Old 08-18-2019, 03:27 PM   #519
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Originally Posted by Impureclient View Post
I'll check in since it's been a while.
It's been two and a half years since I had the TSB done and still no chirps have returned
and it was really chirping it up before the fix.
I've only ever used Chevron 93 from the same gas station for the entire time I've had the car.
Same here with using only Chevron premium unleaded gas. But here on Oahu Chevron Hawaii was bought out by Texaco a few years ago.
Yuh, the chirping was quite loud when it was taken to dealership. I'll find out later when I drive my car if the chirps have stopped or not!
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 08-18-2019, 03:31 PM   #520
86geek
86geek's Avatar
My car's pump was changed, however, still getting chirping but not as loud or as frequent prior to the swap. The chirping is more prevalent when it's really warm outside or if I use certain fuel brands.
Yuh, the high temps and high humidity makes the temperatures here on Oahu very HOT! Real feel temps are in the 90's -95!
Old 08-30-2019, 09:49 PM   #521
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
I think I've got about 10k miles on the new fuel pump, and once in a while I think I still get some chirping, but not nearly as loud and noticeable as the original. Might just have to grin and bear it since there's no gasoline anywhere around me without ethanol content.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 08-30-2019, 10:55 PM   #522
jcb476
Release 10 Series
jcb476's Avatar
Drives: 2013 10 Series FR-S #1874
Agree...sometimes I think even with the new fuel pump, I might still hear the chirps slightly when idling or whenever pulling into my garage. Even if I do hear them ever so slightly, it's so much more quieter than the original pump.
jcb476 is offline   Reply With Quote
DEATSCHWERKS DW 925cc Fuel Injectors & DW65c Fuel Pump ZeroTo86 Engine, Exhaust, Bolt-Ons 0 08-08-2016 06:39 AM
FS: Moto-East Flex Fuel Kit - OEM Fuel Pump FR-Shred Engine, Exhaust, Bolt-Ons 1 05-16-2016 06:28 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
Fuel pump sw20kosh Engine, Exhaust, Transmission 1 12-10-2013 10:21 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
