed on the 69mm pulley
2013 Series 10 FRS #553
Old 10-15-2019, 10:04 PM   #8703
Regular
Drives: 2017 BRZ
Following
Old 10-15-2019, 11:33 PM   #8704
toast
Drives: 14 BSP Edelbrock BRZ
I think Canadian 94 octane is only equal to what we would call 90...
toast is offline   Reply With Quote
Old 10-23-2019, 10:37 AM   #8705
brybot
Drives: 13 DGM BRZ 6MT
210 IC kit still for sale, $850. Can ship.
Images: https://imgur.com/a/eINB5wv
brybot is offline   Reply With Quote
Old 10-24-2019, 11:04 PM   #8706
Regular
Drives: 2017 BRZ
So i just bought a 69mm pulley for my kit. I heard around that i should probably get a different belt and idler pulley. Can someone confirm for me? And if it’s so, which pulley and belt do y’all recommend?
The Following User Says Thank You to Regular For This Useful Post:
jflogerzi (10-25-2019)
Old 11-03-2019, 12:53 AM   #8707
jflogerzi
jflogerzi's Avatar
Bump wondering the same.
Old 11-03-2019, 01:31 AM   #8708
86TOYO2k17
Most people recommend nuline ep121, i used ep141 for a while. I switched to Dorman 419-610 Idler Pulley for 8$ on amazon has worked perfectly. With larger idler pulley you can use the standard belt the kit comes with.
Regular (11-18-2019)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
