Old 08-27-2019, 09:31 PM   #29
AndreC
Drives: Fast track beast
I pull 1.5G in my stock block FRS for 7 years now, zero issues. Pan is already partially baffled from factory.
I also use Amsoil 5W30, which helps though and ensure the oil level is to the top of the range, but not overfilled.
Sent from my SM-G965W using Tapatalk
AndreC is offline   Reply With Quote
Old 08-27-2019, 09:32 PM   #30
Grady
Grady's Avatar
Originally Posted by Elliotw View Post
How much HP is that good for?
Let’s see.... 8psi, pump gas, supercharger.... looks like around 234.5 wheel HP.
The Following User Says Thank You to Grady For This Useful Post:
Elliotw (08-28-2019)
Old 09-01-2019, 08:49 AM   #31
casing
Drives: stock
I've installed a used engine. Lets see how long this one lasts.
casing is offline   Reply With Quote
Old 09-01-2019, 10:49 AM   #32
jRuN
Do any of the oil system mods? New pickup, baffle etc?
Sent from my Pixel XL using Tapatalk
jRuN is offline   Reply With Quote
Old 09-01-2019, 12:17 PM   #33
ls1ac
ls1ac's Avatar
Let us know what you find inside the old engine.
Old 09-06-2019, 01:59 PM   #34
toast
Drives: 14 BSP Edelbrock BRZ
Originally Posted by casing View Post
I am pretty sure this it what happened. It was mostly my fault. My shitty gas mixed oil I believe washed down my cylinders causing my compression rings not to seal essentially boosting my crank case. Blew out the seal and loss oil pressure.
I'm curious how you reached this conclusion.
toast is offline   Reply With Quote
2013 FR-S Spun Bearing kyjondeere Issues | Warranty | Recalls / TSB 1 09-14-2018 09:24 AM
Need help, spun rod bearing, vvt parts missing faninos Issues | Warranty | Recalls / TSB 3 07-12-2018 03:11 PM
Engine failure - Spun rod bearing TWICE dinoniel Issues | Warranty | Recalls / TSB 38 11-07-2016 01:17 PM
Spun Rod Bearing #4 KE70 Issues | Warranty | Recalls / TSB 13 07-05-2016 03:17 PM
Likely hood of a spun bearing aquaman Engine, Exhaust, Transmission 14 02-24-2016 01:37 PM
