Old 07-18-2012, 10:14 PM   #15
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
I had to crank on mine for several minutes. I think in the end I used really sticky/grippy gloves that had been heated to make them even grippier, then I gave it a few good yanks, ended up moving the intake box out of the way to get a lower/more stable hold on it. Finally came loose. Subaru must have used something stupid-powerful to get that damn thing on there so tight.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 07-18-2012, 10:58 PM   #16
ShoGun
ShoGun's Avatar
Drives: 2013 Subaru BRZ SWP 6MT
Okay. Got it off. For future reference and for anyone who is having brz oil filter stuck issues with no wrench handy..... Use sandpaper
Bam!
Thanks everyone!
2013 Subaru BRZ - SWP - 6MT
ShoGun is offline   Reply With Quote
Old 07-19-2012, 04:49 PM   #17
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I just drive a screwdriver into it and lever it off.
As for putting the filter back on, do not use any tools. Wet the gasket with oil and then spin it on until the base touches the block. Then turn it 1/2 turn. Never had a filter leak using this method, and they come off in my hand every time.
Old 07-19-2012, 07:38 PM   #18
Hanakuso
Originally Posted by TOMIMOTO View Post
1. Find a flat head screwdriver.
2. Stab screwdriver through oil filter horizontally.
3. Use penetrated screwdriver to twist the filter off.
4. ...................
5. Profit.
This is always my last resort since things can get messy.
Hanakuso is offline   Reply With Quote
Old 07-19-2012, 07:40 PM   #19
Tainen
Drives: First SWP BRZ-L
rubber strap wrench, super useful tool for lots of things. I prefer it to the filter wrench, as that only has one real use, and only once in a blue moon when you have a stuck on filter.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 09-20-2012, 03:57 PM   #20
garf
Great Member
garf's Avatar
Drives: raven, baught 8-29-12, manual
bought a filter wrench and couldnt get enough room to loosen the filter. best solution, wrap a leather belt around the filter and pull the belt off as if you were starting and old manual start engine. worked great! on a side note i used a Mobil one filter to replace the oem, its smaller in diameter than the oem, is that normal or did i get the wrong one? still threaded on fine.
garf is offline   Reply With Quote
Old 09-20-2012, 03:59 PM   #21
Draco-REX
Corner Junkie
Draco-REX's Avatar
Was it taller?
Old 09-20-2012, 04:00 PM   #22
Draco-REX
Corner Junkie
Draco-REX's Avatar
Not a problem with this car. Even with the drain-back valve the oil will drain through the filter element and back into the engine in a couple minutes. Usually by the time you've got the oil drained there's almost nothing left. When I used the screwdriver trick on mine there was no mess.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
Charky (11-30-2013), Guff (09-30-2012)
Old 09-20-2012, 04:26 PM   #23
garf
Great Member
garf's Avatar
it was slightly taller. oriellys looked up my car on their system to find the filter so i assumed it was correct. anyone know the filter number by chance?
Old 09-20-2012, 04:41 PM   #24
DYOLF26
I work at a toyota dealership and all the guys have a claw type universal oil filter wrench from craftsman. it's by far the best one i've used. Has gotten off every canister oil filter i've ever run into. They are only $12. Any place that carries craftsman tools should have it.
DYOLF26 is offline   Reply With Quote
The Following User Says Thank You to DYOLF26 For This Useful Post:
RRnold (09-20-2012)
Old 09-20-2012, 04:45 PM   #25
xn7485
Drives: 1995 Acura Integra GS-R
Had some trouble myself, but just wrapped some painter's tape on it which gave me a lot more grip, and off it came.
xn7485 is offline   Reply With Quote
Old 09-20-2012, 04:52 PM   #26
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
5. Profit.
I had to do that once! It does work, messy but works.
Old 09-20-2012, 05:14 PM   #27
empower-auto
Kouki-Monster
empower-auto's Avatar
If you need to find a way to remove the filter I recommend you look up Chopper Read on YouTube.
Also, if you remove your oil-filler car you can get a better grip on the filter.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 09-20-2012, 06:28 PM   #28
Roach
Roach's Avatar
Drives: '98 Impreza RS -> BRZ
Or... Just use your belt like a strap wrench!
Just make sure the neighbors aren't watching when you take it off....
Roach is offline   Reply With Quote
The Following User Says Thank You to Roach For This Useful Post:
Cole (11-26-2015)
What oil filter do you use? FRSowner Scion FR-S / Toyota 86 GT86 General Forum 8 07-08-2012 09:04 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
TRD Air Filter tonystewart Engine, Exhaust, Transmission 16 06-21-2012 12:46 PM
Oil Filter Brett Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 10 05-23-2012 09:53 PM
air filter andy19804 Engine, Exhaust, Transmission 9 04-28-2012 03:35 PM
