Old 10-03-2019, 12:07 AM   #267
thinkV
Drives: BRZ Turbo
Originally Posted by kmbkk View Post
Yep, mine is the original kit. Not sure why they changed the MAF position tbh.
Yep it's a bummer, I reached out to them a few times and they suggested I go to a fabricator to have it moved or a new pipe made....
thinkV is offline   Reply With Quote
Old 10-03-2019, 12:14 AM   #268
solidsnake11
Drives: brz
Originally Posted by thinkV View Post
I have considered this, similar situation. But also i just dont know if I can go through the trouble and effort of tuning it again.. have had so many issues I am tired. It runs now, my trims are a bit crazy, but its on target.
If using rom raider
download mafscaling-2.5.1
hopefully your tuned on g rom
log with G SERIES ROM logcfg from this site
load log in mafscaling 2.51
copy corrected maf table, load to rom raider and flash.
I just got this working a couple of days ago and its almost like having a automated tuning ecu.
about 100 times faster than reading logs and correcting each cell.
solidsnake11 is offline   Reply With Quote
Old 10-03-2019, 12:36 AM   #269
thinkV
Drives: BRZ Turbo
Originally Posted by solidsnake11 View Post
If using rom raider
I'm with ecutek
Old 10-03-2019, 12:59 AM   #270
solidsnake11
Drives: brz
I'm with ecutek
It might work with ecutek I'm not for sure.
http://vimsh.github.io/mafscaling/
Old 10-08-2019, 05:50 PM   #271
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
lol
Spool is directly related to exhaust volume. Twin turbos cut it in half. True built twin scrolls also cut it in half. With twins you can get the turbo closer to the head which reduces exhaust volume further. Oem's know this but they don't explain it to the general public.
Has little to do with smaller turbo size efficiency.
I'm sorry but you're wrong. It doesn't have to do with effiiency, it has to do with turbine volume. If you have a smaller volume for the same amount of fluid (exhaust gases) it will spool faster.
That's exactly how twin scrolls are designed. One chamber is smaller, the other larger. One will spool it faster the other will give better top end efficiency with less restriction.
Jaden
Jaden is offline   Reply With Quote
Old 01-16-2020, 03:46 AM   #272
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
Sorry guys to bring this back up. Did you guys solve the problem with the MAF?
Drifter X is offline   Reply With Quote
Old 01-16-2020, 09:41 PM   #273
thinkV
Drives: BRZ Turbo
Nawe, just has high trims and the occasional buck.
The Following User Says Thank You to thinkV For This Useful Post:
Drifter X (01-16-2020)
Old 01-16-2020, 09:48 PM   #274
Drifter X
Drifter X's Avatar
Thanks for the insight. Do you know if other owners besides the OP have the same issue?
Old 01-16-2020, 11:16 PM   #275
thinkV
Drives: BRZ Turbo
Not sure, I haven't heard of many people with the kit. Tuner said it was common to this kit, and Treadstone hasn't commented, in fact they are very hard to contact.
Old 01-16-2020, 11:22 PM   #276
Drifter X
Drifter X's Avatar
Aw shucks. I liked the design of the kit specifically being able to use the FMIC and factory crash bar.
Old 01-17-2020, 12:00 AM   #277
thinkV
Drives: BRZ Turbo
I'm going to guess that the whole routing around the crash bar etc is one of the reasons for the turbulent MAF readings. Then again, I'm not an engineer, but I haven't had any solid answers.
Drifter X (01-17-2020)
Old 01-17-2020, 12:15 AM   #278
Drifter X
Drifter X's Avatar
Yeah I think you may be right. I think I’m gonna look at the Full-race Borg Warner Kit.
Crawford Performance Turbo BRZ ! Visconti Forced Induction 57 10-12-2012 08:45 AM
Turbo BRZ from Accelerated performance buzznasa BRZ First-Gen (2012+) — General Topics 3 07-20-2012 12:14 PM
need donor for treadstone turbo kit treadstone performance Forced Induction 113 07-19-2012 11:31 AM
