Old 09-24-2019, 09:05 PM   #15
Originally Posted by HKz View Post
there was nothing to fix like the crickets. if variations in idle speed bothers you guys so much, then I think y'all aren't doing enough actual driving!
OR,..... maybe they need a bigger engine -
Didn't used to have those problems, back in the day.
HKz (09-24-2019)
Old 09-24-2019, 09:19 PM   #16
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I raised my idle to 900rpm. No more stumbling, also doesn't dip low if you clutch in from a high rpm and let it drop, it stops right at 900. Even with a/c or defrost at full speed
As much as I love a calm 650rpm idle, this car acts say better at 850-900 for me.
Old 09-24-2019, 09:32 PM   #17
Hell, our old 2 cylinder John Deere tractor would idle quite smoothly at 150 RPMs.
However, it had a 10,000 pound flywheel -
"You can take the boy off the farm, but you cannot …." something or other -
Old 09-24-2019, 11:30 PM   #18
JesseG
JesseG's Avatar
Drives: 2016 Scion FR-S
I agree, unfortunately driving in traffic on hot summer Texas days happens sometimes.
And something interesting about the crickets, my FR-S had them when I first bought the car. They’ve been gone after I started filling up with 93 octane at Valero. *shrug*
JesseG is offline   Reply With Quote
Old 09-25-2019, 03:31 PM   #19
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Mine got pretty shaky once during a 90 degree day when I was stuck at a light for almost 15 minutes in city traffic. I don't recall what the RPMs were doing, but the temp gauge read normal so I couldn't figure out why it was shuttering. I turned the AC off and opened the windows. Car was happy, I suffered.
Nevermore is offline   Reply With Quote
Old 09-25-2019, 05:21 PM   #20
Sasquachulator
Pavement Grey
I remember my old Corolla XRS doing an RPM dip when stopped when the AC was on. There was also a clear drop in power too when the AC was on.
More recently however, my Scion IM is doing it.
At times I stop at a light and I can feel the car (and see the RPM) fluctuate between around 500ish to 1000rpm when stopped (leveling off at 750ish for a period before it does it again).
I figured it had something to do with the A/C compressor due to previous experience but I don't have defog or anything that I would think would activate the AC compressor...….so I thought it was weird.
I did have an oil change and that SEEMED to have fixed it for like a week or two but then it came back.
Ill live with it, but I don't know why the car fluctuates the idle as much as it does.
Old 09-26-2019, 01:44 PM   #21
sodjer
Drives: 2015 BRZ Limited
Send a message via MSN to sodjer
Originally Posted by Pwoods View Post
Just an update on my situation. I changed my OFT tune to stage 2 and it seems to have fixed this issue. I’ve heard that a stage 1 tune on a stock car will smooth out the idle, but I don’t know for sure.
My car would do the RPM dip to the point of almost dying as well, after flashing to OFT Stage 1 it cleaned it up and hasn't done it since. Now I just gotta get my header on so I can flash stage 2...
sodjer is offline   Reply With Quote
Old 09-26-2019, 02:31 PM   #22
CoolHandMoss
Drives: 2013 FRS
I have ECUTEK and I was able to get Mike to add in some padding when the throttle closed with the A/C on. Now it kind of hesitates before dropping to idle. It works quite nicely.
CoolHandMoss is offline   Reply With Quote
Old 09-26-2019, 03:27 PM   #23
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Worst ecu, EVER.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 3 Users Say Thank You to venturaII For This Useful Post:
humfrz (09-26-2019), Spuds (09-26-2019), Ultramaroon (09-26-2019)
Old 09-26-2019, 03:50 PM   #24
Originally Posted by venturaII View Post
Worst ecu, EVER.
Got me. Spit my food a little.
Seriously, I know a bunch of local owners, driven many, worked on many...
Not once have I seen one that dipped or shuddered like described here. There's a little bit of it coming from unanticipated changes to accessory load but nothing dramatic.
Old 09-26-2019, 04:53 PM   #25
Pwoods
Drives: 2013 fr-s
Just for the record, I don’t drive my car I just rub it with a diaper
Pwoods is offline   Reply With Quote
Old 09-26-2019, 06:04 PM   #26
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
nice! the tradeoff is you'll most likely avoid a spun bearing, never have to deal with the torque dip and you won't have to change out those pesky poorly designed brakes!
HKz is offline   Reply With Quote
The Following User Says Thank You to HKz For This Useful Post:
humfrz (09-26-2019)
