Old 08-18-2019, 06:53 PM   #15
Unholypanda
Drives: 2017 BRZ Premium w/ PP
Originally Posted by Lightened View Post
How many miles have you driven since flashing the new tune?
100+. A lot less since I put the cat back on. Not sure if that would effect the trims/tune at all. I did that on Thursday and have only driven maybe 25-30 miles since then.
Unholypanda is offline   Reply With Quote
Old 08-18-2019, 06:59 PM   #16
Lightened
Every Ounce Counts
Lightened's Avatar
Drives: 86
.94 IAM is not bad for Florida heat and humidity.
Have you checked for any exhaust leaks starting at the headers to head(s) and all the way back at each connection point of the entire system?
Brand new exhaust flanges can sometimes slightly warp during welding of the pipe and won't seal properly... throwing off ST/LT values.
Lightened is offline   Reply With Quote
Old 08-18-2019, 07:03 PM   #17
Lightened
Every Ounce Counts
Lightened's Avatar
Drives: 86
Yes, you need to log more miles and vary the speed and engine load. Normal daily driving and pulls in different gears.
As the ECU learns it allows more power if the conditions are right or reduces power to protect itself.
The Following User Says Thank You to Lightened For This Useful Post:
why? (08-19-2019)
Old 08-18-2019, 07:10 PM   #18
Unholypanda
.94 IAM is not bad for Florida heat and humidity... fuel quality seems good.
Brand new exhaust flanges can sometimes slightly warp during welding of the pipe and won't seal properly throwing off ST/LT values.
Ya when re-tightening after a couple days I checked for residue on the fittings, and everything seemed clean. I've also put my hand near the fitting when idle to feel for any leaks and haven't found anything.
Would it be worth doing another fresh flash to let it relearn with the new catback? I'm planning on doing an E85 swap here in the next few days so I guess that would do that by default though so I probably shouldn't worry about it.
Old 08-18-2019, 07:15 PM   #19
Lightened
Every Ounce Counts
Lightened's Avatar
Drives: 86
Just wait and then flash for E85.
Have fun!
Old 08-18-2019, 07:18 PM   #20
86TOYO2k17
Drives: 2017 toyota 86
Just went and logged a pull. The IAM started at .7 when I turned the car on, and while driving went to .94 and stayed there. Not sure what that means.
The fuel trims are slightly worrying. ST Ranged from +7 to -15. The LT ranged from -2 to -11. Not sure exactly where in the log i should check the reading to get what I'm looking for. At the start of the pull it ranged from ST @ 4-7 and LT at -4. Once over 2k it went to 0 ST and -2.34 LT and stayed there. I guess that was where it went closed loop?
While the throttle was >90 the AFM was in between 12 and 13 so that seems alright. Over the whole log it ranged from 11 to 20. That was while idling driving normal etc...
I attached a CSV of the data log from the OFT, also https://datazap.me/u/unholypanda/pull?log=0&data=1-13
AFR looked fine, no knock correction, IAM wasn’t dropping. So it looks fine for the most part.
But Fuel trims are a bit high. Possible exhaust leak before the O2 sensor. I would double check your header isn’t leaking. Could clean maf sensor for good measure.
On 93 octane you should have no problem getting to and staying at IAM 1. Although depending on how you drove and how long. You may not have given it enough time. Can take a solid 10mins from start on those maps.
Also fuel trims and everything else can take a good 100+ miles to sort out off a fresh tune. Starting at .7 is to have a safe universal tune mostly for people with 91 octane. On 93 you could change it to start at .9 and have it go to 1 faster.
Based on all this I bet your car wasn’t at it’s full potential on those dynos.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
why? (08-19-2019)
Old 08-18-2019, 07:27 PM   #21
Unholypanda
I'll check the header for leaks tomorrow and clean the sensor.
I only drove for maybe 10m tops to the store and back. I'll check it tomorrow on my way to work to see what it gets to.
It sat for a good 30 min while we did paperwork and got it strapped in then threw it on and did the pulls so it might not have been up to temp and ready to go.
Old 08-18-2019, 08:36 PM   #22
Lightened
Every Ounce Counts
Lightened's Avatar
Drives: 86
Stock airbox & filter?
Old 08-18-2019, 09:31 PM   #23
Unholypanda
Just did another quick test. Nothing major. Tried doing the "vishnu reset" to get the IAM up to 1 by steady accelerating in 3rd a few times. https://datazap.me/u/unholypanda/tac...og=0&data=1-13
Didn't budge. Then when I floored it on the way back it bumped up to .84 https://datazap.me/u/unholypanda/taco-bell-drive?log=1
I feel like I'm missing something in the way it works.
Old 08-18-2019, 09:33 PM   #24
Unholypanda
Ya. I have a K&N drop in coming Tuesday. Found out the hard way that the 2017 MT has a different airbox.
Old 08-18-2019, 11:17 PM   #25
86TOYO2k17
@steve99 should be able to better look at your logs.
Not sure why your having a hard time getting IAM up. 93 should have no problem. Your intake temps are pretty high it’s possible that could be playing a role. Also your fuel trims seem a bit high.
Every time you turn off/on the car it’ll reset back to .7 so your dyno almost certainly was done at .7 which is going to pull enough timing to make some lower numbers like you had.
Old 08-19-2019, 02:18 AM   #26
steve99
Drives: FT86
Logs don't look too bad.
On good 93 jist modify iam initial to be 1 then it will start with iam at 1 ie get max power straight away.
why? (08-19-2019)
Old 08-19-2019, 07:12 AM   #27
Lantanafrs2
Drives: 2013 frs red
I think it takes longer for ecu to learn pump gas then e85. My experience anyway.
Lantanafrs2 is offline   Reply With Quote
Old 08-19-2019, 07:30 AM   #28
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
How many miles between when you flashed the tune and the dyno pull?
The heat and humidity will not be a friend. What shop did you use? There are some shady places in florida, and they might do everything to keep that as low as possible to try and get some business from you.
why? is offline   Reply With Quote
OFT V3.02 Stage 2+ Flash Dyno Results mgarcia707 Software Tuning 3 11-12-2018 03:55 PM
Dyno Results - OFT Stage 2 UEL + Openflash Header + Full Exhaust pinski Software Tuning 8 11-21-2016 11:07 AM
Stock Dyno and Perrin Stage 1 Results brillo Software Tuning 4 01-24-2014 08:26 AM
FINAL RESULTS: Taking Full Blown Stage 1 To The MAX! @Pure Automotive (Dyno Inside!) Pure Automotive Forced Induction 57 03-27-2013 11:41 PM
TRD cat back, any dyno results MTCRX Engine, Exhaust, Transmission 4 11-26-2012 06:26 PM
