Old 09-16-2018, 10:26 PM   #57
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Ok. Got the 2017 engine into the 13' chassis. I've been driving it for a week with no drivability issues. I had to change EVERY SINGLE SENSOR from the 17' back to the 13', so if you plan on doing this, that means you have to replace the DI seals grommets and gaskets and the rail because the fuel pressure sensor is different. I also had to take the cam gears from the 13' engine. It was a lot of work, but the engine runs just fine. I also had to change to a high boost supercharger pulley (18psi) I had laying around because the old belt broke on me. It pulls hard AF but I can't go passed 6k without running lean. Time to get back into tuning.
*EDIT* The boost pulley was too small and engine couldn't handle anything passed 18psi. I got a pulley that was slightly larger that still maxed out at 16psi but I'm now able to get to the 7500rpm rev limit no sweat. As of today 3/21/19 there has been absolutely no issues with the 2017 engine swap.
Added more info in a separate post: https://www.ft86club.com/forums/show...3&postcount=78
*Double Edit* STILL running strong as of 9 23 19. Supercharged FRS wrecks that booty!
D-VO is offline   Reply With Quote
Old 05-31-2019, 11:18 AM   #58
ChrisBRZ13
Why did you have to replace the cam gears?
ChrisBRZ13 is offline   Reply With Quote
Old 05-31-2019, 02:15 PM   #59
sokol
Drives: 2014 fr-s
hello, guys , i have a complete 17 swap and a 16 swap for anyone who needs it, with the ecu,harness and all other parts.
sokol is offline   Reply With Quote
Old 06-24-2019, 02:05 PM   #60
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
Originally Posted by ILLSMOQ View Post
I just did this. 2017 FA20 into a 2013 FRS. Is not a plug and play replacement...infact you have to do a lot of unplugging and swapping of parts to make it work. Basically the complete engine wire harness and the items listed below.
Crank reluctor wheel is different as well as the crank sensor and crank sensor mount which bolts in from behind the engine under the flywheel.
Pass side fuel rail is different and uses a different sensor
Coolant sensors are different
Ignition coils are different 2017 uses a 3 terminal connector 2013 uses a 2 terminal connector
Did you swap out the cam gears as well ?
el-92 is offline   Reply With Quote
Old 06-24-2019, 02:07 PM   #61
el-92
el-92's Avatar
So they cam gears on the 17’ wont run correctly with the older engine ecu or why did you swap them out
Old 06-25-2019, 02:59 AM   #62
el-92
el-92's Avatar
I also want to know that why were they changed
Old 06-28-2019, 12:51 AM   #63
D-VO
I'm not completely sure, but I was working with a Subaru tech during this time; it was something about the sensors inside the cam gears that are different.
Old 08-02-2019, 01:21 PM   #64
TheStig85
Drives: 2013 Subaru BRZ
I've been contemplating doing a swap like this. Unsure of the year, but a newer motor into my '13 Chassis. Is the easiest route to buy a newer motor, say '19, with a '19 wiring harness, and '19 ECU?
Or will this give me issues with the immobilizer (can this be replaced or issues with the cluster)? Perhaps, do a '19 swap and splice new connectors on the existing '13 harness to connect to the '19 sensors?
I'm open to suggestions, but I'd like to do this sometime.
TheStig85 is offline   Reply With Quote
Old 08-05-2019, 12:37 PM   #65
Bunta86
I have swap a 17 FA20 into my 16 everything plugged in where should a side the alternator. My issue now is that all it does it crank and popping crank position sensor code. I can’t seem to find any write up for 17 into 16 just this thread.
Bunta86 is offline   Reply With Quote
Old 08-05-2019, 03:43 PM   #66
TheStig85
I was told if you have a '13 Chassis, the latest engine swap you can do easily is '17. Other than the engine swap, you just need to swap out of the cam gears from the '13.
Can anyone else confirm this?
Old 08-05-2019, 04:37 PM   #67
fika84
fika84's Avatar
If you read this thread, you would know that 13-15 can be swapped easily. 16+ engine into 13-15 chassis is not plug n play.
fika84 is offline   Reply With Quote
Old 08-05-2019, 05:38 PM   #68
TheStig85
I have read over everything, and if I'm understanding it correctly, it seems like the Gear cams from the '13 are the only thing needed to swap over. When you order a new engine, does it come with sensors? If not, I can swap over the ones from the '13 engine.
I see in D-VO's swap did this and the sensors from the '13 due to the '17 wire harness being used.
Correct me if I'm wrong, but that's the way I'm interpreting it.
Old 08-05-2019, 05:44 PM   #69
fika84
fika84's Avatar
Fair question in that regard. For some reason when I read your first question I thought you were hoping it was just plug n play.
I've only ever bought used engines and when that's the case, if you need the sensors you have to make sure they're included. The used 2013 engine I bought a little while back didn't have the cam gear actuators on the timing cover so I had to reuse mine.
Definitely need someone else to chime in
Old 08-19-2019, 08:05 PM   #70
D-VO
That's correct. Sorry I can't rememberwho was doing the 16' swap; but but did you make sure the crank trigger wheel was the same? Are you 100% sure the cam gear sensors inside the gears are the same too?
FS: 2013 FA20 engine w/spun bearing Bullnettles Engine, Exhaust, Bolt-Ons 9 04-05-2017 07:39 PM
FS: FA20 Engine Sportsguy83 Engine, Exhaust, Bolt-Ons 12 03-01-2017 03:51 PM
2017 engine vs 2013 engine DailyDriver86 Engine, Exhaust, Transmission 17 11-09-2016 06:16 PM
Looking to buy FA20 engine ndreim Want-To-Buy Requests 0 12-15-2015 07:06 PM
FA20 Engine Wins Ward's 10 Best Engines of 2013 Jeffsu350 Scion FR-S / Toyota 86 GT86 General Forum 111 03-15-2015 04:39 AM
