#3249 |
Drives: 2015 Subaru BRZ Aozora
I did not, I reused the old orings and added grease onto them. I will go purchase new orings and hope that was the issue. Pardon my ignorance but how do I make sure the injectors are clocked correctly? Thanks.
#3250 |
Drives: 14 BSP Edelbrock BRZ
The fuel rail has 'teeth' sticking out from it. The connector for the injector fits in between the teeth. If you don't have connector there the injector will spray fuel at the walls of the intake instead of I to the air stream. Did you download the instructions? There is a pretty clear picture of this in there
| The Following User Says Thank You to toast For This Useful Post: | itsaBRZ (10-01-2019) |
#3251 |
Drives: anything you let me
Interesting question, can the motor be pulled/installed with the SC intact? Curious if building a second motor makes sense to install the SC on a stand and drop everything in as one piece or if you need to do it as separate steps.
#3252 |
That would be a VERY tight fit, but in theory, yes. In actuality, the manifold should be removed for ease of install.
| The Following User Says Thank You to CSG Mike For This Useful Post: | Uplink (10-04-2019) |
#3253 | |
so I followed the Edelbrock instructions and clocked all injectors facing "outward" however now the fuel injectors can swivel or rotate... is this normal? If I instead place the injectors in the 'teeth' they are no longer facing outwards, but will not swivel or rotate and this seems more secure. I'm just very unsure of which direction these injectors should be pointing so I attached a photo from the driver side. They are currently in the 'teeth' and facing the same direction (red), should I move the left injector to towards the direction of the blue arrow on the left as well? Sorry for all the questions, but I am still getting error code P0170 (system too lean bank 1) I would've taken a picture of the passenger side but the black bracket is covering it. I just really need some clarification on the orientation of all 4 fuel injectors. Thanks again for everyones help. |
#3254 |
The purpose of the teeth is to maintain the orientation. If they are in the right orientation they will not swivel. There is really only one way for this to happen. Going from memory they should be in the direction you indicated with the red arrows. When the instructions say 'outward' I think they are just getting people to not have the electrical connector facing the supercharger manifold.
#3255 | |
I checked to make sure the EVAP and PCV hoses were clamped down. I have also cleaned the throttle body and maf sensor, I'm not sure what else there is to check at this point... |
#3256 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
Does anyone have an easy way to remove the clutch slave cylinder without removing the supercharger or transmission? I'm not having much luck today
#3257 |
#3258 | |
#3259 |
I will double check those again today. I just tried to do some datalogging and my STFT is 7% at idle and my LTFT is 0%, but when I step on the gas, my LTFT jumps all the way up to 30% is this normal?
#3260 |
Drives: 2013 FR-S Series 10
First fresh fill up of 91 octane, i averaged 27 mpg. Only dropped 1 mpg! Probably 80% highway driving averaging 70-75 mph. I do get into it on the street but i find no need to redline anymore dailying.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
| The Following User Says Thank You to Decep For This Useful Post: | marco1ca (10-08-2019) |
#3261 |
Just wondering if this is the same case for everyone else here? My stock passenger side PCV hose tightens up and gets squishy as I step on the gas pedal? There are no leaks or anything in the hose so is this supposed to happen?
Also, my short term fuel trims at idle are around 0% and LTFT is 15% but when I accelerate both STFT & LTFT jump to 20-30%.. I've checked my fuel injectors, pcv hoses, pcv valve and exhaust leaks... anyone have any idea what could be causing this? Thanks. |
#3262 | |
Drives: 2017 Toyota 86
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
