Old 09-11-2019, 10:47 PM   #1
kev0
Drives: '14
Feel a little 'bump' when I brake when CEL is on.
P0171 lean code. I've had it for a while now. I've noticed that when the light is on, and I brake, I feel a subtle 'bump' right before I come to a stop. When I clear the code, the car brakes 100% smoothly. How could a light cause my car to have that bump when I brake?
kev0 is offline   Reply With Quote
Old 09-11-2019, 10:51 PM   #2
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Auto or manual?
Sent from my moto g(6) using Tapatalk
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 09-12-2019, 12:45 AM   #3
kev0
Drives: '14
Originally Posted by jeffchap View Post
Auto or manual?
Forgot to mention! Thanks. It's an automatic
Old 09-12-2019, 02:49 AM   #4
radroach
Drives: car
Hm. I kinda experienced this with a different CEL (ABS sensor broken) causing limp mode, every time I came to a stop the car would almost stall.
Old 09-12-2019, 03:03 AM   #5
kev0
Drives: '14
Well shit. I have an ABS code too (C1201). I didn't think too much of it. The slip lights only come on sometimes. Even when the light isn't on, I still feel the bump. So weird. My RPM's drop when I come to a stop and would sometimes almost stall as well but I'm assuming that's because of the lean issue from my P0171 code.
Old 09-12-2019, 08:17 AM   #6
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Sounds like
http://www.ft86club.com/forums/showthread.php?t=134579
But as always, if you've got fault codes, have those issues fixed FIRST.
The Following User Says Thank You to RZNT4R For This Useful Post:
kev0 (09-12-2019)
Old 09-12-2019, 12:00 PM   #7
radroach
Drives: car
@kev0 limp mode was a pretty severe occurrence in my case. I was unable to rev past 3500 rpm, scary on the highway.
Take care of the ABS problem first and clear codes and see if your lean code goes away.
The Following User Says Thank You to radroach For This Useful Post:
kev0 (09-12-2019)
Old 09-12-2019, 12:21 PM   #8
RZNT4R
No.
C1201 is there to inform you that there is an engine management problem. Repair the engine control system malfunction and it will go away by itself.
kev0 (09-12-2019)
Brake firmness/pedal feel Hyper4mance2k Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 05-22-2019 01:22 PM
New Ferodo Brake Pads Feel Sticky kodyo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 04-30-2018 04:22 PM
Brake feel bg15 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 07-27-2017 02:18 PM
Brake Feel Enhancement Capt Spaulding Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-06-2016 12:33 PM
Odd brake pedal feel, fade? yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 09-11-2012 01:29 PM
