Old 08-29-2019, 07:47 PM   #771
tzbang
Drives: 2013 GT86
My car has to go in for the valve spring recall. So that means engine out. Do you think while it's out I ought to pay Toyota to do some preparations for the SC? I was going to get them to replace the spark plugs anyway.. but now I'm wondering if I should get the clutch done, seems some people upgrade the clutch, snout and bearing when they go FI ?
My car has done about 63,000kms / 40,000miles.. clutch feels fine. Is the stock clutch setup not up to the task?
tzbang is offline   Reply With Quote
Old 08-29-2019, 08:24 PM   #772
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
The clutch should hold like 7psi, but I would upgrade. My stock clutch had plenty of life on it when it came out, but the throw out bearing failed. I chose the Exedy Stage 1 clutch, which is the same as the stock clutch, but with a thicker/stronger pressure plate, and I am on a 85mm/12psi pulley with E85 holding fine so far. Upgrade the TOB to the new one with the dot, and upgrade the fork/pivot. You can do the snout too like I did if you have damage. Check my build.
Old 08-29-2019, 08:50 PM   #773
HachirocksU
Drives: Friggin Really Sweet
Hello,
I wanted to ask,...Engine strength first or SC first?
Thank you!
HachirocksU is offline   Reply With Quote
Old 08-30-2019, 12:32 AM   #774
tzbang
Drives: 2013 GT86
I can't get E85 here. 98RON is the best we have. So I guess I'll stick with the standard pulley so maybe the standard clutch will be ok.
But yeah I did read your build which got me thinking about it. Just so happens I haven't done the valve spring recall yet, been putting it off. But it would make sense while the motor was out to get them to do some stuff. Although I am weary of these sorts of projects getting carried away cost wise..
New plugs. Maybe get them to clean the injectors??
Old 08-30-2019, 02:11 AM   #775
Irace86.2.0
@HachirocksU ...What's your goals? How much power do you want? E85 or pump gas? Depending on your goals, it may make sense to do FI then save for a build, but generally it is best to do a build first or save to do them at the same time.
@tzbang ...Yea, costs can build fast, but things are definitely cheaper when they are apart. Be sure to get a quote because they might charge you a computer calculated rate, regardless of how easy it would be to change the plugs with the engine already out. If the computer says the job takes 4.5 hours then they charge you for 4.5 hours, even if it takes 1 hour or 7 hours. I don't know about clean the injectors, but servicing the DI seals might be an option if you wanted them to make the motor tip top.
Old 08-30-2019, 01:27 PM   #776
CSG Mike
CSG Mike's Avatar
Originally Posted by HachirocksU View Post
Hello,
Thank you!
SC first. Built engine unnecessary unless you're trying to make crazy power.
Old 08-30-2019, 08:57 PM   #777
HachirocksU
Hello and thank you,
For California(SOCAL) option i'm limited with a tune w/o headers or go with a carb legal kit which I am content with those hp range. My goal is to improve as a driver and improve the tq dip on this car. I was also thinking about doing both at the same time as well but that could be hefty all of a sudden hehe.
Old 08-30-2019, 09:00 PM   #778
HachirocksU
Nope no crazy power for me. I probably wouldn't have to worry about rods as well yes? Is it an option for that piece of mind? Thank you.
Great to hear that you folks have re-involved with Harrop. It's nice that they keep the trd/stock airbox so it looks oem-ish.
Not ready yet but will give you folks a ring when it happens.
Old 08-30-2019, 09:21 PM   #779
CSG Mike
CSG Mike's Avatar
Install kit, throw on a safe tune, and call it a day. No need for rods.
Pulling the engine, opening it, doing rods, and then re-installing the engine will cost you more than the supercharger. Don't fall into the trap of unnecessary mods.
Invest it in a good oil cooler instead.
Irace86.2.0 (08-30-2019)
Old 08-30-2019, 10:54 PM   #780
Irace86.2.0
What he said is right. Just get a good tune on a base kit, and you will be fine. No need to build. There is risk with a rebuild too, and at that power level, the risk isn’t worth the reward.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
HachirocksU (08-31-2019)
Old 08-31-2019, 10:39 PM   #781
HachirocksU
Oil cooler is next on my list heh. nice. thx!
Old 08-31-2019, 10:39 PM   #782
HachirocksU
Sound advice. Thank you once again. I just didnt know that part of it.
Old 09-01-2019, 02:59 AM   #783
CSG Mike
CSG Mike's Avatar
PM when you're ready for the parts.
Old 09-01-2019, 05:48 PM   #784
tzbang
Drives: 2013 GT86
Is an upgraded clutch, TOB, fork, snout and oil-cooler all recommended or considered necessary when going FI ?
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 04:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 02:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
