Old 09-27-2019, 04:06 AM   #43
biggie
Drives: gt86
To all long time owners of Q300: I've heard from various sources (forums) that the "glasspack style" insulation is burning off in time (in just a few months - faster if you track the car) and the sound is getting A LOT louder and "empty can" like. Is this true?
I have an catless UEL header and plan to keep stock OP and FP.
Thanks!
biggie is offline   Reply With Quote
Old 09-27-2019, 07:51 AM   #44
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Thanks!
I have had one for 4 years, and 15k+ track miles. At one point it did noticeably get louder. However, with a catless uel, over pipe, catless/resonated mid-pipe and the invidia q300, I easily under any sound check at any track. And you can barely hear it at idle. (once it has warmed up.) Perfect street setup. IMO. Still sounds amazing.
This a 4k rev when I first got it.
With a stripped interior at the glen last year
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
biggie (09-27-2019)
Old 09-28-2019, 07:49 PM   #45
Ernest72
I agree it gets louder but not empty. At least yet. 2.5 years so far.
The Following User Says Thank You to Ernest72 For This Useful Post:
biggie (09-29-2019)
Old 10-04-2019, 01:15 AM   #46
FRS_FIEND
Whats next?
FRS_FIEND's Avatar
Drives: '13 Asphalt FRS MT
Thanks!
I've had mine on since 2013 I'm at 80k mi. No track days but plenty of canyon runs. Sounds just as perfect as day one . I have had catless borla uel headers perrin overpipe invidia resonated front pipe and resonated q300 all since 2013 actually and still have the deep rumble. Loud wot and quiet cruising and warm idle.
Life is too short to drive a boring car...
Instagram: @angelb_af
FRS_FIEND is offline   Reply With Quote
The Following User Says Thank You to FRS_FIEND For This Useful Post:
biggie (10-04-2019)
Old 10-27-2019, 12:10 PM   #47
willburr
Drives: 2017 BRZ
Another data point...
Mine has 1000 miles on it. No other mods. Loud on cold start, quiet at warm idle. Great sound inside and out through the rev range. The volume seems to vary day to day, and I have no idea why, but it's never too loud.
willburr is offline   Reply With Quote
The Following User Says Thank You to willburr For This Useful Post:
biggie (10-28-2019)
Old 10-28-2019, 06:32 AM   #48
biggie
Drives: gt86
Just installed the Q300 CB few days back: sounds much deeper, the "rumble" (UEL header) it's way more pronounced and overall it's not that much louder than with the stock CB. I guess that even if it gets a bit louder in time I'll be OK with it (I hope).
The only downside would be the weight, It's even heavier than stock (just a bit)!
So far I'm happy with my choice
Old 11-13-2019, 03:51 AM   #49
biggie
Drives: gt86
UPDATE
After just one trackday the love story ended. Now, at ~2500 revs, it makes a very lame, empty tin can sound. The same thing happens at ~1700, but that is tolerable. I don't mind louder, but this is ruining the fun big time.
Very disappointing
Old 11-13-2019, 09:23 AM   #50
DarkSunrise
DarkSunrise's Avatar
UPDATE
Very disappointing
Did you check all the connections on the exhaust and hangers?
2022 BRZ Build
2013 FR-S Build
Old 11-13-2019, 09:46 AM   #51
biggie
Drives: gt86
Not after the trackday, no. Do you think there might be leaks that are causing this?
Old 11-13-2019, 11:22 AM   #52
DarkSunrise
It's possible and worth checking. I remember after one of my track days, I was getting a metallic rasp in certain RPM ranges. Turns out the bolt for the hanger holding the midpipe had come loose. If I were you, I'd check all of the connections to make sure everything is snug and tight.
2022 BRZ Build
2013 FR-S Build
Old 11-13-2019, 12:14 PM   #53
RFB
RFB's Avatar
Drives: FRS
UPDATE
Very disappointing
I tracked my FRS heavily since it was born in 2012 (OFT tune UEL headers one cat back then). I've seen Q 300's, Magnaflow, etc., mufflers and cats blow out from heavy tracking, usually for me at the end of the 2nd season.
With a built motor I got one season so -
Now I run one Vibrant cat, 2 resonators and 2 Vibrant racing mufflers .
This should give longevity to hard driven and boosted cars as well as stock.
RFB is offline   Reply With Quote
The Following User Says Thank You to RFB For This Useful Post:
biggie (11-14-2019)
Old 11-14-2019, 08:33 AM   #54
biggie
Drives: gt86
How about the noise, is it much louder than Q300? Maybe you can compare (noise levels) with some other known CB like N1 or MXP RS.
What Vibrant products did you used? I see that there are quite a few model for each part...
Old 11-14-2019, 02:58 PM   #55
RFB
RFB's Avatar
Drives: FRS
Mine is a built blown motor, with a custom built exhaust system.
Your mufflers will depend on pipe diameter, HP, cats, boost, resonators etc.
Any decent race (not muffler) shop can figure out the combo for quiet or noise for your car.
Mine is super quiet when I drive like old people f#ck, but growls when I hit boost.
Old 08-20-2020, 06:06 PM   #56
Hayer_86
Hayer_86's Avatar
Drives: '17 MT 86
UPDATE
Very disappointing
Any update on this? Still tinny or was the issue something else. Im looking at getting the cb but am worried of having the same issues years down the road.
Hayer_86 is offline   Reply With Quote
**INVIDIA** >>SUPER SALE THREAD<< - Invidia N1 - Invidia Q300 - Invidia Front Pipes - FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 629 12-11-2016 09:21 PM
Invidia Q300 and Invidia Frontpipe Installed! Kevin@RAD Engine, Exhaust, Transmission 19 11-05-2013 05:49 PM
Invidia Q300 with Ti Tips seven Engine, Exhaust, Bolt-Ons 23 03-09-2013 01:39 AM
FS: Invidia Q300 Burnt TI Version FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 0 01-16-2013 01:46 AM
Invidia Q300, Frontpipe & N1 Teaser Videos! RallySport Direct Engine, Exhaust, Transmission 18 10-17-2012 04:00 PM
