#8625 | |
2013 Series 10 FRS #553
#8626 | |
Drives: UK GT86
..... All seriousness, at standstill shouldn't matter. But RPM and the amount of throttle do matter. Smaller pulleys will whine earlier/louder due to the compressor spinning faster.
.: Stealth 86 :.
#8627 |
Drives: '13 SWP GT86
I've noticed the same thing - I can only hear my SC on high RPMs at WOT. And even then it's not really loud. I have a 72.5mm pulley, but my exhaust is pretty loud haha (ACE header/OP, catless and loud catback).
I THINK the Jon Bond SC oil I'm using might take a little out of the sound, and the fact that the SC unit itself has been rebuilt by them with new/better bearings and seals, and has their breather/"oil consumption prevention"-kit.. Just a guess though, cause mine isn't nearly as loud as a lot of videos might suggest.
IG @squareddesign
http://www.squareddesign.se |
#8628 |
Drives: '14
Well shit. Are you telling me that I should rev the car even more to make it whine?
#8629 |
Drives: GT 86
#8630 | |
Drives: 2017 toyota 86
#8631 |
Drives: 2013 GT86
Seems to be a lot of oil seepage and vacuum leak problems with the Sprintex design compared to the other SC options out there. I really like the kit but the amount of these issues are hard to ignore. Especially letting so much oil foul up the intake.
#8632 | |
As far as vacuum leaks its 90% install error. Some do get leaks at the recirculation valve, and some do get leaks at the gasket from blower to manifold. Both are simpler fixes. The oil consumption is a concern, i think a lot of them are on non intercooled kits not 100% positive though. But heat is usually the killer of most things. So reducing heat and heatsoak should help. intercooler, gold heat wrap intake pipe, cai, E85/WMI, hood scoop and or vents etc... i also switched to tribodyn oil and opened dipstick once fully hot and re-closed it the theory is at operating temp pressure should be around ambient, and slight vacuum when cold. |
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | LOJOKO (01-04-2020) |
#8633 | |
Drives: GT 86
It shares the same flow/coolant and is just plumbed into the exiting system with a few minor changes. Water jacket is fabbed out of aluminium with SS fixings . |
#8634 |
Drives: '14
For those running CF hoods: what are you running? Trying to figure out which hoods will clear our SC.
#8635 |
Drives: 86
I'm seeing a lot of questions about the whine.
It seems many don't understand the kit has a bypass valve that stays open at low/part throttle that bypasses the supercharger entirely. As such, if you're not on 50%+ throttle then your supercharger isn't actually supercharging, and you won't get whine. From there, ditch the standard airbox and move to a pod style filter to get even more noise. Tldr; hit the accelerator harder if you want the whine. Sent from my Pixel 3a using Tapatalk |
| The Following User Says Thank You to break For This Useful Post: | kev0 (08-29-2019) |
#8636 | |
Drives: '14
#8637 | |
Drives: UK GT86
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | kev0 (08-30-2019) |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
