Old 01-18-2018, 04:08 PM   #337
CSG Mike
CSG Mike's Avatar
Originally Posted by n0thing View Post
With regards to OS Giken Superlock, I've found two part# "TY421-HA" and "D-TC1FA20-S". How do they differ, if any?
TY421-HA is what you want. The other has almost zero configurability.
Old 01-31-2018, 10:44 AM   #338
n0thing
Drives: Subaru BRZ
Does upgrading the LSD induce additional stress to the driveshaft and/or axles? Do they require upgrading as well?
n0thing is offline   Reply With Quote
Old 02-01-2018, 03:00 PM   #339
CSG Mike
CSG Mike's Avatar
Stress is determined by the tire you run, not the LSD. If anything, the LSD will reduce stress since you'll no longer be spinning 1 tire as often.
Old 08-23-2019, 05:07 PM   #340
femaledog
Drives: 2017 BRZ Perf. Pkg.
My OS Giken 1.5way LSD is in the car now w/ CSG's settings on it. It's wild. I should have done this a long time ago.
I think its going to be quite a bit faster. Next time I'm at the track I'll compare.
femaledog is offline   Reply With Quote
Old 08-24-2019, 11:15 AM   #341
CSG Mike
CSG Mike's Avatar
Can you try to describe/explain the difference you feel? I know it's difficult to articulate, but SO MANY folks underestimate the confidence and performance boost a well tuned LSD can make.
Old 08-24-2019, 08:21 PM   #342
femaledog
I'm rarely at a loss for words, but initially I was having trouble describing it.
When powering out of a corner it feels like I'm driving a heavier car. Maybe 400lbs heavier. Not in terms of weight slowing down my acceleration, or my braking coming in. Just that much more mechanical grip, without the inertia that comes with it.
I had some fun ripping it through low grip sections that usually upset the car, and I could give more throttle, earlier, and still not lose traction.
Old 08-24-2019, 09:08 PM   #343
GrabTheWheel
Drives: 16' BRZ
You can get on the gas much earlier coming out of a turn, very noticeable at autoX. When you want to slide the car there is feeling of a better connection between both rear tires that is confidence inspiring. Although a welded diff or a 1 way would probably be better than my OS Giken 1.5 for hooning around. Mine is silent for the most part, once in a while it will act a little funny on very steep driveways on an angle, sometimes there is a hesitation.
I would say this has been one of my favorite mods to the car but totally unnecessary if your car is 100% street driven.
GrabTheWheel is offline   Reply With Quote
uberstupid
High-G Cornering Fueling Solution EAGLE5 Tracking / Autocross / HPDE / Drifting 24 02-22-2017 08:04 PM
cornering-on-rails feeling notout86 Scion FR-S / Toyota 86 GT86 General Forum 38 09-20-2015 07:00 PM
Engine cutting power after hard cornering... CSG Mike Tracking / Autocross / HPDE / Drifting 19 07-04-2015 08:40 AM
Traction control light comes even when not hard cornering? Yamajee Issues | Warranty | Recalls / TSB 26 04-10-2014 01:04 PM
Anyone have the radio switching modes during hard cornering?? silvercar CANADA 4 07-08-2013 12:49 PM
