Old 09-04-2019, 05:22 AM   #197
TaylorFRS
Drives: Hot Lava FR-S
Is there any markings and or ways to tell if a set of tfa are truly CSG? There are some used ones in my area and I dont want to buy just flex a's.
TaylorFRS is offline   Reply With Quote
Old 09-04-2019, 07:09 AM   #198
churchx
churchx's Avatar
Drives: 2014 GT86
As dampers are kind of wearables too .. maybe it's more worth to save for new set? As for those used ones .. CSG started making/selling custom valved As not that long ago, and most customers liked them, so imho there might be little chance for them to soon selling them off for something else, and thus little chance for those to be of CSG spec.
Old 09-04-2019, 12:31 PM   #199
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
It says "CounterSpace Garage" on the tag. There are maybe 1-2 standard FLA units that have been revalved and serviced to CSG Spec, but they are very specific individuals who wanted to pay for the service. FYI, it's far more budget conscious to just order the CSG FLA instead of converting a used FLA to CSG Spec.
CounterSpace Garage is offline   Reply With Quote
Old 09-04-2019, 12:55 PM   #200
CSG Mike
CSG Mike's Avatar
https://counterspacegarage.r.worldss...ex-a-1_web.jpg
timurrrr (09-05-2019)
Old 09-05-2019, 04:44 AM   #201
TaylorFRS
The owner is selling them for a great deal and because hes selling his car. I'm going to pick these up and probibly either get them rebuilt farther down the line or sell them to my friend and buy a new set. So we can both be on these sweet coilovers! Also they do have that sticker thank you!
The Following User Says Thank You to TaylorFRS For This Useful Post:
CSG Mike (09-05-2019)
Old 09-05-2019, 01:31 PM   #202
CounterSpace Garage
Glad to see them being kept within the community!!
Old 09-10-2019, 11:29 AM   #203
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Did my first road course on these coil overs, they handled well, but with the front camber maxed out at the strut towers (I think they were 2.4 degrees), I managed to wear the outer edges of my hoosiers down to the belts in four sessions. I'd like to go closer to 3.2 to 3.5 degrees... is the only reasonable way to accomplish this with an adjustable lower control arm? I assume camber bolts on coilovers would be frowned upon at this point. ??
Video for fun. You can hear my winmax w4 pads screaming in agony.
[ame]https://www.youtube.com/watch?v=7jmU4bEsK9g[/ame]
spitsnaugle is offline   Reply With Quote
Old 09-10-2019, 11:58 AM   #204
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by spitsnaugle View Post
... I think they were 2.4 degrees ... I'd like to go closer to 3.2 to 3.5 degrees... I assume camber bolts on coilovers would be frowned upon at this point. ??
You might find this post and this question useful. I still haven't got a definitive answer to that question though.
The Following User Says Thank You to timurrrr For This Useful Post:
CounterSpace Garage (09-10-2019)
Old 09-10-2019, 12:36 PM   #205
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Do the cam bolts, no issue if properly installed
ineedyourdiddly
Old 09-10-2019, 01:42 PM   #206
CounterSpace Garage
You can use crash bolts to gain additional camber up front. It should be easy to get -3 to -3.5 with that setup and our camber plates.
Also, if you're working the course like that, you're going to need a proper pad. Understandably you have a retrofit CTS-V kit, but heat is still going to be an issue and a pad compound is required to take on that heat on top of the stress from using Hoosiers.
Let us know when you can provide us additional feedback. We'd love to help optimize your setup so you can run harder.
Old 09-10-2019, 02:20 PM   #207
CSG Mike
CSG Mike's Avatar
If installed at the recommended ride heights, you should be able to get the camber range you're looking for.
Have a picture of the top hats? You may need to move the bolts over a hole or two, to get more clearance!
timurrrr (09-10-2019)
Old 09-10-2019, 04:44 PM   #208
spitsnaugle
Good memory on the brakes. Also running STI/EVO rears.
I was just informed I won best engineered car. Too bad I didnt stay for the award ceremony.
Brakes held ok through the 20 minute sessions. I only noticed one time where I thought they were fading. Being my first road course in this car, (and first time on NCM) I wasnt pushing as hard as I could have.
I definitely like my winmax W3's/W4's for autocrossing, but wouldnt mind stepping it up a bit for the next track day (within reasonable budgets)
The car is likely going to Toronto Motorsports Park perhaps next month to get reviewed on Speed Academy for quick three hot laps.
Top hats: contrary to appearance, these are dialed to be equal:
Old 09-10-2019, 04:47 PM   #209
CSG Mike
CSG Mike's Avatar
That tells me your shop likely has the bolts in asymmetrically at the bottom.
Old 09-10-2019, 05:30 PM   #210
CounterSpace Garage
TMP is pretty hard on brakes and having Hoosiers certainly doesn't make that task easier. Let us know if you need something that will actually hold up to that task. With a seasoned veteran driver, the car is going to see some incredible pace. Like we discussed in the past, we got the pads to take on the task and won't cook your caliper. There are certainly pads that are more budget oriented, but you will need to monitor the caliper temperature and fluid.
PM us if you want us to get you setup for next month! We've rushed some parts over to some clients who will be working with Speed Academy soon.
WTB Tein Flex Z HachiRo Want-To-Buy Requests 1 09-19-2016 01:13 PM
tein flex z mclovin85 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-14-2016 06:27 PM
TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day CounterSpace Garage Groupbuys 47 02-18-2016 12:33 AM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 09:33 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
