Old 08-26-2019, 10:10 AM   #1163
ermax
ermax's Avatar
Originally Posted by YamahaR86 View Post
Following up on this. Managed to drop my oil pan this weekend, it was a PITA mainly because my exhaust bolt was seized and I was fighting it. Oil pan was pretty simple to take off, undo the 10mm bolts and pry off the sealant.
Not sure if it helps anyone but this is about 6k miles after recall.
@humfrz @Ultramaroon
Looks great!
Old 08-26-2019, 12:42 PM   #1164
Doesn't get any better than that!
Old 08-29-2019, 05:09 PM   #1165
Alfrz91
Drives: 13 Scion Frs
Not looking great on my stories end and am likely going to end up in small claims with them. On a separate note, I can drop a manual motor into my automatic with minor changes correct? Just looking to get this resolved the most cost effective way
Alfrz91 is offline   Reply With Quote
Old 08-29-2019, 06:47 PM   #1166
maslin
Benz Tech
Drives: 2017 BRZ Premium
I believe you can swap it for a couple (several?) thousand dollars.
It's not a tranny, clutch pedal and shifter trim kind of thing. There was a thread a few weeks back, someone had it all layed out with dollar figures. It's 3-4x what you would expect.
maslin is offline   Reply With Quote
Old 08-30-2019, 08:45 AM   #1167
GrantedTaken
I have not kept up with this thread.
After the first few fails, I decided I will never bother doing this recall.
Are there actually people still doing this recall?
Have the dealers still been having problems or is the recall all good now?
GrantedTaken is offline   Reply With Quote
Old 08-30-2019, 09:41 AM   #1168
Alfrz91
Just so we're clear, im literally talking about just the engine, not swapping my transmission. Just dropping a engine from a manual car, into my automatic car. Nothing about swapping the transmission.
Turning a manual engine, into a engine in an automatic car.
Old 08-30-2019, 10:00 AM   #1169
Yes, probably getting done somewhere just about every day, although we'll never really know since there are no numbers published on this, and VAST majority of users impacted are not on this forum.
Well, some shops never had issues, and some shops only had one or maybe two. I don't recall seeing a recent failure (as in the work was just done). Again, we'll never know for sure.
Old 08-30-2019, 10:16 AM   #1170
maslin
Benz Tech
Ah! Much better. Shouldn't be anything you can't swap from your current engine. Vacuum pump is the only thing off the top of my head?
Old 08-30-2019, 11:14 PM   #1171
gravitylover
I picked mine up last Friday and already have about 1200 hard miles on it. So far so good. I'll probably change the oil before I go back out on the road again next week just for good measure.
Old 08-31-2019, 06:57 PM   #1172
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
Just got the registration notice — damn CA. Let the games begin
PWBRZ is offline   Reply With Quote
Old 08-31-2019, 07:07 PM   #1173
marco1ca
Drives: Toyota Celica
Yes, and many have not had problems, see this thread:
https://www.ft86club.com/forums/showthread.php?t=133383
marco1ca is offline   Reply With Quote
Old 09-04-2019, 01:23 PM   #1174
Alfrz91
After speaking w the director of the dealer, my final options are:
1. Service Manager(who was the only one who wants to help even remotely), offered to put in a used motor that I bring to them into my car for no labor.
2. Kick rocks.
3. Have a separate shop put in a motor I purchase and pursue reimbursement in small claims. Unsure how it would look in court if I was to let the dealer put in the motor and then pursue small claims.
Car is still gutted so realistically the only labor I'm going to end up paying no matter what is essentially testing the motor, and swapping auto engine parts over into the manual engine.
Also, if anyone has any helpful info on freight shipping, please pm me. Like if there's any solid and preferably fast ones. East coast.
Old 09-07-2019, 02:47 PM   #1175
Ezmarii
Drives: 2013 brz used
MY 2013 limited BRZ auto
Had the valve spring work done in the 1st week of July. Put roughly 1k miles on it round trip in the last week of July for a road trip. After I got home, I only put about 7-10 miles on it a week (daily driver for work) Went on another road trip in the last week of August, another 1k round trip.
Some time during the drive home or within the day or two after, the noise started.
Noise: single or double metallic tap @ startup. while warming up, no abnormal noises. Once rpm drops <1k idle , slight metallic rattle timed perfectly with engine rpm sounds. If you rev up the engine at all, the rattle increases on tempo with the engine until it gets to about 1100-1300 and then it disappears.
While driving, if i take my foot off the gas and allow the car to coast down a hill, engine idles low enough to create the noise again. also can be heard at a stop light/stop sign.
The dealership was really busy this week, but after a week of no news they told me the flex plate is cracked and they can't prove if it was them or not while doing the recall work, so they're going to fix it w/ no charge.
Webster Groves Subaru @ Saint Louis
I will try to remember to update this if i hear anything else about it!
Ezmarii is offline   Reply With Quote
Old 09-07-2019, 03:58 PM   #1176
Flex plate?
What is that?
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 09:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 02:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 08:21 PM
