Old 09-30-2019, 12:24 PM   #1
Greenbean
Drives: 2017 series yellow BRZ
bags without insane camber (18x9.5 38mm)
anyone here on running bags with a 18x9.5 x38mm or something around that offset? kinda curious to see what it would look like with a meatier tire ex. 245/35 or 255/35. if anyone has a 18x9.5 inch wheel with offset and tire specs around these on air suspension can you guys post photos.
Greenbean is offline   Reply With Quote
Old 09-30-2019, 02:55 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
https://www.ft86club.com/forums/showthread.php?t=106343
I don't think you are going to get that to fit. It looks like guys are rubbing with 18x9.5 +35 with a 225/40. A 18x8.5 +25 is suggested several times for the front.
I LIKE TIRES!
Old 09-30-2019, 04:59 PM   #3
Greenbean
i did find this on custom offsets https://www.customwheeloffset.com/wh...ft-performance says no rubbing but who knows and that post seems to be all over the place about what rubs, ill just continue the research this is just a thought rn anyways. I appreciate the help!
Old 09-30-2019, 08:48 PM   #4
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
On bags I'd probably run 18x10 +20, you won't need that much camber to air out, def not cambergang or anything like that. I have a couple friends that run close to that size
My question is why run bags if you're looking at relatively normal wheel sizes? You can be static low with 18x9.5 +38 on coilovers easily...
Shizuka is offline   Reply With Quote
Old 10-02-2019, 07:55 AM   #5
Greenbean
im already on coils and a 18x9.5 38 setup with 255/35, it was just crossing my mind if i did want to do it bc i dont wanna buy new wheels and tires if i could do it and run a smaller tire i would but really dont want to buy a whole new setup thank you probably just stick with my coils lol
Airlift bags on 18x9.5 (235/40) Any issues? Izanagi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-25-2017 11:43 AM
RAYS 57DR Limited Edition - 18x9.5 +38mm 5x100 /// RavSpec Wheels and Tires 4 08-11-2015 12:23 PM
RAYS Gramlights 57DR 18x9.5 +38mm Mag Blue Special Ed. RavSpec Wheels and Tires 4 09-17-2014 12:27 AM
WORK Emotion XD9 - 18x9.0 +38mm / 18x10.0 +38mm (3" Lip) RavSpec Wheels and Tires 49 12-22-2012 11:17 AM
