Old 08-30-2019, 11:59 AM   #43
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I have the 3.56 gears and at 70mph, it's between 3400-3500. It's not too bad, I just keep it at 60mph at 3000rpms
Dr. BRZ is offline   Reply With Quote
Old 08-30-2019, 12:07 PM   #44
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
That rpm seems high for the speed you go. I have stock 4.1 diff on slightly larger than stock 235/40 tires on 18x8 (a 3.1% larger size) and 80mph is 3500rpm in 6th gear.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 08-30-2019, 12:15 PM   #45
Dr. BRZ
Dr. BRZ's Avatar
Originally Posted by Spawn_Of_Creation View Post
That rpm seems high for the speed you go. I have stock 4.1 diff on slightly larger than stock 235/40 on 18x8 tires (a 3% larger size) and 80mph is 3500rpm in 6th gear.
The rpms are definitely higher. I'm on 225/45 tires on 17x7 wheels. It doesn't bother me. I don't take the car on the highway much, mostly streets.
Old 08-30-2019, 12:23 PM   #46
86TOYO2k17
Drives: 2017 toyota 86
You mean 4.5 final drive?
Old 08-30-2019, 12:30 PM   #47
Spawn_Of_Creation
Human
With your stats you should be at 80mph @ 3000rpm with your 3.56 fd. If that is really your speed, you might have clutch slippage.
Old 08-30-2019, 12:32 PM   #48
churchx
churchx's Avatar
Drives: 2014 GT86
Worth also to take into account by how much speedo lies even with stock FD, if one tries to draw some lines between something calculated and reading from dash.
Old 08-30-2019, 01:44 PM   #49
Dr. BRZ
Dr. BRZ's Avatar
Oops my bad, I just realized I typed 3.56 and not 4.5. My bad, yes I have the 4.5 gears. Thanks for the heads up cause I had to think about it lol
Old 08-30-2019, 01:54 PM   #50
Dr. BRZ
Dr. BRZ's Avatar
Yeah that's what I meant to say, when I read your comment lol
Old 08-30-2019, 02:27 PM   #51
86TOYO2k17
Lol all good. How you liking it?
I thought it was best NA mod besides header/tune. Lets it pull hard through 5th.
Old 08-30-2019, 04:05 PM   #52
churchx
churchx's Avatar
Drives: 2014 GT86
86TOYO2k17: i like how those FD swaps can make upper gears more usable on track and add up that subjective feel of more performance due better gearing (up there).. but then again i dislike how 1st, and in more extreme ratio cases even 2nd, can be less usable, too quickly hitting redline and adding redundant shifts. Hence always thought that FD swaps should in most cases be used together with close ratio gearset, that makes 1st & 2nd gear longer. If only later wouldn't cost that much .
Old 08-30-2019, 04:56 PM   #53
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It's not as bad as you think though obviously track dependent. I almost never have to go down to 2nd anymore.
Old 08-31-2019, 03:28 AM   #54
churchx
churchx's Avatar
Drives: 2014 GT86
On tracks i go to most used are 2nd and 3rd (as 2/3 of those tracks are for karts, and just two, "full size"), 4th a bit less, and just on one i'd almost need 5th for 5sec at end of longest straight, but decide lingering at redline, as extra upshift-downshift would probably hurt times more. +I daily drive car a lot, and also have to crawl in traffic jams with no gas in 1st often. Hence why i wouldn't want just make top gears more usable .. at cost of making lowest gears less usable, but something that would improve overall, or add gains much more then (hopefully) little loss, for "win-win" lol . And to that imho close gear ratio set together with FD swap should fit best. Watching charts for eg. TRD/Cusco gear set, 1st & 2nd seem distanced more apart from rest, thus wished combo should make keeping in power band easier, keep 1st & 2nd almost same as before, easing their dailying usage, but keep 3-4-5-6 down for better gearing/acceleration .. unfortunately at high cost, much higher then just FD
Old 08-31-2019, 11:55 AM   #55
Dr. BRZ
Dr. BRZ's Avatar
I LOVE it! With it, I lost to a 335i by a bumper because I missed up the shift from 4th to 5th. On a roll, I was tied with a challenger rt in 6th gear. Good freaking mod.
Old 09-04-2019, 01:11 PM   #56
Gam3rBlue
Drives: Scion-FR-S
Doing this swap, Is it only good for Turbos or should It also be done for SC pushing 350whp? Lemme know, If its worth it.
Thank you,
Gam3rBlue is offline   Reply With Quote
IS300 M85/M98 rear diff - does it fit? PantsDants Engine, Exhaust, Transmission 39 03-28-2017 08:28 PM
Lexus is300 diff swap M98 3.91 ogrowup Engine, Exhaust, Transmission 5 02-28-2017 10:45 AM
Lexus IS300 Second Car - Thoughts? somecrazyazn Other Vehicles & General Automotive Discussions 48 05-05-2014 05:47 PM
vs Lexus IS300? SteelReign FR-S / BRZ vs.... 38 03-27-2012 11:48 AM
