| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Which brand for rear hub assembly?
It sounds like maybe I have my rear passenger wheel bearing going out on me, and I'd like to just go ahead and buy the full hub assembly so I can knock out the studs and prep it with extended ARP studs for a replacement when needed.
RockAuto has three brands available: SKF, Moog, and Beck/Arnley. I'm thinking the SKF is probably the highest quality, but I'm open to being told otherwise. Anyone had to replace their rear hub assembly/wheel bearings and what brand do you think I should choose here? Thanks |
#2 |
Drives: Subaru BRZ
I replaced mine with OEM.
For extended studs, I would go with 2.5" 100-7729, I do not think we need the 3" 100-7716, the 2.5" ones should be more than enough? |
#3 | |
I'm running the 3" right now, probably will go with them again because for one set of wheels I run 18mm / 19mm spacers and I like having some extra past the threads on my lug nuts. I will call the parts counter at the dealership to do a price check on the OEM hub assembly. Probably right that just going with OEM is the best bet. I will say I am REALLY happy these are sold as bolt-in assemblies vs having to press-out/press-in bearings
| The Following 2 Users Say Thank You to Tristor For This Useful Post: | Code Monkey (09-05-2019), wparsons (09-05-2019) |
| wtb: rear fog light assembly | chriscross_tnt | Want-To-Buy Requests | 6 | 09-02-2013 11:54 PM |
| [SYD] *Brand New* Stitched Alcantara OEM Gauge Cluster Hood Assembly | eckoflyte | Australia Classifieds | 5 | 05-02-2013 04:42 AM |
| Rear Hub Assembly? | SsmoothyMonster | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 02-03-2013 02:22 AM |
| Rear Hub Assembly? | SsmoothyMonster | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 02-03-2013 02:13 AM |
