Old 08-31-2019, 11:01 AM   #57
CSG Mike
CSG Mike's Avatar
Is that on 2017+ cars only ?? Was it fixed in racerom 10.1 ver 33571 ?
Yes, 17+, and not fixed
I still run RR9
Old 08-31-2019, 11:32 AM   #58
tomm.brz
Drives: brz 2017 hksv2
in my my17 i still get the bug with latest rr10 (rr10.1 hadn t been released yet for K00G) but actually only if I mess with the throttle angle with custom maps
I can mess real time with ign advance and cams and all work good
Old 08-31-2019, 04:24 PM   #59
Lantanafrs2
Drives: 2013 frs red
I have a feeling the op has/had an upstream exhaust leak.
Lantanafrs2 is offline   Reply With Quote
Old 08-31-2019, 09:07 PM   #60
steve99
Drives: FT86
I still run RR9
arrrh.
think i ran into it on a 2017 auto today, wont rev over 3500 , no cels. like its stuck in safe mode but no CEL
RR9.1 works fine RR10.1 no go
Old 08-31-2019, 10:00 PM   #61
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Or not, say that Dyno reads a stock 86 at 160-ish hp, that's pretty in the ballpark for a stock car, +12 hp is on par for what I'd expect from a canned tune and short tube header. Maybe it reads lower and he's actually getting near 20? We don't know. I've also got a Tomei header (EL) and OFT, put my car on a Dyno and I'd be happy with 10hp over stock and really impressed if it was close to 15hp, but my whole power setup was less than $1k.
That's just the reality of tuning a modern NA engine for pump gas that the OEM already squeezed 95% of the performance out of from the factory.
ineedyourdiddly
wparsons (09-03-2019)
Old 08-31-2019, 10:12 PM   #62
Lantanafrs2
You may be right but the curve itself looks too close to stock (dip area) imo
Old 09-01-2019, 01:16 AM   #63
86TOYO2k17
Drives: 2017 toyota 86
I thought we already figured his issue out. IAM was at .7 and it was very hot and humid resulting in much lower numbers. Mystery solved.
Old 09-01-2019, 03:01 AM   #64
CSG Mike
CSG Mike's Avatar
arrrh.
Mine is... a bit more extreme. I get a full ECU crash/shutdown at between 7100 and 7300 rpm at WOT. If you're not going straight... yeah.
Because it's a full shutdown, the log cuts off too.
steve99 (09-01-2019), wparsons (09-03-2019)
Old 09-01-2019, 05:27 AM   #65
churchx
churchx's Avatar
Drives: 2014 GT86
Oh. Just trying to imagine Mike's case scares me s***less :/. Hopefully it happened on dyno.
Old 09-01-2019, 06:43 AM   #66
steve99
Drives: FT86
Eeeek that scary , would not get it on dyno as going straight, then on road or track shuts off, nasty
Old 09-01-2019, 03:44 PM   #67
CSG Mike
CSG Mike's Avatar
It happens both on the dyno and on the street, and in any gear, as long as I hit the RPM, I get a full shutdown. Whole car powers down, like I turned my key off, and then powers back up within about a second on its own.
RR11 was just released; I suspect the bug may be gone now. I'll find out within a few weeks when I can purchase some dyno time.
Old 09-03-2019, 02:22 PM   #68
wparsons
wparsons's Avatar
Full decel and no power steering mid corner sounds like a serious code brown.
flickr
Old 09-03-2019, 02:23 PM   #69
wparsons
wparsons's Avatar
That doesn't explain why the torque dip is still there... I'll bet that, plus wrong OTA tune for the header.
flickr
Old 09-03-2019, 03:13 PM   #70
86TOYO2k17
His graph looks almost identical to this tomei uel after tune graph, notice the appearance of a torque dip if you didn't have the baseline to compare.
Also OPs graph is so squished it makes his “torque dip” look over exaggerated compared to if it was stretched across the entire graph like most dyno graphs.
His graph looks as would be expected for a cheaper header with canned tune with catted FP with IAM at 0.7 and 90F + 90% humidity.
The Following 3 Users Say Thank You to 86TOYO2k17 For This Useful Post:
Lantanafrs2 (09-03-2019), strat61caster (09-03-2019), wparsons (09-03-2019)
OFT V3.02 Stage 2+ Flash Dyno Results mgarcia707 Software Tuning 3 11-12-2018 03:55 PM
Dyno Results - OFT Stage 2 UEL + Openflash Header + Full Exhaust pinski Software Tuning 8 11-21-2016 11:07 AM
Stock Dyno and Perrin Stage 1 Results brillo Software Tuning 4 01-24-2014 08:26 AM
FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) Pure Automotive Forced Induction 57 03-27-2013 11:41 PM
TRD cat back, any dyno results MTCRX Engine, Exhaust, Transmission 4 11-26-2012 06:26 PM
