Old 09-30-2019, 09:38 AM   #43
8inchAzN
Drives: Car
Originally Posted by qcbaker View Post
Description for the WS80 on TireRack.
To be fair, this doesn't explicitly say that the remaining 40% of tread is only as good as an all season, it only says that it isn't the multicell compound.
From my understanding, the WS50 line was winter on top of all seasons. The WS60+ changed that. I know the WS80 has the top layer as the Multicell compound and the bottom is the original Winter tire compound. The Multicell compound is at the wear bar after my first season.
8inchAzN is offline   Reply With Quote
Old 09-30-2019, 10:07 AM   #44
qcbaker
Shitpost Generator v8.6
qcbaker's Avatar
That doesn't sounds unreasonable, but do you have a source from Bridgestone that confirms that? Dont want to be spreading misinformation.
qcbaker is offline   Reply With Quote
Old 09-30-2019, 10:33 AM   #45
TunaNoCrust
TunaNoCrust's Avatar
Drives: 86, 981S, RX8, 2500HD, GenesisV8
This thread has me thinking that maybe I should try a different winter tire this year instead of the Blizzaks... If the General Altimax Artic has 100% tread depth of the winter compound instead of just 60% like the Blizzaks, wouldn't that mean I could get away with 2 winters of hooliganism rather than just 1...?
I have run Altimax Arctics on two of my previous winter DD's Altima and Maxima and absolutely loved them. What a great tire for the money. Phenomenal wear, and traction in deep snow or ice that was beyond impressive.
TunaNoCrust is offline   Reply With Quote
Old 09-30-2019, 11:56 AM   #46
8inchAzN
Drives: Car
Which Part?
WS90:
Beneath the Multi-Cell compound is Bridgestone's best winter compound, but without the Multi-Cell feature. Source: https://www.tirerack.com/tires/tires...l=Blizzak+WS90
WS60:
The Blizzak WS60 features a dual-compound tread with Bridgestone's silica-enhanced Tube Multicell compound layered on top of a standard winter compound. Source:https://www.tirerack.com/tires/tires...l=Blizzak+WS60
I can't see the WS80 going back to all season
Old 09-30-2019, 02:04 PM   #47
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
A test of some premo winter tires here for 2018 model tireS. Interesting first place result as I haven't heard of that model of continental tire.
The Michelin x-ice scored low on this list due to poor ice performance comparatively. I found that funny.
http://www.skstuds.ca/2019/02/14/201...ed-by-the-naf/
Old 09-30-2019, 10:25 PM   #48
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
I haven't tried any others, but the Blizzak WS80 has served me well through 3 winters. If you're driving on dry roads more often than not, they'll likely wear out within a couple of seasons of use, but even worn down they're still way better than trying to drive on anything else in the snow.
EDIT: That last line came out a little more loaded than intended. By "anything else" I meant any non-winter tire.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 10-01-2019, 12:22 PM   #49
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I've used all sorts over the years...early Gislaved Frost, Vredestein Grip, Nokian Hakkapeliitta, Dunlop Graspic DS3, Conti ExtremeWinterContact...and I just picked up a lightly used set of Uniroyal Ice & Snow 3s, with studs, for this season. I can't wait for snow.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 10-11-2019, 01:58 AM   #50
guitarman
Drives: 2016 Scion FR-S
Can anyone confirm (or deny) if the Michelin Pilot Sport AS 3+ tires have the M+S logo on them? Thinking about getting a set of these but the Mountain/Snowflake or M+S logo is required.
guitarman is offline   Reply With Quote
Old 10-11-2019, 10:12 AM   #51
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Not thinking so.
https://www.tirerack.com/tires/tires...Speed+Rated%29
https://www.michelinman.com/all-seas...-s-3-plus.html
https://www.tirerack.com/winter/tech...jsp?techid=125
Look for a dedicated winter tire if the 3PMS is required.
Tire Rack has a filter in their search for 3PMS.
https://www.tirerack.com/tires/TireS...inLoadRating=S
They only have 2 tires in 215-45-R17 with that rating.
https://www.tirerack.com/tires/tires...S&autoModClar=
JohnJuan is offline   Reply With Quote
Old 10-11-2019, 10:42 AM   #52
They do not. They are not a rated snow tire. I use them for about 8 months a year but real snows go on when the temperature gets consistently below 40. Soooo... any day now.
Old 10-11-2019, 11:16 AM   #53
Sasquachulator
Pavement Grey
Those all look to be Studded tires.
I've only ever used studless
Old 10-11-2019, 11:27 AM   #54
RToyo86
RToyo86's Avatar
Keep scrolling. They provide a seperate studless review below with 8 tires.
Snipped for the end result.
Continental VikingContact 7 – 91.3 points
Pirelli Ice Zero Fr – 90.6 points
Goodyear Ultra Grip Ice 2 – 90.6 points
Nokian Hakkapeliitta R3 – 90.3 points
Bridgestone Blizzak WS80 – 88.4 points
Hankook Winter I*Cept IZ2 – 88.1 points
Michelin X-Ice XI3 – 87.5 points
Nokian Nordman RS2 – 86.6 points
Old 10-12-2019, 12:53 AM   #55
guitarman
Hi,
Thanks for the feedback. It may be different up here in Canada but I looked at some Michelin A/S 3's at Costco this evening and they had the M+S rating. Tire guy there said all of their "all season" tires have the M+S rating...
So I guess I'll give them a whirl !
Old 10-12-2019, 09:40 AM   #56
Hi,
Well over on my side of Canada they don’t have the symbols on the tires. That said they would probably be great if you are on the island or coast. If you are inland or actually do mountain roads in the winter they will let you down. They are a great three season tire but struggle in dep snow or extreme cold.
tires, winter
TSW Panorama Black w/ Hankook tiers $800 benlevy3 Wheels and Tires 4 05-07-2015 02:57 AM
Winter Tires worth it in Jersey for the remaining of this winter? Jfheisenberg Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-22-2015 10:58 AM
selection of swaybars, for fast street tiers TW180 Fricke Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-18-2014 08:10 AM
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 06:56 PM
