Old 09-10-2019, 04:37 PM   #1
gpvecchi
gpvecchi's Avatar
tS rear stopper
I saw that BRZ tS has rear stopper fitted to the subframe. 2013 model has upper, 2015 model, lower.
Do you think that fitting both is a good idea? It would be something similar to Beatrush kit...
BTW, I have the STi bushings...
Thanks!
Old 09-10-2019, 09:28 PM   #2
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Gonna need part numbers and photos here.
Clutch Dog is offline   Reply With Quote
Old 09-10-2019, 10:50 PM   #3
norcalpb
norcalpb's Avatar
I wouldn’t do both, or why have done the compliant, STi subframe bushings to begin with?
Old 12-04-2024, 09:31 AM   #4
Prodigalson
ThisGuyLoves86's
Prodigalson's Avatar
Drives: 2013 Scion FRS
Thanks!
Did you end up installing both the upper and lower? Seems it would be similar to the Whiteline inserts approach. I have ordered both the upper and lower and 4 of the longer subframe bolts.
2013 Scion FRS (current car)
1991 Mazda Miata MX5 (current car)
2003 Nissan Pathfinder (R50) (current car)
2018 Lexus GX460 (current car)
2023 GR86 Neptune M6 Premium (Leased)
Prodigalson is offline   Reply With Quote
Old 12-04-2024, 05:07 PM   #5
gpvecchi
gpvecchi's Avatar
Yes, I fitted upper and lower on the front, and just upper on the back (lower are not compatible) with longer bolts. I have the STi subframe bushings too.
Old 12-04-2024, 08:45 PM   #6
Prodigalson
ThisGuyLoves86's
That's helpful information, thanks!
How much improvement do u think the subframe bushings add (as opposed to just the stoppers?). How difficult were they to install?
Old 12-05-2024, 01:05 AM   #7
gpvecchi
gpvecchi's Avatar
The frame bushings are a great improvement, a lot of traction. Furthermore, the front ones are not slotted, so there is no risk of the subframe moving.
They are quite expensive to fit.
The stoppers are a good help.
The Following User Says Thank You to gpvecchi For This Useful Post:
Prodigalson (12-10-2024)
Old 12-10-2024, 12:39 PM   #8
Prodigalson
ThisGuyLoves86's
Rallysport Direct had them for $25 each so i ordered all 4
Window stopper rubber ripping frslee Issues | Warranty | Recalls / TSB 6 02-06-2014 01:21 AM
Worn out clutch stopper AsianStyle Issues | Warranty | Recalls / TSB 1 07-05-2013 08:07 PM
FS: cusco front strut bar with stopper 86design Brakes, Suspension, Chassis 14 06-17-2013 02:41 PM
Clutch Stopper? wootwoot Engine, Exhaust, Transmission 4 08-06-2012 03:02 PM
HKS Stopper Head Gaskets for FRS and BRZ Hal@Dynosty Engine, Exhaust, Bolt-Ons 7 07-03-2012 08:48 PM
