Rust bucket enthusiast
Mishimoto Oil Cooler w/ Thermostat
STOP READING - SOLD
Selling my Mishimoto Oil cooler that comes with the gold thermostatic sandwich plate. Despite negativity in the community, this oil cooler was great and did not leak. People often over-tighten the sandwich plates and crack the spacer - this one was installed correctly and has very little sign of use aside some oil hiding in passages (I tried to get it all out as best I could) and a few of the fittings have marring on the finishes because I don't have an aluminum wrench set. Only issue with the kit is that the sensor wiring is very short. Certainly not unworkable, but you can but a new sensor if you want slightly longer wiring - they intend for you to extend them for your needs anyway. Or if you don't have an external temp gauge, ignore it. Looking for $400 shipped CONUS If some of you know my history, worry not - oil cooler was taken off for the recall work and did not ever go back on - this oil cooler did not see a spun bearing ![]() ![]() ![]() ![]() ![]() Here's how it looks on the car. Subtle but cool!
#2 |
Price dropped to $400 shipped!
#3 |
JDM Vaping Stance Nation
Drives: 2013 White
Will this fit in the front with a turbo intercooler already mounted? I see some people have removed their front grill cover and wasn't sure if it was a clearance issue or not.
Clueless
#4 |
Drives: BRZ Limited
It will if you have an aftermarket crash bar. I've seen some people have it mounted in front of their turbo intercooler that way. I've personally mounted mine on the side, but had to use longer lines.
| The Following User Says Thank You to nwgabrz For This Useful Post: | YamahaR86 (10-10-2019) |
#5 |
This really depends on the intercooler and how the charge pipes are connected as well. The mounting bracket and oil cooler can be separated, so it's not like it has to be mounted to the crash bar directly using the supplied bracket. I can tell you that with my huge FMIC it would end up behind the intercooler, but would still fit.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | YamahaR86 (10-10-2019) |
#6 |
$OLLLLDDDDDD
| Tags |
| darkpira7e, mishimoto, oil cooler |
| Mishimoto racing (low temp) thermostat thoughts ? | Turbo | Engine, Exhaust, Transmission | 3 | 10-05-2018 04:44 PM |
| F/S: Mishimoto racing thermostat | Trac Toy | Canada Classifieds | 0 | 03-13-2016 06:35 PM |
| MD: Mishimoto Oil Cooler / Earls Oil Thermostat - NEW | BoostinIX | Engine, Exhaust, Bolt-Ons | 11 | 07-09-2014 08:59 PM |
| Mishimoto Releases In-Line Oil Thermostat! | Mishimoto | Engine, Exhaust, Bolt-Ons | 0 | 05-07-2014 01:21 PM |
| Product Release! Mishimoto Racing Thermostat for the FR-S/BRZ! | Mishimoto | Announcements, Contests, Giveaways | 1 | 08-23-2013 05:02 PM |
